[CLOSED] Airflow Snorkel Group Buy #2
Discussion in 'Closed Group Buys' started by mahaloTaco, Aug 5, 2016.
Thread Status:
Not open for further replies.
  1. Jan 26, 2017 at 7:24 PM
    #5001
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Yes, theres a center bit. But someone was talking about jumping or being too rough
  2. Jan 26, 2017 at 7:25 PM
    #5002
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Start the hole with drill in reverse. Once you have a good start, drill normally but SLOW. Do not force it. Done
    Drainbung, Sna, Gply and 1 other person like this.
  3. Jan 26, 2017 at 7:28 PM
    #5003
    fatfurious2
    David
    Ashburn, VA
    Can I score the fender with the saw in reverse, and then change direction?
    chiefcrunchy likes this.
  4. Jan 26, 2017 at 7:29 PM
    #5004
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Exactly. And ffs, if you have never used a hole saw before, at least practice on a piece of wood before trying to drill your fender.
  5. Jan 26, 2017 at 7:30 PM
    #5005
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    What time-ish? Your place?
  6. Jan 26, 2017 at 7:31 PM
    #5006
    fatfurious2
    David
    Ashburn, VA
    It's going to be at @Lots2Learn58 place in Burke. Around 8:35pm
  7. Jan 26, 2017 at 7:32 PM
    #5007
    chiefcrunchy
    Brian
    That may be doable.
  8. Jan 26, 2017 at 7:33 PM
    #5008
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I already told you all of this son...
    Sure, you believe a pro carpenter/pseudo plumber/enthusiast fabricator/welder over a...
    ...Lab Tech
    :rolleyes:
    mbmack1, Bentrodder, trekker and 3 others like this.
  9. Jan 26, 2017 at 7:35 PM
    #5009
    fatfurious2
    David
    Ashburn, VA
    When we get there in person, will be putting all of this to use
  10. Jan 26, 2017 at 7:45 PM
    #5010
    Subway4X4
    Lloyd
    NY/NJ
    My opinion: Too much work using a Dremel for this particular fender project. I would've used a angle grinder with a fresh cutting wheel since there is a lot of room and a lot of relatively straight lines. For the inside curves, maybe switch to a grinder, instead of cutting wheel.
    For a 4" hole, the Dremel method would likely work a lot better than a angle grinder because there's not a lot of room for it.
    Just an opinion.
  11. Jan 27, 2017 at 4:28 AM
    #5011
    fatfurious2
    David
    Ashburn, VA
    Out for delivery!! :annoyed::yay:
    trekker likes this.
  12. Jan 27, 2017 at 5:38 AM
    #5012
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    Luckily it all missed me, but thats not the only time something like that has happened and I don't always get lucky enough to get out of the way in time so pissed off about being pissed on. Haha
  13. Jan 27, 2017 at 5:44 AM
    #5013
    mbmack1
    matt
    az
    SAVAGE silver '06
    Just to be clear for everyone who isn't familiar with this method. You need to have the drill in forward in order to make the center hole with the arbor. Once the arbor is through, then you reverse to score your hole saw line, then forward again to complete the cut.
    If you attempt to drill the arbor (pilot) hole in reverse it's just gonna walk all over the place on you. And start with very little pressure until the arbor bit starts to cut where you want it too. If you press too hard and it starts to walk it may slip and scratch the hell out of your truck.
  14. Jan 27, 2017 at 5:53 AM
    #5014
    mbmack1
    matt
    az
    SAVAGE silver '06
    When I have to drill ceramic tile for mounting grab bars in showers I use small diamond holesaws to get through the tile. They don't have arbors. You have to have the drill going full speed and contact the tile at a 45° angle until you get a score line, then straighten out slowly to go straight through. Stresses me out every time I have to do it. Especially in a brand new remodeled shower.
    ABA180 and Blackout14 like this.
  15. Jan 27, 2017 at 5:55 AM
    #5015
    Subway4X4
    Lloyd
    NY/NJ
    Good stuff. Additional words of wisdom if you don't mind, mainly to reduce the chances of wandering:
    Use a center punch to make a small dimple so your pilot bit doesn't wander around.
    After you center punch, maybe drill a hole with a regular, sharp bit.
    Then follow with your hole saw, going in reverse as previously described, with the pilot bit into your new center hole.
    Then forward to complete the cut as described above.
  16. Jan 27, 2017 at 5:57 AM
    #5016
    mbmack1
    matt
    az
    SAVAGE silver '06
    Yep. I like doing an 1/8" pilot hole as a first step any time I'm drilling metal. Easier to control and it removes the possibility of the larger bit walking around on you.
    Blackout14 and fatfurious2 like this.
  17. Jan 27, 2017 at 6:24 AM
    #5017
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This. Just went through it for the water feed on my toilet.
    mbmack1[QUOTED] and Blackout14 like this.
  18. Jan 27, 2017 at 6:45 AM
    #5018
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    why has no one used a jigsaw?
  19. Jan 27, 2017 at 7:07 AM
    #5019
    la0d0g
    running for the hills
    For crawling not hauling
    So much discussion over drilling a hole :anonymous:
  20. Jan 27, 2017 at 7:08 AM
    #5020
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
Thread Status:
