*CLOSED**BUSSMAN RTMR FUSE BOX GROUP BUY ENDS SEPT 30TH, 2015
Discussion in 'Closed Group Buys' started by ramonortiz55, Aug 17, 2015.
  1. Nov 4, 2015 at 4:50 PM
    #1221
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  2. Nov 4, 2015 at 4:55 PM
    #1222
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    Yup they are in there.
  3. Nov 4, 2015 at 4:58 PM
    #1223
    ramonortiz55
    Ramon
    Texas
    stock
    SUCKASSS!!!! I am a member of the SSS!!!
  4. Nov 4, 2015 at 5:13 PM
    #1224
    WhiteWalkerTaco
    WhiteWalkerTaco Well-Known Member
    Justin
    Denver, CO
    2015 White Tacoma TRD Off-road
    WHAT?! I thought you already got your order and didn't get stickers. I want mine back! :angrygirl:
  5. Nov 4, 2015 at 5:14 PM
    #1225
    ramonortiz55
    Ramon
    Texas
    stock
    :anonymous:
  6. Nov 4, 2015 at 5:15 PM
    #1226
    WhiteWalkerTaco
    Justin
    Denver, CO
    haha
  7. Nov 4, 2015 at 5:23 PM
    #1227
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
  8. Nov 4, 2015 at 6:14 PM
    #1228
    Red Demon
    Red Demon Well-Known Member
    Vinnie
    Kennett Missouri
    07 SR5 4x4
    Tinted windows Upgrade to New 2014 radio Weather Tech Front Lift:2.5 ICON Extended Travel Coilover Shocks Icon Uni Ball Tubular UCA Rear Lift: Icon 1.5" AAL ICON 2.0 Aluminum Series Rear Shock Relentless Front Bumper Relentless Rear Bumper SOS Sliders and skid plate
    Should have made him wait ,I'm thinking last :boink:
  9. Nov 5, 2015 at 9:43 AM
    #1229
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    You didn't get the memo...cause you're not a member yet: but we dissolved the SSS. Sorry, your too late.......LOSER!!!!!!!:rofl::infantry:
    4x4Taco09 likes this.
  10. Nov 5, 2015 at 9:44 AM
    #1230
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
  11. Nov 5, 2015 at 1:12 PM
    #1231
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    question for @Yotamac or you other guys that might know. If you've used up all the relays in the box, but have a wiring harness with a relay already included (think rigid wiring harness or something similar), can you just wire that to one of the fused connections?
    Accessorry --> Relay included in wiring harness --> Fused input in Bussman (F7-F10) --> In-cab switch
    I'm wondering because I'll already have the bussman wires going into the cab to switches, so it would be easier to just run everything to the box as I add new accessories. Let me know if that wasn't clear enough to understand.
  12. Nov 5, 2015 at 1:31 PM
    #1232
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That's what I plan on doing: lights with the relay to the box which then goes to the switch.
    The lights I already have have a relay so I'm going to use up the non-relayed spot first
  13. Nov 5, 2015 at 1:42 PM
    #1233
    Mcdees84
    Tallahassee, FL
    Any idea on fuse size to tap into then? Just the smallest fuse?
  14. Nov 5, 2015 at 1:45 PM
    #1234
    BYJOSHCOOK
    Josh
    Check Out My Builds
    If my electrical background serves me right (I don't have one) you take your watts of the lights and divide it by something to get the correct relay :notsure:
    Mcdees84[QUOTED] likes this.
  15. Nov 5, 2015 at 1:47 PM
    #1235
    Mcdees84
    Tallahassee, FL
    hahaha! You take something and divide it by something else and you arrive at something. Got it! ;)
  16. Nov 5, 2015 at 1:51 PM
    #1236
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I'd do a quick Google search tbh, I did it earlier but have since forgot....
  17. Nov 5, 2015 at 1:53 PM
    #1237
    Mcdees84
    Tallahassee, FL
    No worries man...it just made me laugh when I read it. Hopefully some other guys chime in.
  18. Nov 5, 2015 at 2:01 PM
    #1238
    ramonortiz55
    Ramon
    Texas
    stock
    Watts divided by volts ..volts in our case is 12 volts. that would give us the amperage
    Mcdees84 and BYJOSHCOOK like this.
  19. Nov 5, 2015 at 2:03 PM
    #1239
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Told you! @Mcdees84 you divide watts by something! :thumbsup:
  20. Nov 5, 2015 at 2:10 PM
    #1240
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    Yes, you can use power through the fuse block for and external relay. The wires going into the cab only power the relays in the RTMR. F7-F10 can be considered a simple terminal block with outgoing leads. You will have to run the additional wires into the cab for the additional switches and/or relays. They are constant hot and always energized when the fuse is in.
