*Closed* 20% Off Supercharger Group Buy 2nd Gen 4.0 Engine
Discussion in 'Closed Group Buys' started by big_jarv, Oct 6, 2016.
  1. Mar 23, 2017 at 6:50 PM
    #4381
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Totally normal.
    18 is nothing... AFR on my Shelby jumps to 28 (probably max for the Aeroforce Interceptor gauge I use) when coasting in gear!
    oliver1539[QUOTED] likes this.
  2. Mar 23, 2017 at 7:53 PM
    #4382
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I rarely check AFRs at fuel cut anymore, I'm more excited by my Ultragauge telling me I'm getting 60 MPGs lol, fuckin try to coast in nuetral everywhere I can lol
  3. Mar 23, 2017 at 11:05 PM
    #4383
    Norton
    Configure it to recognize injector cutoff and it will tell you you're getting 999.9MPG.
    TacoCat likes this.
  4. Mar 24, 2017 at 3:02 AM
    #4384
    VolcomTacoma
    Jeff
    NorCal
    Pfffff I'm cool with 60 mpg, lets mot go crazy.
    Pavlik1988 likes this.
  5. Mar 24, 2017 at 4:11 PM
    #4385
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    How does one do this? I want to see this mythical unicorn show up on my UG. Sometimes i see it hit over 100mpg in neutral on a long hill if i am over 60 or so mph.
  6. Mar 24, 2017 at 4:36 PM
    #4386
    Norton
    I'm not sure of the specific version UltraGauge you have but, for my UG EM, Injector Cutoff is discussed on pp 14 and 43 of the Owner's Manual...
    MENU > UltraGauge Setup .. > Injector Cutoff
    Often the engine is used to de-accelerate the vehicle, for example when heading down hill in gear or when the engine is used to slow the vehicle during engine braking. While in gear and during de-acceleration, many vehicle manufacturers will turn off the fuel injectors in order to save fuel. This is true for vehicles with either manual or automatic transmissions. The fuel savings is slight, but over time and distance could become significant. UltraGauge can detect when the injectors are switched off and factor the fuel savings into the fuel usage and mileage calculations.
    Injector cutoff is disabled when set to zero, and is disabled by default. To enable Injector cutoff detection, set the value equal to seven times the engine size in liters, rounded up to a whole number. For example, for a 2.3L engine the value should be set to 2.3x7= 16.1 > 17. The value is not crucial and this calculation represents a best estimate.
    When enabled and injector cutoff occurs, the Instantaneous MPG will read 999.9, and the Instantaneous Gallons/hour will read 0.0
    TacoCat[QUOTED] likes this.
  7. Mar 25, 2017 at 12:00 PM
    #4387
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    So I finally got my supercharger installed yesterday... no problems so far I got the TRD reflash. All smiles over here :D
    oni06, gersus, TacoCat and 4 others like this.
  8. Mar 25, 2017 at 12:08 PM
    #4388
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Loginfailed likes this. :thumbsup:
  9. Mar 25, 2017 at 3:43 PM
    #4389
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    It would be really interesting if a few guys lived close to each other and got together and did some runs to compare performance differences between various setups. Like bd vs trd etc ;)
  10. Mar 25, 2017 at 4:21 PM
    #4390
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My truck is becoming a fat pig as I add more go-slow accessories. I'll let you guys duke it out, LOL.
    oni06 and Pavlik1988 like this.
  11. Mar 25, 2017 at 4:22 PM
    #4391
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Speaking of guys who live close to me... WTF ever happened to @Biscuits ?
  12. Mar 25, 2017 at 6:29 PM
    #4392
    Pavlik1988
    Pavlik1988 Well-Known Member
    Pavel
    Chicago
    2015 Toyota Tacoma TRD Sport 4X4 V6 SC
    modified
    Chicago, NW suburbs, IL
    trd flash, 2.825" stock intake, DCSB, 6-speed
    But it will be big difference if someone add bumpers or big tires.... or other heavy environment
  13. Mar 26, 2017 at 6:17 PM
    #4393
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Got the fuel pump out today. Gotta put new pump in and a couple small things before starting it up. Got it all reflashed tho no problem.
    Camby, Norton, gersus and 1 other person like this.
  14. Mar 27, 2017 at 5:58 PM
    #4394
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Catch can will be here Wednesday. So hopefully she will fire up this weekend. Roads still covered in salt tho so she's not leaving the garage.
    loginfailed likes this.
  15. Mar 28, 2017 at 7:37 PM
    #4395
    Norton
    Still need to install my S/C :anonymous:, but the BD will never interface with my ECU... Sold it via Craigslist this afternoon. :yay:
    Local dealer quoted me $125 to install TRD flash. Now, I need to find the time for surgery.
  16. Mar 28, 2017 at 8:46 PM
    #4396
    ThomasMore66
    Dallas/Fort Worth & Durango
    Just let Toyota do the install. Save yourself. Write a check.
    Norton[QUOTED] likes this.
  17. Mar 28, 2017 at 8:48 PM
    #4397
    Norton
    I'm seriously considering that! Quoted price for the complete install was $950, including the flash.
  18. Mar 28, 2017 at 8:51 PM
    #4398
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Little secret. The blower is technically an "accessory" so be sure you are being charged TRD accessory rate and not the higher mechanic shop rate. I got mine at accessory rate and then negotiated $10/hr off that price which Toyota had a code in the system for, so it is something they do often enough.
    TacoCat and Norton[QUOTED] like this.
  19. Mar 28, 2017 at 8:52 PM
    #4399
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Good move. :)
  20. Mar 29, 2017 at 12:07 AM
    #4400
    Pavlik1988
    Pavel
    Chicago
    modified
    I payed 850+tax. With flash
    Norton[QUOTED] and tacomavoyager like this.
