**CLOSED**GROUP BUY**NORTHSTAR DEEP CYCLE BATTERIES**
Discussion in 'Closed Group Buys' started by ramonortiz55, Nov 11, 2015.
  1. Dec 14, 2015 at 5:31 AM
    #261
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    I believe Northstar is private labeling Drakon, Exide (Pure Lead Ultra High Performance) and X2 Power.
  2. Dec 14, 2015 at 8:36 AM
    #262
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What does that mean
  3. Dec 14, 2015 at 12:13 PM
    #263
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  4. Dec 14, 2015 at 5:12 PM
    #264
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Peter it means that Northstar is the battery manufacturer and the others are labeled with their private branding. It is like Odyssey makes DieHard Platinum and Stinger batteries.
    OZ-T[QUOTED] likes this.
  5. Dec 14, 2015 at 8:01 PM
    #265
    OZ-T
    Peter North
    British Columbia
    I C
    Apparently they do the Motomaster Eliminator series for Canadian Tire too
  6. Dec 15, 2015 at 6:30 AM
    #266
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Peter, many thanks for the info. I will add it to the Lead-Acid Battery Manufacturers and Brand Names List on www.batteryfaq.org.
  7. Dec 15, 2015 at 1:34 PM
    #267
    ramonortiz55
    Ramon
    Texas
    stock
  8. Dec 15, 2015 at 5:44 PM
    #268
    dctamcoa
    dctamcoa Well-Known Member
    Dan
    Tulsa, Oklahoma
    Double cab TRD
    Pelfreybilt front and High clearance rear bumper +3 lift on LT 285 75 16R Goodyear MT/R, All pro Apex rock sliders, bed rack with CVT Mt. Hood
    I'm in if the 34/78 is on this group buy. I'm still not sure what is the difference is in the 34/78 F ?
    I thought I saw a page on this post that the other battery sizes are in. If not never mind.
  9. Dec 15, 2015 at 9:25 PM
    #269
    CBiscuit14
    CBiscuit14 Professional Lurker
    South Dakota
    08 DC TRD Sport 4X4
    I do need a new battery soon.... Subbing while I do some research!
  10. Dec 15, 2015 at 9:29 PM
    #270
    ramonortiz55
    Ramon
    Texas
    stock
    :D
  11. Dec 16, 2015 at 11:00 AM
    #271
    ramonortiz55
    Ramon
    Texas
    stock
  12. Dec 17, 2015 at 7:10 AM
    #272
    ramonortiz55
    Ramon
    Texas
    stock
  13. Dec 17, 2015 at 9:10 AM
    #273
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Everyone whose battery is close to being out of warranty or feels/knows its losing its cold cranking amps should buy one and keep it stored at room temp off the ground and it still should be ready to go your battery goes bad. A good battery is a good investment and every Tacoma should come stock with a quality agm battery like an Odyssey or Northstar! Treat yourself to it TW members, you won't regret it. Just return/sell those crappy Christmas gifts for one!
  14. Dec 17, 2015 at 9:28 AM
    #274
    ramonortiz55
    Ramon
    Texas
    stock
    done!
  15. Dec 17, 2015 at 8:11 PM
    #275
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  16. Dec 17, 2015 at 8:24 PM
    #276
    ramonortiz55
    Ramon
    Texas
    stock
    do ettt
  17. Dec 17, 2015 at 8:35 PM
    #277
    Digiratus
    Roaming the PNW
    The RedHead
    :fingerscrossed:
  18. Dec 18, 2015 at 5:59 AM
    #278
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    With all due respect, the only thing worse than storing a wet or AGM battery at room temperature is storing it above room temperature or below 20 degrees F. The reason is because a battery is an electrochemical device and has a natural self-discharge rate which is affected by temperature and battery type (plate chemistry). Increased temperatures create greater self-discharge rates which intensifies lead sulfate formation on the plates and can cause sulfation. Temperatures below 20 degrees will freeze fully discharged wet batteries and can damage them. Keeping the battery fully charged (recommended) or periodically recharging will prevent sulfation in storage. For more information, see Sections 7.6, 13 and 16 in the Car and Deep Cycle Battery FAQ.
  19. Dec 18, 2015 at 9:49 AM
    #279
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    There is nothing worse than that.
    Nothing...
    worse..
    ..than that.
  20. Dec 18, 2015 at 9:50 AM
    #280
    ramonortiz55
    Ramon
    Texas
    stock
    are you sure?
