*CLOSED**BUSSMAN RTMR FUSE BOX GROUP BUY ENDS SEPT 30TH, 2015
Discussion in 'Closed Group Buys' started by ramonortiz55, Aug 17, 2015.
  1. Aug 26, 2015 at 3:30 PM
    #241
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    I've been saying this all along...and extend it beyond 4ft....compromise even 7FT would be attractive
  2. Aug 26, 2015 at 3:31 PM
    #242
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    that's fine. not all of us need a switch plate, nor a custom tacoma specific panel. in that case, then the ebay special is what works. :)
    Ill make sure to remove you from the list.
  3. Aug 26, 2015 at 5:00 PM
    #243
    maurzog
    maurzog Well-Known Member
    I am interested, add me to the list.
  4. Aug 26, 2015 at 5:02 PM
    #244
    ramonortiz55
    Ramon
    Texas
    stock
    gotchu
  5. Aug 26, 2015 at 6:23 PM
    #245
    dctamcoa
    dctamcoa Well-Known Member
    Dan
    Tulsa, Oklahoma
    Double cab TRD
    Pelfreybilt front and High clearance rear bumper +3 lift on LT 285 75 16R Goodyear MT/R, All pro Apex rock sliders, bed rack with CVT Mt. Hood
    I know I want to get in on this so I'm in for Fuse panel + @@Yotamac mounting plate + @@Iggy. switch plate
    I'm not about the switch backs, the have to be used on air on board switches? Or something similar
  6. Aug 26, 2015 at 6:45 PM
    #246
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    I have no idea what you mean about on air on board switches?
  7. Aug 26, 2015 at 6:54 PM
    #247
    dctamcoa
    Dan
    Tulsa, Oklahoma
    Double cab TRD
    I saw them early in the post. Push button OEM Toyota style. I don't understand how those would work in panel. The rocker style I understand how that would work.
  8. Aug 26, 2015 at 6:58 PM
    #248
    dctamcoa
    Dan
    Tulsa, Oklahoma
    Double cab TRD
  9. Aug 26, 2015 at 7:05 PM
    #249
    imom
    CAL
    2014 Regular Cab
    I'm saying this:
    units 15.00% (-$27.00)+ free shipping + free battery leads + 7FT wire instead of (4ft)
    To reiterate basetaco's comments...but adding 3FT more wire length.
    But currently it's this:
    Myz250f likes this.
  10. Aug 26, 2015 at 7:14 PM
    #250
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Yeah they use your typical contura rocker switch...like what OTRATTW sells or air on board...NOT the push button switches. Just look in Iggy's groupbuy thread and you'll see pics...
  11. Aug 26, 2015 at 7:16 PM
    #251
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    I'm not sure the OEM style will fit .........help!
  12. Aug 26, 2015 at 7:20 PM
    #252
    JdevTac
    Josh
    MD/GA
    2nd gen
    ROCKERSSSSSSSSSSSS, not push button like the little tiny OEM ones under the HVAC....if you look at Iggy's groupbuy thread you can find plenty of pics to reference.
  13. Aug 26, 2015 at 7:20 PM
    #253
    dctamcoa
    Dan
    Tulsa, Oklahoma
    Double cab TRD
    Thanks, so I can plug the switch back right into is my understand?
  14. Aug 26, 2015 at 7:27 PM
    #254
    JdevTac
    Josh
    MD/GA
    2nd gen
    https://www.tacomaworld.com/threads/switch-panel-gb.352289/page-41
    Yes that is the idea...switch pops into the plate and then the switchbacks should be plug and play and mate with the switch body...I haven't looked at switch body diagrams on OTRATTW for example, but I do think the pin layout may change from switch body to switch body depending on how many LED's it has in it for illumination, I think all the other stuff like power (relay in and out) and ground for the actual switch stays the same. But idk you'd have to ask Iggy or Yotamac or someone.
    I think the original switchbacks were made with OTRATTW Contura V in mind.
    for example and comparison to see what im talking about:
    this -
    http://www.otrattw.com/wiring/KW66a.pdf
    vs this
    http://www.otrattw.com/wiring/A60.pdf
    EDIT: i'm guessing you'd have to specify what switches you are going for so they can add the jumpers appropriately based on the switch diagram.
  15. Aug 26, 2015 at 9:42 PM
    #255
    ramonortiz55
    Ramon
    Texas
    stock
    Hey guys, ill be gone on a four day weekend vacation.
    My access to TW will be limited.. ill be back on here 100% on monday.
    I'll answer all questions and update the list then.
  16. Aug 26, 2015 at 10:19 PM
    #256
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Put me on the list! :D
  17. Aug 27, 2015 at 9:51 AM
    #257
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Guys before this gets out of hand listen to @JdevTac
    I get all my switches from @OTRATTW (OTRATTW). Now each switch may be different depending on which type you get. The most common switch type is a SPST (Single Pole Single Throw) with a dependent lower light (meaning it's depending on the switch being on to be on) and independent upper light (meaning it takes power to be on from a separate source).
    This is what's a little tough when it comes to making these boxes in mass production and then supporting them. Since they are custom it takes a bit of homework to either know how the boxes come prewired, or how you want to wire your system.
    In regards to the eBay deal, there is always products that are cheaper. Like any business there are different costs associated with making something. Some have a higher overhead or margins to justify making a product. Even if they are the exact same thing they may be different price so take a look at the big picture and see what your getting to see if it's worth it to you.
    I can make these boxes for the same price as they eBay ones, but I can't offer support or custom models, which is what most are in need of, so it's not worth my time if guys are just going to get upset since they don't know what to do.
    Anyway, I didn't want to get into that part of the discussion and I hope this GB hits all it's numbers, but like anything thats electrical I highly recommend you draw a diagram ahead of time to know what you're going to need. Know what switches you're going to buy and see if they are compatible with the pigtails. If you don't even the cheapest box you can find will be expensive if it doesn't fit your needs.
    Joelev likes this.
  18. Aug 28, 2015 at 9:11 AM
    #258
    Yukon Yak
    Yukon Yak Well-Known Member
    Denis
    Whitehorse, Yukon Canada
    2015 TRD Access Cab Trails Team
    BFG KO2 285/75R16 OME 886/Dakars Rotopax Pelfreybilt Aluminum Front/Rear HC with gate Dual Batteries Rigid fogs, 20 inch spot/flood, SQR back up Cobra 75, 3' fire stick Custom Storage/Dog Platform in Cab Allpro Apex sliders Allpro Apex Aluminium Pack Rack Allpro Aluminium Gear Rack
    impeccable timing
    Sign me up
  19. Aug 28, 2015 at 9:33 AM
    #259
    ramonortiz55
    Ramon
    Texas
    stock
    haha okay bud.
  20. Aug 29, 2015 at 10:00 AM
    #260
    ramonortiz55
    Ramon
    Texas
    stock
    to da top!
