CLOSED Group Buy for MorrFlate Inflator CLOSED
Discussion in 'Automotive Group Buys' started by Unchained 5150, Aug 19, 2020.
  1. Sep 5, 2020 at 4:03 PM
    #121
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Rick,
    I was obviously lazy the first time I hit the site. I just found this:
    "The Haltec air chucks default closed (they won’t let air out when pressurized). They have 3 lock-on-teeth to lock onto your valve stems (no more air chucks coming loose and leaking air!). The teeth don’t engage until you engage the locking collar, which helps your valve stems and the Haltec teeth last longer. To pull them off, just pull the locking collar away from the valve steam, thus releasing the teeth and the air chuck all in one swift, easy movement."
    These are the easier to use better chucks.
    6 gearT444E likes this.
  2. Sep 5, 2020 at 4:06 PM
    #122
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    No worries you in now?
    CttAznRanger and RobP62[QUOTED] like this.
  3. Sep 5, 2020 at 4:26 PM
    #123
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Gonna make him in.
  4. Sep 5, 2020 at 5:20 PM
    #124
    jtvitangcol
    jtvitangcol Well-Known Member
    Socal
    2018 DCSB cement OR
    When we expecting invoices
    nudavinci64 and RobP62 like this.
  5. Sep 5, 2020 at 5:30 PM
    #125
    Unchained 5150
    Rick
    Auburn Ma
    I just reached out to ask him that
    RobP62 likes this.
  6. Sep 5, 2020 at 5:32 PM
    #126
    jtvitangcol
    Socal
    2018 DCSB cement OR
    Ok thanks OP. Appreciate you running this been eyeing these for a while
    RobP62 and Unchained 5150[OP] like this.
  7. Sep 5, 2020 at 5:49 PM
    #127
    Unchained 5150
    Rick
    Auburn Ma
    Long weekend so maybe Tuesday
    RobP62 likes this.
  8. Sep 6, 2020 at 6:39 AM
    #128
    Unchained 5150
    Rick
    Auburn Ma
    We are at 23 peeps
    RobP62 and thebaker like this.
  9. Sep 6, 2020 at 2:53 PM
    #129
    Bigdaddy4760
    Maner
    Poolville Texas
    I'm in. Thanks
    RobP62 likes this.
  10. Sep 6, 2020 at 2:54 PM
    #130
    Unchained 5150
    Rick
    Auburn Ma
    24 now sweet
    RobP62 and Bigdaddy4760 like this.
  11. Sep 6, 2020 at 4:50 PM
    #131
    Unchained 5150
    Rick
    Auburn Ma
    Group message sent to all of you, and thank you very much for getting in on this my friends.
  12. Sep 7, 2020 at 6:03 AM
    #132
    Unchained 5150
    Rick
    Auburn Ma
    More good news it does not normally come with the Digital Gauge but in this Group Buy they are including it as well.
    RobP62, BeLance89, jaydemSR5 and 5 others like this.
  13. Sep 7, 2020 at 6:19 AM
    #133
    Bigdaddy4760
    Maner
    Poolville Texas
    That's great
    RobP62 likes this.
  14. Sep 7, 2020 at 6:30 AM
    #134
    Unchained 5150
    Rick
    Auburn Ma
    Yup savings of $25.00
    RobP62 and Bigdaddy4760[QUOTED] like this.
  15. Sep 7, 2020 at 6:35 AM
    #135
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Sign me up for the 4 tire kit.
  16. Sep 7, 2020 at 6:38 AM
    #136
    Justwandering
    Justwandering Well-Known Member
    1996 Land Cruiser, 2008 GX470
    You da man!
  17. Sep 7, 2020 at 3:12 PM
    #137
    Sierra Trail Pro
    Sierra Trail Pro The more I play with it, the Bigger it gets!
    Kelly
    Cameron Park, CA
    2020 TRD Pro, Magnetic Grey Metallic
    Upgraded REM Polished 5.29 Revolution Gears Dobinsons 2.5 MRA/MMR adjustable remote reservoir front coilovers w/732lb springs, 35x12.5 BFG KM3 MTA tires on Moto Metal 16" wheels, incl. full size spare Bushmaster bolt on wheel well flares CaliLED full cab length DOM Steel Rock Sliders w/kickouts, Total Chaos welded spindle gussets, & LCA Cam Tab Gussets, Welded "Runnin 4 Tacos" Cab Mount Relocation Bracket, C4 Fabrication front steel hybrid bumper incl. heavy duty steel bumper support add-on's, C4 Fab Rear overland high rise steel bumper w/steel rear qtr panel wrap armor and side tube upgrades, 12k Smittybilt XRC Pro Comp Winch w/Factor 55 Flatlink Expert shackle mount assembly, Dobinsons heavy duty rear leaf spring pack, Timbren Off Road Racing bump stops (F&R), Fox 2.5 TRD Pro OEM rear monotube shocks, OEM Factory TRD Pro front aluminum skid RCI Steel skid plates (tucked in to factory engine skid)@ transmission, transfer case, lower A arms, and rear diff; CBI steel gas tank skid, ARB Twin Compressor in an M.O.R.E. engine bay mount, ARB Front Air Locker w/ Stainless Steel Air Lines Diode Dynamics 30" LED light bar @front bumper, RIGID front fog lights tied into factory wiring harness, Odyssey Group 31 AGM battery in a CBI Steel battery tray, Decked Slide-Out lockable Bed Drawer System, Yaesu FTM-400XDR HAM Radio (c/s:K6TOY), FreeSpirit Recreation "Evolution" Aluminum Hard Shell RTT w/Accessory Rails X2, FreeSpirit Recreation 270 Degree Swing-Out Self Supporting Awning w/Tent Mount Brackets, Cab Rack Mounted shower/changing tent, CBI corner to corner Steel Full Bed Rack, Prinsu Cab Rack w/extra rails, UpTop Overland upTAKE Snorkel (Functional & self draining), iPOD Bantam X touch screen switch panel control module, Dometic CFX3 95DZ Dual Zone Electric Refrigerator/Freezer w/dedicated electrical circuit & outlet, Dometic Refrigerator Slider Bed Mount, (4) 4 Gal Roto Pax Gas Cans w/locking Bed Rack Mount, MaxTrax Extreme Recovery Boards w/locking bed rack mount, Valley Runner custom ECU tune, TRD Advanced Cold Air Intake, Escort Radar Detector, hard wired w/RVM mount ALL K&N cleanable filter media installed, Only use Mobile One Full Synthetic Oil, changed every 5K miles, All Major Mods Professionally Installed
    Thank you very much for setting up this group buy for us!
  18. Sep 7, 2020 at 3:35 PM
    #138
    Unchained 5150
    Rick
    Auburn Ma
    Thank you for participating
  19. Sep 7, 2020 at 3:36 PM
    #139
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    From what I read the + is just longer, correct?
    RobP62 and JasonT87 like this.
  20. Sep 7, 2020 at 3:37 PM
    #140
    Unchained 5150
    Rick
    Auburn Ma
    Correct
    RobP62 likes this.
