**CLOSED** GROUP BUY - Wheel Bearings (2005-2018) v2.0
Discussion in 'Automotive Group Buys' started by 05Taco4x4, May 30, 2018.
  1. May 31, 2018 at 4:48 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    The seals are included in the GB :thumbsup:
  2. Jun 5, 2018 at 9:29 AM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Just for clarification, do these come with factory studs? Also curious on the ARP studs. Stock length or only extended? and how much extra?
    Either way, add me to the list. I just found a bad drivers wheel bearing not 30 minutes ago.
    EDIT: Nevermind the ARP studs. I see you only have extended. And i see the price. I run 1" wheel spacers so that is a no-go on fancy studs.
  3. Jun 5, 2018 at 9:38 AM
    05Taco4x4
    2TR-FE Enthusiast
    The hubs are generic, like Dorman- the studs are of same grade strength. I do use Toyota mounting bolts.
    ARP 8740 chromoly lugs (2-3/4")
    +$99
    The threads finish at 2-1/2", 1/4" finished end. Stock lugs are 1-1/2"
    I could cut them, but it'd be a pain in the ass and wouldn't be a finished end; they're meant to be used with open ended nuts.
    I'll add you to the list now :thumbsup:
    5678ta[QUOTED] likes this.
  4. Jun 5, 2018 at 9:43 AM
    5678ta
    Hogan
    Henderson, NV
    No need to hassle with that. The standard will be fine.
    05Taco4x4[QUOTED][OP] likes this.
  5. Jun 5, 2018 at 3:33 PM
    SilvFx
    SilvFx Well-Known Member
    Englewood, CO
    2010 Toyota FJ Cruiser
    Toytec Ultimate 3 Lift, RCI skids, 285/70/17 BFG AT KOs
    How about the 07-09 and 10-14 FJ Cruisers? If so, I can mention to members over at FJ Cruiser Forum.
  6. Jun 5, 2018 at 3:48 PM
    05Taco4x4
    2TR-FE Enthusiast
    Yes sir, also these vehicles:
    2003-15 4Runner
    2007-14 FJ Cruiser
  7. Jun 5, 2018 at 3:50 PM
    Jigeye
    Jigeye Active Member
    Alaska
    09 2.7L SR5 4x4
    LCE header, secondary air filter removed, AFE pro-dry S, backup camera anytime, blistein 5100s on .75" and General HAD leaf springs, Michelin Defender LTX 165/70/16 on stock rims, Cali Raised stealth mount light bar, leer camper shell, 200k miles mod
    Will the gb close as soon as you have 8 people? Considering this but can't pull the trigger just yet
  8. Jun 5, 2018 at 4:01 PM
    05Taco4x4
    2TR-FE Enthusiast
    Yes, as soon as I hit 8 the GB will be closed and start to the next one- no piling on at the end; it'll be ongoing and likely labeled Version 2..3.. and so on.
    For those that don't want to wait, the regular offering is very competitive and available for quick shipment.
  9. Jun 5, 2018 at 4:17 PM
    dylmatik
    dylmatik Well-Known Member
    Dylan
    16 DCLBTRDOR
    I'm interested.
    Where are you located? Currently at 70k on my odometer for my third gen and I do like to do preventative maintenance.
  10. Jun 5, 2018 at 4:20 PM
    05Taco4x4
    2TR-FE Enthusiast
    Kaneohe, HI
    Ships USPS Flat Rate Box so should be 3 day shipping
  11. Jun 8, 2018 at 2:28 PM
    1stDueL22
    1stDueL22 Well-Known Member
    Va. Beach, Virginia.
    2025 Bronze Oxide Off Road LB Premium
    Go ahead and add me to the list. Have my 2010 taco and a 2008 4runner in the household so these will be be used eventually I'm sure. :)
    05Taco4x4[OP] likes this.
  12. Jun 9, 2018 at 5:36 PM
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    Please add me to the list :thumbsup:
  13. Jun 9, 2018 at 5:38 PM
    05Taco4x4
    2TR-FE Enthusiast
    Done
    We're getting somewhere now, half way there!
  14. Jun 10, 2018 at 4:38 PM
    dylmatik
    Dylan
    16 DCLBTRDOR
    Please add me as well.
  15. Jun 10, 2018 at 5:26 PM
    #35
    05Taco4x4
    2TR-FE Enthusiast
    Done
  16. Jun 10, 2018 at 6:41 PM
    #36
    09TRDSport4x4
    Nick
    Southwest Ohio
    Pardon my ignorance but these are a direct swap of the existing hub and bearing, right? In other words I just unbolt the caliper and move it out of the way, remove the rotor and shield, unbolt anything else attached then remove the axle nut and bolts holding the hub on and pull it off?
  17. Jun 10, 2018 at 7:38 PM
    #37
    5678ta
    Hogan
    Henderson, NV
    Exactly as you describe. Easiest way to replace wheel bearings.
  18. Jun 10, 2018 at 9:29 PM
    #38
    09TRDSport4x4
    Nick
    Southwest Ohio
    Ok cool, I just wanted to make sure I didn’t need anything else to do the install. I’m also debating whether to do it myself or pay my mechanic buddy to do it. It doesn’t sound like it would be much worse than a brake job and not quite as bad as a full suspension install but it’s been a while since I’ve tackled either of those things on my own. How long you guys think it would take to do the swap on both sides myself? We talking a one or two day thing?
  19. Jun 10, 2018 at 10:48 PM
    #39
    5678ta
    Hogan
    Henderson, NV
    If you are doing the seals as well, it's a decently involved job since pulling the spindle off is the easiest route. Anyone with amateur mechanic skills could probably knock both sides out in an hour, assuming they have the correct tools on hand.
  20. Jun 10, 2018 at 11:28 PM
    #40
    05Taco4x4
    2TR-FE Enthusiast
    Not a day, taking it easy is 2-3 hrs max. I would borrow O'Reilley's slide puller to guarantee an easy job. Make sure to have a small wire brush to touch up the inner bore/face of the steering knuckle.
    Biscuits likes this.
