CLOSED Group Buy: TRD/ Magnuson 4.0 Supercharger Quickchange Pulley Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Nov 13, 2017.
  1. Apr 2, 2018 at 1:28 PM
    #361
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  2. Apr 2, 2018 at 1:54 PM
    #362
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    The
    I’ve got one. Are you doing the pulley boys thing?
  3. May 30, 2018 at 12:16 PM
    #363
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    If I go with the pulley boys 2.8” pulley with kit, do I have to worry about the spacing/fitment issue? Last I read, a 2.8 doesn’t require a snout trim
  4. May 30, 2018 at 1:47 PM
    #364
    BillDaCat8
    Jake
    PHX
    Just trim it.
    The 2.8 would probably fit. But, you'll want more boost soon enough. Seems odd to use the PulleyBoys setup if the plan wasn't to eventually go smaller tho. I'd suggest just going with one of Gadget's 2.8987654684621 pulleys if that's all the oomph you're ever gonna want.
  5. May 30, 2018 at 4:58 PM
    #365
    Roostfactor
    TX panhandle
    Trim it and quick change gets my vote. Its leaves your options open if you ever change your mind.
    12TRDTacoma[OP] likes this.
  6. May 30, 2018 at 8:06 PM
    #366
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The 2.8 pulley satisfaction doesn’t last long before wanting more boost
    12TRDTacoma[OP] and Roostfactor like this.
  7. May 30, 2018 at 8:15 PM
    #367
    Roostfactor
    TX panhandle
    Spoken by a veteran!
  8. May 30, 2018 at 8:59 PM
    #368
    Skootter14
    Jeremy
  9. Jun 21, 2020 at 7:13 PM
    #369
    BillDaCat8
    Jake
    PHX
    Need to update this thread too Rob.
    nudavinci64 likes this.
