CLOSED 5/31/20 GROUP BUY Dirt King LCA's Ball Joint Type GROUP BUY ENDS 5/31/20 CLOSED
Discussion in 'Automotive Group Buys' started by Unchained 5150, Mar 26, 2020.
  1. May 11, 2020 at 4:25 PM
    #361
    Idahotaco88
    Idahotaco88 Well-Known Member
    Steven
    2017 black AC OR
    Kings 2.5 with adjusters, icon rxt stage 2. SCS stealth blue on 35s
    Order #6863. Looking forward to these!! Thanks for the group buy.
    Mully and Gregw138 like this.
  2. May 11, 2020 at 4:26 PM
    #362
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Not wheeling also has the same effect
  3. May 11, 2020 at 4:27 PM
    #363
    hoarder23
    Shay
    NJ
    Scratches
    I'm about to lower it, my junk has seen some shit
  4. May 11, 2020 at 4:27 PM
    #364
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Correct that's me they will beautiful forever
    Mully and hoarder23[QUOTED] like this.
  5. May 11, 2020 at 4:28 PM
    #365
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    That’s not happening. I have big plans
    uurx, Mully and hoarder23[QUOTED] like this.
  6. May 11, 2020 at 4:45 PM
    #366
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Yep, we are Moab bound again this year, then over to CO, up into WY, into MT, eventually we will end up at ID dunes for a week. Parents live in Idaho. I run a 7 to 11 state run each year, everything from sight seeing, to running some trails. Life is good my TW friends.
  7. May 11, 2020 at 4:54 PM
    #367
    Gregw138
    Greg
    NY
    WAY TOO MANY
    https://youtu.be/BXWvKDSwvls
  8. May 11, 2020 at 5:01 PM
    #368
    Mully
    CA
    Gregw138[QUOTED] likes this.
  9. May 11, 2020 at 5:04 PM
    #369
    Unchained 5150
    Rick
    Auburn Ma
    I think I'm going to buy a new pair of JBA's and paint them Yamaha Blue with PJ1 Epoxy Paint. Then install when I put the Dirt Kings on.
    Gregw138, Mully[QUOTED] and patdeezy like this.
  10. May 12, 2020 at 6:57 AM
    #370
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    So I just ordered a set of Timbren Active Offroad bump stops to go with these. Does anyone know if I should still install the spacer provided by DK with non-OEM bump stops?
    Once I get them in I can get some measurements on their compressed height vs. the OEM compressed height as well but just wondering if anyone has used these already.
    TACOtrd1106 likes this.
  11. May 12, 2020 at 10:17 AM
    #371
    Gregw138
    Greg
    NY
    WAY TOO MANY
    Did the LCA braces install go smooth ?
  12. May 12, 2020 at 10:23 AM
    #372
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Still waiting on the guy with the welder to come by...
    Ive got everything disassembled and sanded/prepped but that part of it went well at least.
    I will say that my alignment cam bolts were rusted to hell after only 40k miles in dry climates. So hopefully the grease-able fittings help prevent this in the future.
    Mully likes this.
  13. May 12, 2020 at 10:43 AM
    #373
    Gregw138
    Greg
    NY
    WAY TOO MANY
    Supreme Suspensions - Front Caster & Camber Kits for 2016-2020 Toyota Tacoma Greaseable Alignment Cam Bolt Kit https://www.amazon.com/dp/B085P2K7K3/ref=cm_sw_r_cp_api_i_56TUEbZPDNSAQ
    I got the greaseable cam bolts also to install when my lowers arrive. I’m not sure if it’s necessary with the greaseable bushings but I live in a heavily salted area in the winter. Good luck with rest of install.
  14. May 12, 2020 at 11:17 AM
    #374
    hoarder23
    Shay
    NJ
    Scratches
    I'd be wary of that kit. I've seen multiple reports of that style having the plates round out. It looks like those are just the MOOG kit x2 and with their sticker. https://www.tacomaworld.com/threads...lem-solver-caster-camber-cam-bolt-kit.317057/
  15. May 12, 2020 at 1:34 PM
    #375
    Gregw138
    Greg
    NY
    WAY TOO MANY
    Good to know. Thanks for the heads up. It’s kinda redundant anyways since the lowers have grease fittings. I will just never seize the shit out of the OEM bolts
    Mully and Island Cruiser like this.
  16. May 12, 2020 at 4:58 PM
    #376
    Mully
    CA
    Got the alignment done, truck drives great, feels good when turning around corners, seems like it feels a little firmer in the steering. All comes down to the truck drives flawlessly. Alignment tech said "that's a bitchen truck".
  17. May 12, 2020 at 5:10 PM
    #377
    Unchained 5150
    Rick
    Auburn Ma
    Indeed it is
    Mully[QUOTED] likes this.
  18. May 12, 2020 at 5:48 PM
    #378
    Idahotaco88
    Steven
    2017 black AC OR
    Did you remove your sway bar?
  19. May 12, 2020 at 5:52 PM
    #379
    Gregw138
    Greg
    NY
    WAY TOO MANY
    I’m willing to bet that thing has been off for quite some time.
    Mully likes this.
  20. May 12, 2020 at 5:53 PM
    #380
    Mully
    CA
    A couple of years ago.
    Gregw138 likes this.
