**CLOSED**GROUP BUY**NORTHSTAR DEEP CYCLE BATTERIES**
Discussion in 'Closed Group Buys' started by ramonortiz55, Nov 11, 2015.
  1. Dec 24, 2015 at 10:47 AM
    #341
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    What a deal!
  2. Dec 24, 2015 at 11:05 AM
    #342
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    im keeping that suspension from the FJ allpro posted on IG
  3. Dec 24, 2015 at 11:23 AM
    #343
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Go ahead. I think I'll be doing SAS anyways haha
    It's a good chunk of change and if I wanted I could get a better deal on new stuff ;)
  4. Dec 24, 2015 at 11:27 AM
    #344
    ramonortiz55
    Ramon
    Texas
    stock
    fiiiiinneee
  5. Dec 24, 2015 at 11:28 AM
    #345
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    You seriously getting it though?
  6. Dec 24, 2015 at 11:29 AM
    #346
    ramonortiz55
    Ramon
    Texas
    stock
    nah.. gotta finish the 4runner first.
    :spy:
  7. Dec 25, 2015 at 12:49 PM
    #347
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    OK, I am in for a 27F.
  8. Dec 25, 2015 at 12:50 PM
    #348
    ramonortiz55
    Ramon
    Texas
    stock
    gotchu!
  9. Dec 25, 2015 at 2:50 PM
    #349
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Bumpity bump bump
  10. Dec 25, 2015 at 2:51 PM
    #350
    ramonortiz55
    Ramon
    Texas
    stock
    bumpo
  11. Dec 26, 2015 at 9:48 AM
    #351
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Please put me down for one 27F battery.
  12. Dec 26, 2015 at 9:52 AM
    #352
    ramonortiz55
    Ramon
    Texas
    stock
    done
  13. Dec 26, 2015 at 10:31 AM
    #353
    Rhubarb
    Rhubarb Well-Known Member
    Big D (TX)
    2016 OR, Manual Trans
    Do you or anyone else know if the 27F will fit in the 2016 battery bay?
  14. Dec 26, 2015 at 10:34 AM
    #354
    ramonortiz55
    Ramon
    Texas
    stock
    Check Toyota's website. There should be a list of compatible battery sizes.
  15. Dec 26, 2015 at 12:47 PM
    #355
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    I know there's 10 people out there that need a new battery..
  16. Dec 26, 2015 at 12:58 PM
    #356
    qnyla
    NM
  17. Dec 26, 2015 at 3:11 PM
    #357
    Rhubarb
    Big D (TX)
    Qnyla: Are you going for the 27F in your 2016? I saw your post; just want to be sure I understood. I don't even have my 2016 yet, but should be coming soon.
  18. Dec 26, 2015 at 4:06 PM
    #358
    qnyla
    NM
    Yes, I test fit an old 27F and was happy with the fit. A 27F battery tray is required. I *thiink* the part number for the 27F tray is 744310C020 and is about $34 online. The 27F is not what Toyota puts in the 2016 so make sure you are comfortable with the fit.
    From the links in the OP,
    24F Northstar NSB-AGM24F
    CCA = 830A
    Pulse cranking amps = 1500A
    Reserve capacity = 160 min
    weight = 57 lb
    27F Northstar NSB-AGM27F
    CCA = 930A
    Pulse cranking amps = 1750A
    Reserve capacity = 195 min
    weight = 68 lb
    ramonortiz55[OP] likes this.
  19. Dec 26, 2015 at 8:48 PM
    #359
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Been testing out the 27f North Star battery the last few days in big bear. 20° and below temperature the truck cranks up without missing a beat.
  20. Dec 27, 2015 at 7:34 AM
    #360
    Rhubarb
    Big D (TX)
    Qynla: Do you think the following plate would fit in the 2016 compartment? Based on your photo above, it looks like it would fit, although might be very tight: (Dorman battery tray for around $13. 7 1/2 inches wide/13 3/4 inches long.)
    http://www.amazon.com/Replace--Repl...8-2-fkmr0&keywords=northstar+27F+battery+tray
    Also, do you see any problem with the positioning of the NorthStar positive/negative posts? From the following PDF that OZ posted, it looks like one would only need to face the battery backward. Thoughts?
    http://mediacdn.shopatron.com/media/mfg/15710/spec_file/213779785.pdf
