*CLOSED**BUSSMAN RTMR FUSE BOX GROUP BUY ENDS SEPT 30TH, 2015
Discussion in 'Closed Group Buys' started by ramonortiz55, Aug 17, 2015.
  1. Oct 27, 2015 at 6:29 AM
    #1081
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    but you said theyre not strict?:annoyed:
  2. Oct 27, 2015 at 6:57 AM
    #1082
    HBGIBBY
    HBGIBBY Well-Known Member
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
    oh well, I'm sure they won't be afraid of that camper shell and that pose! nice stain job though!
  3. Oct 27, 2015 at 8:15 AM
    #1083
    Myz250f
    Myz250f Well-Known Member
    daniel
    New York
    exhaust, headlight bulbs, k&n intake, programer, toytec boss front coil overs, toytec boss rear shocks, sway bar relocation, Dakar leaf pak, oc taco extended stainless steel break lines (red), kicker component front speakers, kicker 2 way rear speakers, pioneer head unit, mtx thunder amp, reverse light bulbs
    @Russtoy
    for the warn power interrupter.
    from the rocker switch. do you just have to wire up the 18 gauge wire that comes in the kit to the switch? seems like a pretty simple setup!
    just trying to figure out how this wires up to the switch.
  4. Oct 27, 2015 at 9:57 AM
    #1084
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    Yes sir...run the yellow to the switch inside the cab, then run power to the switch and ground it. Very very easy to do. You don't have anything to worry about...the kit comes with directions which are very easy to follow...it has both text and pictures. Heck I just looked up the directions...here's the part your asking about....
    1. Route the yellow wire from the switch location through the fire wall to the Power Interrupt solenoid. Protect the wire where it passes through the fire wall by routing it through a grommet or similar protective device. Route the spade connector through the switch bracket and plate and
    push onto the #1 Power Interrupt switch terminal. Slip a small rubber wire boot over the wire eyelet and secure the eyelet to the small, right side post of the solenoid with the outer nut and lock washer from the post. Tighten the nut and push the boot over the solenoid post.
    2. Route the red, fused wire from the switch location to a suitable switched, "hot" wire from the ignition switch. Route the spade connector through the switch bracket and plate and push onto the #2 Power Interrupt switch terminal. Splice the wire end into the "hot" wire with the snap lock connector provided.
    3. Route the black wire from the switch location to a suitable, metal ground under the dash. Route the spade connector through the switch bracket and plate and push onto the #3 Power Interrupt switch..."
    Here's the link to the directions...
    http://www.gowarn.com/aux_incl/pdf.ashx?pdf=WAR_62132_INS_1.pdf&line=WAR
    IIRC the kit was like $65 shipped. It had everything in it that you'll need. Although the actual switch and wire connectors were cheap Chinese garbage! I used my own connectors and switch...then always use shrink tubing and dielectric grease (that's just me).
    The switch they sent was probably OK. But I wanted
    something nice looking and match my other switches.
    This is the switch that I ordered.
    I hope this helped you @Myz250f !!! To me you can't beat it. Save you from having to worry about people messing with your winch and it'll save dead batteries! Win..Win!!
    - Russel
    Myz250f[QUOTED] likes this.
  5. Oct 27, 2015 at 10:01 AM
    #1085
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    Hahahahahaha......who's laughing now!!! Hahahahahaha.....
  6. Oct 27, 2015 at 10:05 AM
    #1086
    Myz250f
    daniel
    New York
    awesome man thanks foe the help. just ordered one! and a bunch of switches!!
    also I live in ny.
    (everything rusts in ny) hard winters and lots of road salt. any ideas on how to protect this from the weather?
  7. Oct 27, 2015 at 2:49 PM
    #1087
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    I'm right there with you buddy...living here in Ohio. The amount of salt and and salt-water (brine) they put on the road is just crazy. Wish people would just learn to drive on snowy roads. Look at the amount of money the cities and states would save not buying salt or brine. Then the amount of money we'd save on rust saving aids with our vehicles...anyway.
    It depends on what the item is and how much salt spray it will receive. Like my winch and winch calbe I'll spray with Amsoil HD metal protector. Covers whatever you spray in a clear coating that stays where it was sprayed and protects that item from salt/water...so it won't rust. Electrical items and more delicate items...I'll spray with Amsoil MP lubercate (Amsoil version of WD-40)
    http://www.amsoil.com/shop/by-produ...nts/heavy-duty-metal-protector/?code=AMHSC-EA
    http://www.amsoil.com/shop/by-produ...protectants/mp-metal-protector/?code=AMPSC-EA
    You can look them up and see what Amsoil said you should use them on and how to use them. I'm sure there're cheaper products available...I use Amsoil in all my vehicles and have slowly started using all their products. However, I still use WD-40 a lot. It's a very good product.
  8. Oct 27, 2015 at 4:50 PM
    #1088
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    BYJOSHCOOK likes this.
  9. Oct 27, 2015 at 4:56 PM
    #1089
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Payment just sent :D
  10. Oct 27, 2015 at 4:59 PM
    #1090
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    I got 2
  11. Oct 27, 2015 at 5:00 PM
    #1091
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    Thanks Josh, We just missed it for today. It will go out first thing in the morning.
  12. Oct 27, 2015 at 5:03 PM
    #1092
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
  13. Oct 27, 2015 at 5:04 PM
    #1093
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Not a big deal, got paid last week and meant to pay the rest, but I guess I figured it'd be a while before mined shipped. But obviously you've been busy haha
    Yotamac[QUOTED] likes this.
  14. Oct 27, 2015 at 5:08 PM
    #1094
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    Oh man Im soo sorry, I'll mail you some tomorrow.
    I must have just missed it. So sorry Russel!
  15. Oct 27, 2015 at 5:47 PM
    #1095
    ramonortiz55
    Ramon
    Texas
    stock
    noo... @Russtoy isn't part of the secret squirrel society.
    @HBGIBBY tell him!
  16. Oct 27, 2015 at 5:48 PM
    #1096
    ramonortiz55
    Ramon
    Texas
    stock
    :annoyed:
  17. Oct 27, 2015 at 5:49 PM
    #1097
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    SSS 4 life MFer
  18. Oct 27, 2015 at 5:50 PM
    #1098
    WhiteWalkerTaco
    WhiteWalkerTaco Well-Known Member
    Justin
    Denver, CO
    2015 White Tacoma TRD Off-road
    WOOOO I might be in the next shipment! :broccoli::dancingbacon::bananadance:
  19. Oct 27, 2015 at 5:59 PM
    #1099
    HBGIBBY
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
    @Russtoy great to see you last month at the annual SSS convention!
  20. Oct 27, 2015 at 6:07 PM
    #1100
    ramonortiz55
    Ramon
    Texas
    stock
