**CLOSED**GROUP BUY**NORTHSTAR DEEP CYCLE BATTERIES**
Discussion in 'Closed Group Buys' started by ramonortiz55, Nov 11, 2015.
  1. Dec 27, 2015 at 8:24 AM
    #361
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I would not use the aftermarket battery tray, as it lacks the two lugs that insert into holes in the battery base in the engine compartment. These lugs prevent the battery from sliding. The tray you posted seems like it would require that it be bolted down (item 3 in the install instructions in the Amazon photo).
    I would just buy the OEM part for $34 online. The "F" in 27F indicates the positioning of the pos/neg posts. The 27F battery pictured in the Oz posted PDF should be correct. Compare to the photo of the old junk 27F I posted above.
  2. Dec 27, 2015 at 10:31 AM
    #362
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Thats my 27F mounted in my truck , terminals are correct
  3. Dec 27, 2015 at 12:25 PM
    #363
    zeekevin
    zeekevin Well-Known Member
    San Diego
    The 24f and 27f should have no problem fitting in the Tacoma. The terminal post are all in the correct locations
  4. Dec 28, 2015 at 10:13 AM
    #364
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    In for a 27F.
  5. Dec 28, 2015 at 10:16 AM
    #365
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    added
  6. Dec 28, 2015 at 11:24 AM
    #366
    ramonortiz55
    Ramon
    Texas
    stock
  7. Dec 28, 2015 at 11:50 AM
    #367
    Rhubarb
    Rhubarb Well-Known Member
    Big D (TX)
    2016 OR, Manual Trans
  8. Dec 28, 2015 at 11:52 AM
    #368
    ramonortiz55
    Ramon
    Texas
    stock
  9. Dec 28, 2015 at 11:53 AM
    #369
    ramonortiz55
    Ramon
    Texas
    stock
    EDDO likes this.
  10. Dec 28, 2015 at 3:43 PM
    #370
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  11. Dec 28, 2015 at 6:01 PM
    #371
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Where are those other 8 people
  12. Dec 28, 2015 at 7:48 PM
    #372
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Keep bumping the thread and they'll come soon enough. :thumbsup:
    Digiratus likes this.
  13. Dec 28, 2015 at 8:04 PM
    #373
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Pshh. I'm not bumping anything ;)
  14. Dec 28, 2015 at 8:05 PM
    #374
    ramonortiz55
    Ramon
    Texas
    stock
    So what did you guys have for dinner?
    Anyone watching MNF?
  15. Dec 28, 2015 at 8:50 PM
    #375
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  16. Dec 28, 2015 at 9:12 PM
    #376
    ramonortiz55
    Ramon
    Texas
    stock
    Those 8 other people are viewing this thread
  17. Dec 28, 2015 at 9:16 PM
    #377
    ramonortiz55
    Ramon
    Texas
    stock
    40 viewers o_O
  18. Dec 28, 2015 at 9:29 PM
    #378
    OZ-T
    Peter North
    British Columbia
    I already got one
  19. Dec 28, 2015 at 9:57 PM
    #379
    Digiratus
    Roaming the PNW
    The RedHead
    You need 2
  20. Dec 28, 2015 at 10:00 PM
    #380
    Digiratus
    Roaming the PNW
    The RedHead
    To all of the 47 'guests' currently viewing this thread. Join TW and get a battery. :bananadance:
