CLOSED - Apex Fabworks and Cali Raised LED Black Friday Group Buy - CLOSED
Discussion in 'Closed Group Buys' started by MojaveMadman, Nov 17, 2016.
  1. Jan 2, 2017 at 10:26 AM
    #641
    Soccer Mom
    Soccer Mom Well Endowed Member
    2017 MGM SR5 DCSB
    METHOD | SOS | C4 | RIGID | PRINSU | OME | TC
    https://youtu.be/45RUedrAbXM
    Deet[QUOTED] likes this.
  2. Jan 2, 2017 at 10:44 AM
    #642
    neoflex
    neoflex Well-Known Member
    Haven't had a chance to get back out and mess with it. I was going to make my way out the other day to wire it up and play with the mounts more but I could not find the harness. I suspect one of the kids packed it away with the Christmas decorations without me noticing and rather than drive myself nuts unloading everything from the attic again and than unloading a ton of totes I spent the $15 and ordered another one from Cali-Raised. Once I get out to wire it I will probably see if I can get it more centered. Anyone else run into this issue? Like I said earlier, it's literally a 1/4" at most. Not a lot but enough to get my OCD kicking. Curious to see if anyone else has experienced this or if the slightly off center is normal.
  3. Jan 2, 2017 at 10:52 AM
    #643
    MojaveMadman
    MojaveMadman [OP] Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    This is the first I have heard of this happening. There is some room in the hole on the mounts to move it a little in either direction. It way also be the plastic in the grill could be slightly off to one side, but with nothing to reference you never would notice. Or more than likely a combination of a few things. I would try and adjust with the holes in the mounts. Then if you still can't get it as desired it may take some pushing on the mounts to move them over a little bit. Could probably be done with a piece of wood leveraged off the frame or something. Every vehicle made has slight differences from the manufacturing processes. It was 5 degrees colder the day your truck was made and the plastic or metal parts cured a tiny bit different. Add in how many parts are on a truck and the same efforts with the mounts. We build every mount in a fixture but there are a thousand little variables when welding or bending stuff. There is actually a station on the assembly line where guys have pry bars and mallets and other stuff and they go through the truck and "adjust" body panels and what not to get them fitting perfect after being installed. It's actually kind of funny to see.
  4. Jan 2, 2017 at 10:52 AM
    #644
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Do the brackets have adjustability left & right? I didn't think they did but have not installed mine yet
  5. Jan 2, 2017 at 11:15 AM
    #645
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    They are not slotted but the holes are over sized, so there is a little bit of room. Like I said, first time I have ever had this issue so I wouldn't worry about it too much.
  6. Jan 2, 2017 at 12:07 PM
    #646
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    PREMIUM HARNESSES ARE READY!!!!
    Just got this box in the mail and did a fast test, works perfect!!!
    When the head lights are off, no illumination. When you push the button, the image lights up.
    When the head lights are on, the words illuminate. When you push the button you have both the words and the image light up.
    There is a 42" illumination lead on the harness. This will allow you to install the switch either on the left side of the steering wheel or in the center of the dash. The tap a fuse is also a separate part. This way you can route the wire without any issues, then make the final connection once everything is in place. The add a fuse allows for the stock fuse to remain in use and also adds a fuse to the illumination wire for full protection. This harness is badass!!!
    On my website now for order. I have 25 in hand and more will be ready in another two weeks. If you have any questions please let me know!
    SGT Taco, Fuse and srdoublecab2.7 like this.
  7. Jan 2, 2017 at 12:10 PM
    #647
    srdoublecab2.7
    srdoublecab2.7 SRlifted&gifted
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
    These look sweet
    Defiantly gonna have to get some ditch lights and a 30 inch in the grill
  8. Jan 2, 2017 at 12:10 PM
    #648
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
  9. Jan 2, 2017 at 12:38 PM
    #649
    ChaseUA
    ChaseUA Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
  10. Jan 2, 2017 at 12:59 PM
    #650
    pc3coyote
    pc3coyote www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
  11. Jan 2, 2017 at 1:12 PM
    #651
    s1t808
    s1t808 Sitting in the timeout corner
    HI > OCONUS
    2015 Taco
    Lift? Yea I got one of those
    Order placed!
    MojaveMadman[OP] likes this.
  12. Jan 2, 2017 at 1:18 PM
    #652
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    What color is the illumination? I would be looking for amber to match my other dash lights.
  13. Jan 2, 2017 at 1:25 PM
    #653
    Fuse
    Fuse Geologist
    Calgary
    2015 TRD Sport 6MT
    Ordered!
    :cheers:
  14. Jan 2, 2017 at 1:32 PM
    #654
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    I will do a write up when I have time. It is honestly super easy. The harness needs three connections. There is a positive and negative that go to the battery. There is the plug that goes into the LED. And there is the add a fuse that you plug into the tail light fuse. And the rest is just running wires or switches to places you desire.
    They are amber illuminated. If anyone wants another color or different size switch you can buy any of the Mic Tuning Toyota style switched and they will plug right into the harness.
    SGT Taco and Nickel like this.
  15. Jan 2, 2017 at 4:06 PM
    #655
    Deet
    Deet Well-Known Member
    Tracy, CA
    2016 White TRD Off-Road 4x4 DCSB
    Thanks, Chris. Ordered... :D
  16. Jan 2, 2017 at 4:17 PM
    #656
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
  17. Jan 3, 2017 at 7:11 AM
    #657
    I'mTheDude
    I'mTheDude Well-Known Member
    Hickory, NC
    2012 DCSB TRD OR
    Ordered. WOOT! Also, will I be able to tap into the add-a-fuse somehow to wire my ditch lights as well?
  18. Jan 3, 2017 at 11:15 AM
    #658
    UberDingu
    UberDingu Well-Known Member
    CT
    21 Off-Road AC 4x4 V6
    Yeeesss... ordered
  19. Jan 3, 2017 at 1:59 PM
    #659
    Soccer Mom
    2017 MGM SR5 DCSB
    Got one!
  20. Jan 4, 2017 at 7:09 AM
    #660
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    You can splice into
    The illumination wire. I wouldn't mess with the fuse part.
    I'mTheDude[QUOTED] likes this.
