**CLOSED**ARB compressors 5.0 - Group Buy**
Discussion in 'Automotive Group Buys' started by ramonortiz55, Feb 11, 2019.
  1. Feb 22, 2019 at 3:08 PM
    #121
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    added
  2. Feb 24, 2019 at 12:06 PM
    #122
    jaredc2306
    jaredc2306 Well-Known Member
    Jared
    San Antonio, Tx
    2016 ACLB TRD OR Quicksand
    I’m in for the twin without the tank. Thanks! @ramonortiz55
  3. Feb 24, 2019 at 1:07 PM
    #123
    ramonortiz55
    Ramon
    Texas
    stock
    added
  4. Feb 24, 2019 at 7:54 PM
    #124
    BETX983
    BETX983 Active Member
    2017 TRD Off-road
    Twin please...no tank.
    I need to stop reading group buy posts!
    BlueFox18 likes this.
  5. Feb 24, 2019 at 7:54 PM
    #125
    ramonortiz55
    Ramon
    Texas
    stock
    addee
  6. Feb 25, 2019 at 5:27 AM
    #126
    ramonortiz55
    Ramon
    Texas
    stock
    List updated, this closes on Thursday!
  7. Feb 25, 2019 at 5:50 AM
    #127
    Steve565
    Steve565 Well-Known Member
    Boise Idaho
    2019 MGM Tacoma off road DCSB
  8. Feb 25, 2019 at 5:56 AM
    #128
    ramonortiz55
    Ramon
    Texas
    stock
  9. Feb 25, 2019 at 5:59 AM
    #129
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So reading the dual version on ARB it states it will run most air tools with an additional tank. So getting the dual also means your need an additional tank as well.
    Designed for inflating Tires and air locker activation when used in conjunction with optional accessories
    Suitable for many air tools when used in conjunction with a 4L air tank (optional with on-board models)
    100% duty cycle
    Sealed for moisture and dust resistance
    Hard anodized cylinder bores for reduced friction
  10. Feb 25, 2019 at 6:03 AM
    #130
    ramonortiz55
    Ramon
    Texas
    stock
    People run the dual without the tank.
    If you are using it to fill up tires, no need for a tank
  11. Feb 25, 2019 at 6:05 AM
    #131
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    But what about air tools?
  12. Feb 25, 2019 at 6:09 AM
    #132
    TsuiTaco
    TsuiTaco Member
    Jim
    Gardena CA
    10' DCSB 4x4 TRD OR
  13. Feb 25, 2019 at 6:37 AM
    #133
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Why do you need air tools? What are you bringing with you that a battery powered solution cant accomplish? Not poking fun, genuinely curious.
    I carry a Milwaukee M18 mid-torque impact with my twin. 600ft/lbs removal is more than enough for every bolt except the harmonic balancer. Even a small battery is enough to rotate several sets of tires.
    Milwaukee's high-torque has 1400 ft/lbs if you need more...
  14. Feb 25, 2019 at 6:43 AM
    #134
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    None actually, but when I asked about the difference in this thread it was stated the dual is if you want to run air tools. But if an additional tank is needed makes no sense to buy the dual is all. I'm just using it for airing up purposes.
    5678ta likes this.
  15. Feb 25, 2019 at 7:02 AM
    #135
    5678ta
    Hogan
    Henderson, NV
    So that is purely a volume equation. Most air tools are rated at consuming 3-6 CFM. The twin is rated for 6.1 CFM free flow(lower CFM under pressure) so you "could" almost continuously run lower consumption tools. The tank acts as a buffer to hold the pressure higher for longer period, giving the compressor a chance to kick on and maintain PSI. This also results in faster tire fills since you transfer high pressure air into low pressure vs trickle fill just above the tire PSI.
    But lets be honest, for purely airing up purposes, 20 seconds faster per tire is not worth the hassle, space, and plumbing of a tank. I went with a twin because my old shittybilt took 10 minutes to fill a tire in Colorado.
  16. Feb 25, 2019 at 7:07 AM
    #136
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    So honesty I could get away with the single mounted under the hood?
    5678ta likes this.
  17. Feb 25, 2019 at 8:30 AM
    #137
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    The single will do just fine airing up tires. The dual is just going to do it faster with theoretically less heat buildup. The benefit of the dual is being able to run low CFM air tools and redundancy if for some reason 1 of the 2 compressors dies.
  18. Feb 25, 2019 at 8:33 AM
    #138
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thank you going to just get the single and slee bracket for under the hood.
  19. Feb 25, 2019 at 10:19 AM
    #139
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Who else makes a bracket for mounting a single under the hood besides slee?
  20. Feb 25, 2019 at 10:28 AM
    #140
    BlueFox18
    BlueFox18 Well-Known Member
    Wade
    2018 Cavalry Blue Tacoma TRD Pro
