**CLOSED** Bussman RTMR group buy 2.0
Discussion in 'Closed Group Buys' started by ramonortiz55, Jun 25, 2016.
  1. Jun 25, 2016 at 7:37 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Closed
    It's been awhile since we did the last one, a few T4R.org guys have been asking me for another round of the Bussman RTMR group buy and the vendor has had a few requests.
    Previous thread - https://www.tacomaworld.com/threads...use-box-group-buy-ends-sept-30th-2015.387403/
    Let's do round two!
    Tacomapros, a TW vendor, has agreed to let me host a group buy for his boxes!
    Here is what is going on:
    http://www.tacomapros.com/electronical-bussmann-rtmr/
    **Mandatory Description**
    The Bussman RTMR Fuse and Relay boxes offer a convenient and compact solution for auxiliary electrical accessories such at lighting. We did the hard work and prewired these fuse/relay boxes for an easy solution to complicated wiring.
    These RTMR boxes are water resistant with rubber seals.
    They come with 5 relayed and 4/5 fused leads. 1 power input stud and 1 ground stud for easy hook up.
    Kit includes:
    1 - Universal mounting plate
    5 - Relays
    10 - Standard Fuses
    4 ft long - color coded single cable with a 7 lead pin. This allows for 5 or 6 switches with a power lead for switch illumination
    All leads are color coded for easy traceability
    This box will simplify wiring all your aftermarket accessories to ONE waterproof stock looking box. These are sturdy and very clean looking.
    Need a install write up? I created one a few months ago using a similar setup sourced from another provider. I am an owner of a very similar fuse box and can answer questions in regards to installation. - 3rd gen 4runner and second gen Tacoma
    This is my install writeup:
    https://www.tacomaworld.com/threads/auxiliary-fuse-box-install-skygear-box-pictures.377085/
    Keep in mind, I did the install on a 2001 4runner.
    The installation for the tacoma is similar except you can mount the box on the drivers side and not have to relocate anything.
    So what's the discount?
    - MSRP - $180
    In order to prevent huge lead times, I propose the following.
    To order in batches of 5 or 10 at a time, unless tacomapros tells me otherwise. To make sure everyone gets their box in timely manner once they've provided funds.
    So once you're on the list.. that's your number until the group buy is finished :D
    The purchase order will be respected throughout the group buy, unless two members agree to switch spots. The agreement must be done via GROUP PM with me AND tacomapros.
    If you are interested in this:
    Sign up by replying to this thread. Don’t chicken out. You are either in or you aren’t. NO maybe, no waiting on the wife, gf or bf to get permission. There is enough time to make up your mind or find a doctor to sell your kidney or pawn your wife’s jewelry. If you are on the fence to see if it’ll go up to 15% before you jump in, you are HOLDING the group buy back. Don’t be that dude.
    greeneggsnspam likes this.
  2. Jun 25, 2016 at 7:38 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Wiring Diagram:
    What it looks like underneath - Colors may not exactly match diagram -
  3. Jun 25, 2016 at 7:38 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Saved for shenanigans
  4. Jun 25, 2016 at 7:38 AM
    ramonortiz55
    Ramon
    Texas
    stock
    List:
    1. @MYT4CO
    2. russtoy (T4R.org)
    3. hawaiianeyz (T4R.org)
    4. Mighty Buffalo (T4R.org)
    5. @OBXPaul
    6. @Krusetj
    7. @LunaticConcepts
    8. @seank (T4R.org)
    9. 4Rnewbie (T4R.org)
    10. Anonymous (T4R.org)
    11. DirtyDanno (T4R.org)
    12. Tucson4runner (T4R.org)
  5. Jun 25, 2016 at 7:40 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  6. Jun 25, 2016 at 7:41 AM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    In for one for the taco. I'll need longer leads for the switch backs as mine will be in the overhead console:thumbsup:
  7. Jun 25, 2016 at 7:42 AM
    ramonortiz55
    Ramon
    Texas
    stock
    will do, ill add you :)
    Ugly Betty[QUOTED] likes this.
  8. Jun 25, 2016 at 7:42 AM
    ramonortiz55
    Ramon
    Texas
    stock
  9. Jun 25, 2016 at 7:42 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Thank you
  10. Jun 25, 2016 at 7:44 AM
    Ugly Betty
    mark
    TX
    Is iggy in on this one again, I should get one of his plates just in case:cool:
  11. Jun 25, 2016 at 7:49 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I am working on it
  12. Jun 25, 2016 at 10:09 AM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    We can do just like version 1!
    Let me get pricing for you all.
    Ugly Betty likes this.
  13. Jun 25, 2016 at 10:14 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Put me down for one.
    OP, check your link for the write-up.
  14. Jun 25, 2016 at 10:14 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Install write up link leads to your picture gallery, not a thread. Dummy.
    Unchained 5150 likes this.
  15. Jun 25, 2016 at 10:18 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    MO NI CA
    AR15xAR10[QUOTED] likes this.
  16. Jun 25, 2016 at 12:23 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Im in put me down
  17. Jun 25, 2016 at 1:12 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I just finished building and mounting my RTMR for the first gen using the basic TP first gen plate.
  18. Jun 26, 2016 at 6:29 PM
    Ugly Betty
    mark
    TX
  19. Jun 27, 2016 at 6:46 AM
    ramonortiz55
    Ramon
    Texas
    stock
  20. Jun 27, 2016 at 10:57 AM
    ramonortiz55
    Ramon
    Texas
    stock
    i make you regret purchases
