[CLOSED] Airflow Snorkel Group Buy #2
Discussion in 'Closed Group Buys' started by mahaloTaco, Aug 5, 2016.
Thread Status:
Not open for further replies.
  1. Aug 15, 2016 at 5:14 PM
    #121
    mahaloTaco
    mahaloTaco [OP] TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    Get em' while there hot!
    I have a Supercharged 4 banger. It is the same application as a v6.
  2. Aug 15, 2016 at 5:16 PM
    #122
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Do you have a pic by chance under the hood? I know that itll be different cause you have glass fenders and all but I want to see how it attaches to the stock air box... I also really want the safari snorkel unfortunately not the airflow one. Just sticks out far.
  3. Aug 15, 2016 at 5:16 PM
    #123
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Ya hook up the two round thingies
    mahaloTaco[OP] likes this.
  4. Aug 15, 2016 at 5:17 PM
    #124
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    The airboxes are different from 4 cylinder to 6 cylinder... I know how but there is different plumbing you need to do.
  5. Aug 15, 2016 at 5:21 PM
    #125
    mahaloTaco
    Max
    Los Angeles
  6. Aug 15, 2016 at 5:25 PM
    #126
    mahaloTaco
    Max
    Los Angeles
    Safari one is a rip off in price.
    Also limits the amount of Airflow.
    Safari cannot be used with a supercharger as well.
    IMG_7611.jpg IMG_7608.jpg IMG_7612.jpg IMG_7609.jpg IMG_7613.jpg IMG_7610.jpg
    The Hunter[QUOTED] likes this.
  7. Aug 15, 2016 at 5:29 PM
    #127
    mahaloTaco
    Max
    Los Angeles
    Air boxes are different but same diameter
  8. Aug 15, 2016 at 5:29 PM
    #128
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Thanks for the pics!
  9. Aug 15, 2016 at 5:30 PM
    #129
    mahaloTaco
    Max
    Los Angeles
  10. Aug 15, 2016 at 5:33 PM
    #130
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    What do you guys think about this? I read there is problems in heavy, wet snowfall. What if right where the plumbing goes into the air box, I have a door that can close and then the air is drawn from the normal location. Only for use during heavy snow. Think this is possible?
  11. Aug 15, 2016 at 5:36 PM
    #131
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    That could be cause for leaks when the snorkel is functioning as a snorkel... They make attachments for snow Im pretty sure NYCO has one something that won't allow that stuff in
  12. Aug 15, 2016 at 5:38 PM
    #132
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Yea that's probably the better way to go
  13. Aug 15, 2016 at 6:03 PM
    #133
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Damn peer pressure is killing me.
    Does the connection pipe routing in the engine bay change? My passenger side engine bay is maxed out because of the Aux Battery.
    Can someone show pics on how the connection is routed inside the engine bay to the outside plenum?
  14. Aug 15, 2016 at 6:04 PM
    #134
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    It goes into the factory airbox tubing under the hood that goes into the opening at the fenderwell. Still uses the factory airbox in the factory location
  15. Aug 15, 2016 at 6:12 PM
    #135
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    can you just turn the top hat 180* in the snow?
  16. Aug 15, 2016 at 6:15 PM
    #136
    Dave41079
    Dave...
    Nashville, TN
    It will be in a negative pressure zone while driving at speed and won't draw enough air to supply to the engine. Donaldson makes pre-filters that work well.
  17. Aug 15, 2016 at 6:47 PM
    #137
    la0d0g
    running for the hills
    For crawling not hauling
    Never had an issue in the snow after three seasons. Like others said, run a prefilter if you're concerned about it.
    Airflow specifically says to not rotate the intake for speeds above like 20mph (I can't remember the exact mpg).
  18. Aug 15, 2016 at 6:49 PM
    #138
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Do it Lloyd!!!
    mahaloTaco[OP] and fatfurious2 like this.
  19. Aug 15, 2016 at 6:51 PM
    #139
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Taking money yet :D I've spent so much already last week :anonymous:
    mahaloTaco[OP] and stairgod like this.
  20. Aug 15, 2016 at 6:51 PM
    #140
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    whats the explanation behind this?
Thread Status:
