**CLOSED**BAKFlip & BAKbox Group buy 2.0 **2005 - 2016 TACOMAS!/TUNDRAS**
Discussion in 'Closed Group Buys' started by ramonortiz55, Nov 20, 2015.
  1. Feb 28, 2016 at 9:55 AM
    #1141
    Tacomadan79
    Tacomadan79 Active Member
    2016 trd sport dclb
    Finally installed my Fibermax yesterday. Was scared about the fit after reading all the posts from the other Bak thread on here. My cover fits perfectly. Either I got lucky, or they worked out all the issues. Very happy with my cover.
  2. Feb 28, 2016 at 10:32 AM
    #1142
    rfat3000
    rfat3000 Well-Known Member
    Rick
    Smithfield, VA
    2021 Limited Army Green
    I found my BakFlip HD leaked like crazy. After playing with it the water was coming in between the rail and the bed cap. The water was coming in through the 3 or 4 groves in the bed liner cap. I took them off today and applied a small bead of clear silicone to the bed cap and reinstalled the rail. It should take care of those pesky leaks.
    TacoTripn27 likes this.
  3. Mar 5, 2016 at 8:04 PM
    #1143
    MightyLordRay
    MightyLordRay Well-Known Member
    Brass fittings work like a charm fyi for anyone who wants to know...
    Thanks again LTacoman
    LTacoman likes this.
  4. Apr 9, 2016 at 7:09 AM
    #1144
    bwonger
    bwonger Unknown Member
    Brian
    Santa Barbara, CA
    2016 DCSB 4x4 OR Super White
    finally got mine on yesterday! How was everyone's water tests? Also, anyone get "dimpling" when tightening down the fasteners in the front left and right? I moved the weatherstrip to get it to lay flatter. Had light rain and a little water comes in basically at the 4 points where the bed caps are the 1/16th lower by design.
    Hartman and ramonortiz55[OP] like this.
  5. Apr 15, 2016 at 3:20 PM
    #1145
    bwonger
    Brian
    Santa Barbara, CA
    so did everyone get seals like this between side bed caps and the installed bak rail (red arrow)? i could have sworn people got replacements, but i've called BAK twice and they sent me a bulkhead strip and a replacement seal (green arrow) but nothing that would go where the red arrow points to....anyone?
    twogiraffe likes this.
  6. Apr 15, 2016 at 4:00 PM
    #1146
    LTacoman
    LTacoman Well-Known Member
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    Common, simple problem. Ok so I am going to try to explain this as best I can on what I did to get my rails to sit perfectly:
    if you look at your truck rail caps, you will see that they do not run completely 'flat' all the way to the tailgate, they 'taper inward' about 8" (or so) before the tailgate. if you remove the bak rail, you will see that the weatherstripping (indicated with red arrow) just runs parallel to the rail. This then makes the rail not sit flush on the bed cap, because if you look from the underside with a light, you will see that the weatherstrip goes up and gets smashed in between the tapered section (between bed cap and bak rail).
    Very simple solution: loosen adhesive and reposition weatherstripping on section that sits on the taper section of the bed cap. Essentially, if you are still looking at it from the same view as your red arrow pic, the weatherstrip should be moved to sit flush against the 90 degree edge of the bak rail (a little left), and therefore you will be able to move the rail to the right to sit flush against the bed cap (with weather stripping filling in the little corner gap). As long as you adjusted the weather stripping correctly along the taper area, this will in turn also allow the bak rail to sit perfectly flush on the bed cap.
    Seriously, just look at the whole thing from all angles (especially underside with a light) and you will see the 'problem' right away. Took me a little while to figure it out...
    Good luck!
    Edit: not sure if 8", just going off memory
  7. Apr 15, 2016 at 4:54 PM
    #1147
    bwonger
    Brian
    Santa Barbara, CA
    I did that, my rail sits flush as shown in first picture, however, quite a bit of water comes through, and not just at the tailgate and bulkhead where the holes are. I know tonneau's aren't waterproof but i believe i am getting a bit more water than others are. The second pic is from someone else on here, their seal seems different than the one i received.
  8. Apr 24, 2016 at 12:52 AM
    #1148
    bwonger
    Brian
    Santa Barbara, CA
    Did anyone that received the replacement seals decrease the amount of water getting into their truck beds?
  9. Apr 10, 2017 at 6:32 PM
    #1149
    FtApache
    FtApache Well-Known Member
    2019 Raptor
  10. Apr 10, 2017 at 6:35 PM
    #1150
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    yes, itll be late this month.
    FtApache[QUOTED] likes this.
  11. Apr 10, 2017 at 11:06 PM
    #1151
    Metonymy
    Metonymy Well-Known Member
    2017 White Tacoma TRD PRO
    None (yet)
    Yes! Just got my truck and I want a tonneau.
  12. Apr 11, 2017 at 12:00 AM
    #1152
    esses
    esses Well-Known Member
    2017 TRD Sport Double Cab, Long Bed, 4WD
    Toddler Car Seat and some cardboard boxes in the bed.
    Me three. sub'd
  13. Apr 11, 2017 at 5:22 AM
    #1153
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    I will definitely be in for a group buy on a G2 for my 2016 TRD Sport DCSB
  14. Apr 11, 2017 at 6:14 AM
    #1154
    southerntaco171
    southerntaco171 Well-Known Member
    Ocean Springs, MS
    2017 TRDOR
    2013 regular cab 4x4 Bilsteins Spc uca Eibach coils 285/75/r16 Projector retro 5500k hids 2017 TRDOR DC Weathertech Floor mats 5500k Morimotto Headlights and Fog lights 5% Tint 2008 Toyota Tacoma(SOLD) 8k Hid Headlights and fog lights, BHLM, 6" Pro Comp basic, 2.5" top spacer, Allpro front bumper, Jvc KVX10 double din, 2 crossfire bmf 12's, Memphis 6x9s, cherry bomb exhaust, K&N drop in intake,
  15. Apr 17, 2017 at 3:37 PM
    #1155
    ramonortiz55
    Ramon
    Texas
    stock
  16. Oct 20, 2019 at 7:01 PM
    #1156
    valeyellow46
    valeyellow46 Well-Known Member
    Christopher
    Tacoma SR5 Cavalry Blue
    I have the OEM bed mat too, what did you do with these drain tubes and the mat? Thanks!
