*CLOSED**BUSSMAN RTMR FUSE BOX GROUP BUY ENDS SEPT 30TH, 2015
Discussion in 'Closed Group Buys' started by ramonortiz55, Aug 17, 2015.
  1. Aug 25, 2015 at 4:57 PM
    #221
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Ramon,
    Now that I see the price...I'm still confused. Does this kit from Yotamac 10FT leads or 4FT leads? The 10FT leads is listed as $200, while the 4FT kit is $180. On your first post, you list it as 10FT cables, but then you said it's $180 for RTMR. If it is for 10FT leads @ $27 discount, that's $153, but the power cables is another $20. So it's $173...again is this for 4FT or 10FT?
    The ebay link I shown before...for $115 has this:
    • 3 Foot of wire for all Circuits. 8 AWG Battery Power, 14 AWG Ground (For Relay Triggers ONLY), 12 AWG Switched From Relay, 18 AWG Relay Coil Switch.
    • High Temperature Cross Linked TXL wire. Not standard Cheap Parts Store Hook Up Wire that will Melt when soldered!
    Power cables included, but only 3FT leads.
    So the only con is 3FT leads...kinda short....if this group buy is for 4FT leads...@ $173 vs $115...still not a good value. If it's 10FT and has the power cables and the raptor pro 180 main circuit breaker thrown in...then $173+ would make it a good deal. BTW, your previous comment the the EBAY didn't come with a mounting plate...the picture shows the mounting plate...so have to check with the seller if it's included.
    I'm just trying to compare apples to apples for this group buy. I don't mean to incite anger or frustration. I just want this to be a good group buy and entice more folks if the thing listed as a true package. What's the point of buying RTMR without the power cables? Thanks again for doing all this.
  2. Aug 25, 2015 at 6:44 PM
    #222
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Bought the one on eBay a while back cause I'm impatient lol. But the seller does offer support and included his email for answering any questions. Nice little package.
    On a side note I haven't heard back from Tacomapros/Yotamac on buying switchbacks seperately...I might just make my own :(
  3. Aug 25, 2015 at 6:46 PM
    #223
    JdevTac
    Josh
    MD/GA
    2nd gen
    The mounting plate is included from the seller on eBay, what everyone else is saying is that the eBay auction includes a GENERIC mount, whereas this groupbuy is for a CUSTOM bracket made specifically for our Tacomas, so no need to fab yourself a mount that is plug in play thru the groupbuy.
  4. Aug 25, 2015 at 7:56 PM
    #224
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Yes, you are right. It comes with a mounting bracket. Keep in mind, this is a generic mounting bracket that has not been proven to be installed on the Tacoma. Can you make it work? Maybe. That's your call.
    The bracket that this fuse box comes has been proven to work with 4runners and tacomas with no issues at all, at a common location, with factory holes already there. (same spot, but on driver's side, 3rd 4runner spot shown):
    There is a reason why the harness is only four feet long: There are two locations where you can locate switch panels, at the sunglasses holder and the pocket below the AC controls (with the @Iggy. panel).
    If you want your switches at the pocket below the AC controls, you will need a seven foot total wiring harness (four feet already included +3 feet, +$10).
    If you want your switches at the sunglasses holder, you will need a ten foot total wiring harness (four feet already included +6 feet, +$20).
    In regards to the circuit breaker:
    Why would you need a circuit breaker? Each circuit is already fused, no need to add a breaker to a fused system.
    Does your stock, OEM Tacoma fuse box have a circuit breaker from the factory?
    Nope.
    Then again, if you want one, that's your call :)
  5. Aug 25, 2015 at 7:58 PM
    #225
    ramonortiz55
    Ramon
    Texas
    stock
    If you are anxious, or are fabricator savy, then maybe Ebay is the way to go. If you don't want to make you're own bracket, or don't want to deal with finding the resources, then this group buy is for you.
  6. Aug 25, 2015 at 7:59 PM
    #226
    ramonortiz55
    Ramon
    Texas
    stock
    I wish I was fabricator savy, I have a lot of ideas for our Tacomas :)
  7. Aug 25, 2015 at 11:15 PM
    #227
    imom
    CAL
    2014 Regular Cab
    I wanted a main breaker for the oh crap or I need to shut down an entire section...main on/off switch. The ebay listing shows power cables included...this does not...it's another $20. Your original post still so 10 ft long wires...so what is it for the $180 -27 (discount) 10 ft wire or 4 ft wire? Again...there's the $20 for power cables from the RTMR to battery. Ebay listing shows it included. So the price is $173 vs $115.
    If the RTMR is installed in engine bay...I'm not sure if 4 ft wires is long enough.
    BTW the same raptor 140 main breaker that Yotamac sells for $30. It sells for less than $20 on Amazon and Ebay:
    http://www.amazon.com/RAPTOR-R5CB14...e=UTF8&qid=1440580690&sr=8-2&keywords=R5CB140
    And if you want an equivalent there are cheaper ones that sells for $9 shipped.
    http://www.ebay.com/itm/CNS-CB140-1...b07f180&pid=100005&rk=1&rkt=6&sd=320543251372
    So I don't get these 30% mark ups. It's supposed to be a group buy...where is the discount. If this is a business, you buy volume and then you sell making a profit, I get that, but if the competitor is selling much less for the price of one versus a group buy price...something isn't right.
    Ramon, I know you are helping creating all these group buys and I really appreciate it, but I see some problems I like to address, because I think these are fair questions.
  8. Aug 26, 2015 at 2:44 AM
    #228
    imom
    CAL
    2014 Regular Cab
    That's a definite value added...so the default then is to install in the engine bay. For most this would be okay and worth the extra charge because of the mounting. But then the price you pay, you still need to buy the extra $20 for the power wires that should be included in this RTMR. So you are still at $173 for the power wires and RTMR...but if you want to run all the 7 lead cabs into the cab, is 4ft enough to install say an amplifier under the seat? I say no...you need longer cables...so it's extra money. So if the group buy is for 10ft plus power cables and the custom mounting plate for $173 vs $115...it makes sense because the 10FT you can cut to length what you need per connection and the custom mount means no extra work.
    Personally myself, I want to install the RTMR in the cab somewhere, so I don't need that mounting plaet. The reason? Most of the electronics are inside the cab. Why should I try to run 5 times or 6 times the 7 lead cables through the firewall, when I can run just 1 fat 4 gauge or 0 gauge wire into the firewall and then have the 7 lead cables go where they may... 4ft maybe enough...it may not be even in the cab.
    So I like to know if this kit is for 10FT wire or 4 ft wire for the $180 - 27 discount price for RTMR?
  9. Aug 26, 2015 at 4:09 AM
    #229
    ramonortiz55
    Ramon
    Texas
    stock
    Per my last post, as mentioned, it is four feet.
    If you're going to mount the fuse box in the cab, then looks like the ebay box would be your best choice.
    I don't mind the questions at all, they're legit.
    Good luck bud. :)
  10. Aug 26, 2015 at 9:41 AM
    #230
    ramonortiz55
    Ramon
    Texas
    stock
    He made his own.
  11. Aug 26, 2015 at 10:37 AM
    #231
    JdevTac
    Josh
    MD/GA
    2nd gen
    I just received it the end of last week so haven't actually gotten around to install. That, and I am talking to Yotamac about switchbacks so I'd rather just do it all at once. I plan on installing a quick disconnect for the switch panel too.
    But yeah it's definitely going to be a custom mount of some sort. There's a few ways I could go about doing it but I haven't decided yet.
    The only thing I don't look forward to is routing the switch wires through the firewall.
  12. Aug 26, 2015 at 11:45 AM
    #232
    FarrDG
    FarrDG Member
    Pacific North West
    2008 Tacoma TRD Offroad Double Cab
    Sway-away Coilovers, All Pro overland springs, Tibetan bump stops and Fox shocks. Stainless still brake lines, u bold flip kit. FJ TRD wheels Cooper STT tires. Lear canopy with security screens for the shepherd and search and rescue equipment.
    I'm in for one. Please add me to the list. Thanks
  13. Aug 26, 2015 at 11:48 AM
    #233
    FarrDG
    FarrDG Member
    Pacific North West
    By the way is there a way to ask about switch backs for switches that fit into the empty switch slots that the Tacoma have? Thanks.
  14. Aug 26, 2015 at 12:00 PM
    #234
    ramonortiz55
    Ramon
    Texas
    stock
    I will add you.
    Any special requests can be placed with tacomapros when we start ordering.
  15. Aug 26, 2015 at 1:40 PM
    #235
    tacozord
    tacozord Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    You want a circuit breaker or fuse to protect the fuse/relay block to protect the overall box from an internal short or from combined overload. The Bussmann RTMR is rated at 80 amps. You have the potential to overload the internal busses if you exceed this amount. With five circuits, you could easily do this with five 20amp circuits.
    You're correct in saying that the OEM fuse block doesn't have a circuit breaker. However, it does have a fuse. In my Tacoma with the towing package, its rated at 140amps.
  16. Aug 26, 2015 at 2:10 PM
    #236
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    I plan to add an 80amp breaker before the relay just to be on the safe side of things. If the oem fuse panel starts a fire and makes my truck extra crispy then Toyota will be eating that but if my mod causes a fire or shorts out something its all on me.
    As for everyone price checking. anything that can be done to your truck will be cheaper if you spend the time to do it. hell you can buy leds and solder circuits together for a light bar. Its all about how hard you want to make the install vs how cheap. For me money has no value but my free time is priceless........and Im a broke ass SOB
    I will always choose professional quality over cheapest bid and 5x longer install time and headaches
  17. Aug 26, 2015 at 3:22 PM
    #237
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Yotamac Fuse panel + custom mounting plate =$153 free shipping
    Iggy switch plate = $ 38 free shipping. tacomapros switchbacks. =$ 30 vote for free shipping
    Total of =$ 221
    I will be fine spending this for a packaged GB but I do agree it's not a smoking deal.
    Free shipping will complete the GB in my opinion and if you buy everything like I am battery leads should be thrown in for free ;)
  18. Aug 26, 2015 at 3:28 PM
    #238
    ramonortiz55
    Ramon
    Texas
    stock
    You are correct.
    I need to get in touch with tacomapros and see how long they want to run the GB after the two weeks have expired.
    Then ill ask mods to post it on the front page.
  19. Aug 26, 2015 at 3:28 PM
    #239
    imom
    CAL
    2014 Regular Cab
    I'm leaning more towards my DIY. This way I have control of what I want (how far to run each connection). If I can find a RTMR that's smaller than the bussmann then I will...I found another littlefuse RTMR. That box maybe smaller. $50 is less than my time as well, but 4ft won't cut it for me if I have to mount it somewhere further away and not in the engine bay. I don't know how you guys/gals are going to route all those 7 leads times 5 into the cab and also still have enough wire. If you buy from the group buy, I suggest you pay more and get the 10FT version. This group buy is good for those who can't solder or have crimping tools.
    My plan is to then buy or wire it up myself and verify it on a bench. I use a bench power supply for the main power and verify each connection before you install everything. I'd reconsider if it was the 10FT version and came with the provide cables to the battery as well. So remove me from the list for now. Thank you.
  20. Aug 26, 2015 at 3:29 PM
    #240
    ramonortiz55
    Ramon
    Texas
    stock
    you may have a valid point here.
    the circuit breakers are to be installed at user's discretion :)
