Closed - Internal Stiffeners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kwikvette, Jul 10, 2024.
  1. Jul 27, 2024 at 5:38 PM
    #581
    Max8
    Max8 Thinking Outside The Box until they close the lid
    23 SR5 DCLB stock
    2012 ARE DCU contractor cap, Transmission aftercooler kit (Iconic Fabrication & Hayden 698), Bed Stiffeners (Kwikfab LLC), Firestone airbag leaf springs, wye connector and pressure gauge, Tailgate security mod (mfgr. by Christian06 on TW), OEM mud flaps, OEM tailgate electronic lock, Tow-Pro Elite Electric Brake Controller, Anytime Backup Camera hardwired 42 ft to camper, RCI Alum. Skid plates & cat covers, 2WD LO mod (BB Tuning), Fumoto oil drain, ECT Always-On Mod (hardness by Funman1steve), 6awg DC DC tow charger wiring, inline 60 amp breakers & battery terminals, Kill switch, KJTO driver side grab handle, Hood hold open gas struts, Scangauge III, Seat Covers (Seat Covers Unlimited... wearing poorly),
    Id like to buy a plain set without the F bomb. Thank you.
    Having had to weld gusset plates to all the frame member connections of my cracking aluminum work cap, I'd like to minimize further racking in the bed.
    @Max8
    Kwikvette[OP] likes this.
  2. Jul 27, 2024 at 5:42 PM
    #582
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    I'll add you to the 3rd batch!
    No need to tag yourself, tagging me is how I'm notified if you want a set.
  3. Jul 27, 2024 at 8:35 PM
    #583
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    I'd like to move up. Ready to pay today.
    Kwikvette[QUOTED][OP] and NoOne like this.
  4. Jul 28, 2024 at 8:26 AM
    #584
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're in 2nd batch, not far behind!
    Spot filled up right away after I posted - just wanted to up the total batches to 12 versus 8.
    ERod27 and NoOne like this.
  5. Jul 28, 2024 at 10:34 AM
    #585
    bonuscup
    bonuscup Well-Known Member
    Southern California
    2021 TRD OR DC LB XYZ
    Really nice work. What is the advantage of this setup vs say the total chaos stiffeners?
    NoOne and Kwikvette[QUOTED][OP] like this.
  6. Jul 28, 2024 at 10:37 AM
    #586
    Kwikvette
    Fresno County
    4 run, 2 don't
    I should put this up on the front page but, @MagicToolbox said it best -
  7. Jul 28, 2024 at 10:54 AM
    #587
    bonuscup
    Southern California
    Awesome thanks. Solid work
  8. Jul 28, 2024 at 11:00 AM
    #588
    Kwikvette
    Fresno County
    4 run, 2 don't
    Like I told first batch, I promise I will start production first thing Monday.
    Would hate to delay anything by starting too early :anonymous:
  9. Jul 28, 2024 at 11:32 AM
    #589
    ERod27
    ERod27 Well-Known Member
    Eddie
    2019 TRD OR DCSB
    King 2.5s with Camburg Kinetik UCA Cooper Discoverer AT3 XLT 285/70/R17 17" 4 Runner TRD PRO SEMA wheels TRD PRO skid plate 5.29 Yukon gears Apogee front bumper with Warn EVO Apogee rear bumper with tire carrier
    Why does your behavior not surprise me? Undersell, over deliver!
  10. Jul 28, 2024 at 1:09 PM
    #590
    Kwikvette
    Fresno County
    4 run, 2 don't
    So, I'm glad I've been cutting these out because I will say, consumable life is actually less than average.
    To reflect this, I will be updating the price.
    Current batches are not affected by this.
    The new difference is $4/per.
    Thanks for understanding!
    Tulsa Taco likes this.
  11. Jul 28, 2024 at 1:13 PM
    #591
    Kwikvette
    Fresno County
    4 run, 2 don't
    Check this out; this is my refrigerated air dryer which lowers the temperature of incoming air in order to effectively separate moisture.
    This bottle was empty last week :bananadead:
    So, it's doing an absolute amazing job at removing moisture but with long runs on thicker steel, it really pushes consumables.
    Ignore the shiny outer edge, I sanded it to get a better idea of the orifice.
    Anyone that does CNC plasma, media blasting, painting, etc will understand what moisture does :rofl:
    NoOne and musicisevil like this.
  12. Jul 28, 2024 at 2:12 PM
    #592
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Swamp Crotch?
    ERod27 likes this.
  13. Jul 28, 2024 at 2:46 PM
    #593
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sounds like a personal problem :luvya:
    ERod27 and NoOne[QUOTED] like this.
  14. Jul 28, 2024 at 2:46 PM
    #594
    Kwikvette
    Fresno County
    4 run, 2 don't
    I use a moisturizing cream that prevents all that :anonymous:
    NoOne likes this.
  15. Jul 28, 2024 at 2:50 PM
    #595
    Kwikvette
    Fresno County
    4 run, 2 don't
    Also 95% of batch 1 is cut out.
    The remaining 5% are the pieces I lost due to a tip up, as well as anomalies like this.
    However, surface scratches and whatnot are expected. This is actually the worst of it, so everything is far better looking but this occurs through normal material handling from suppliers.
    Enjoy!
  16. Jul 28, 2024 at 4:13 PM
    #596
    GunthorNC
    That tie down, the only issue with it is the knick in the side? Not hole positioning or anything? If so, I'll take it. These parts will be living in a large rock tumbler for about 2 months before I paint and install them.
  17. Jul 28, 2024 at 4:16 PM
    #597
    Kwikvette
    Fresno County
    4 run, 2 don't
    The scratch on the bottom panel, will get filled with whatever paint someone uses, not to mention it'll live in a hidden location.
    The tie down bracket you mention? Yeah something occurred in the lead in and gouged that edge so I consider it scrap.
    If ya want it, I'll include it with your normal pieces once I make your order.
    Hole spacing, etc is the same as everything else.
    NoOne likes this.
  18. Jul 28, 2024 at 4:19 PM
    #598
    GunthorNC
    Yeah, if it's just that Nick throw it in mine. No point in you losing money over something so minor
    NoOne likes this.
  19. Jul 28, 2024 at 4:23 PM
    #599
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    It's still money lost!
    But yeah I'll toss it in with your order meaning, you're still getting two regular pieces.
    Appreciate you looking out though!
    Even from a garage shop, sold goods need to be held to a certain standard :hattip:
    NoOne and ERod27 like this.
  20. Jul 28, 2024 at 5:58 PM
    #600
    MagicToolbox
    MagicToolbox Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    Speaking of hole spacing, I took a shot at redrawing the tie down for the current revision of the plastic spacers. Apparently I got the hole spacing slightly off, and I forgot to increase the size of the holes.
    Can you send me a copy of the CAD for the tie down bracket? I'd like the spacers to be as close as possible to the steel.
