**CLOSED** Group buy - Iggy LED light bars!
Discussion in 'Closed Group Buys' started by ramonortiz55, Sep 18, 2016.
  1. Oct 6, 2016 at 7:56 PM
    #481
    trekker
    trekker I like tacos
    Brandon
    Pocatello, ID
    '14 DCSB TRD OR MGM
    floor mats and a beer switch
    Thanks Mike
    KRAMERICA[QUOTED] likes this.
  2. Oct 6, 2016 at 7:58 PM
    #482
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Oct 6, 2016 at 8:02 PM
    #483
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    :anonymous:
    Damnit you made me get out a calculator. NO it's a 100Watts! Still only 3 or 4 amps, that being the more important number for fuses and wiring.
    trekker[QUOTED] likes this.
  4. Oct 6, 2016 at 8:03 PM
    #484
    T4RFTMFW
  5. Oct 6, 2016 at 8:04 PM
    #485
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    This is just not true. If it's 100W and you run it off a 12V system the amps are 100/12=8.3A. I'm not sure the estimate of 100W is correct either. Better have @Iggy. confirm
  6. Oct 6, 2016 at 8:12 PM
    #486
    trekker
    Brandon
    Pocatello, ID
    '14 DCSB TRD OR MGM
    I thought so but wasn't totally sure how many chips are in the bar. Thanks guys for your input I'll wait for @Iggy to chime in.
  7. Oct 6, 2016 at 8:14 PM
    #487
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    That could be, hopefully iggy can confirm. I can't find the spec sheet but have a 20" 126w on my truck now, and as poor as my memory is serving me right now. I think it's only drawing 4Amps. But it's obviously past my bed time... :facepalm:
  8. Oct 6, 2016 at 8:18 PM
    #488
    mountainmonkey
    Colorado
    Never enough
    You are either off on your recollection of your lights wattage or the amperage, the math just doesn't add up. Wattage equals voltage (usually ~12V in automotive applications) times the amperage. Or conversely, amperage equals wattage divided by voltage.
  9. Oct 6, 2016 at 8:20 PM
    #489
    trekker
    Brandon
    Pocatello, ID
    '14 DCSB TRD OR MGM
    @mountainmonkey has the right equation dividing wattage by voltage equals amperage so 4 amps at 12 volts would yield 48 watts max. If you've got your bar on a 4 amp fuse you might try a 10 amp fuse to get close to max wattage and brightness... at least that's how I think it works lol :cheers:
  10. Oct 6, 2016 at 8:23 PM
    #490
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I'm definitely going to have to check my fuse panel to see what I put in there. All I can say for certain is I haven't popped the fuse yet... :fingerscrossed:
  11. Oct 6, 2016 at 8:26 PM
    #491
    mountainmonkey
    Colorado
    Never enough
    Just remember that too large a fuse is as bad as a fuse that's too small. For lighting applications a general rule of thumb is to have the fuse rated at ~125% of the total rated amperage of all the lights on the circuit.
    trekker likes this.
  12. Oct 6, 2016 at 8:48 PM
    #492
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    @ramonortiz55
    I just purchased a 20" Single Row Lightbar on Iggy's site :thumbsup:
    303tacoma and ramonortiz55[OP] like this.
  13. Oct 6, 2016 at 8:57 PM
    #493
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Sorry I missed all that about the watts.
    The 20 single row is 100w and needs 6.7A to achieve max lumens.
  14. Oct 7, 2016 at 2:37 PM
    #494
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    ordered/paid for 40w diffused pods. thanks for group buy!
    Iggy likes this.
  15. Oct 7, 2016 at 6:20 PM
    #495
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    added
  16. Oct 8, 2016 at 1:58 PM
    #496
    jgantzler
    jgantzler Well-Known Member
    Jeremy
    Mounting hardware is around 8 mm if I remember right, they come with the 8 bolts you need, a rubber gasket to go between the light and bumper. As far as matching up to your existing cut outs, that I cannot answer.
    mtbkr[QUOTED] likes this.
  17. Oct 9, 2016 at 6:41 PM
    #497
    ramonortiz55
    Ramon
    Texas
    stock
    this closes tomorrow
    CharlieCafe and 303tacoma like this.
  18. Oct 9, 2016 at 7:20 PM
    #498
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    Any specific time?
  19. Oct 9, 2016 at 7:26 PM
    #499
    ramonortiz55
    Ramon
    Texas
    stock
    midnight
  20. Oct 10, 2016 at 9:12 AM
    #500
    mtbkr
    mtbkr Well-Known Member
    Allan
    Spring, TX
    2014 Super White DCSB SR5 4x4
    modifying my truck one group buy at a time
    I tried using the code and it says,
    Warning: Coupon is either invalid, expired or reached its usage limit!
