Closed - Internal Stiffeners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kwikvette, Jul 10, 2024.
  1. Jul 11, 2024 at 8:02 PM
    #61
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    You're good :thumbsup:
    Hope that above data points helped, regarding my incorporated bottle opener
    But here's a piece I cut out and compared to having it cut out on a $100k+ laser system
    5" tall and less than 2" wide
    Mine of course was on the right
    The dross wasn't knocked off (easily done with a wire wheel) but I wanted to directly compare the two systems on a specific test piece side by side
    I'd love a laser setup, but can't afford it :rofl:so instead I have a plasma setup
  2. Jul 11, 2024 at 8:47 PM
    #62
    MagicToolbox
    MagicToolbox Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    Yeah, a laser would be perfect. I just finished up helping to pack up and move to storage the makerspace that I am a member of, we've been packing for two weeks or I would ABSOLUTLEY have used the Glowforge laser cutter and done a prototype in 3mm plywood. Of the F-Bomb tie down as well as the rest of the stabilizer to see if it fit on my 3rd gen.
    If the F is cut in the right spot, I think you would get body color showing through, so if we paint or powder coat them, the F would show up pretty well. The fins allow hooking with cargo hooks. I think they would be big enough for a typical strap to pass through also. And your design with the fins gives a great spot to cinch a loop of rope in that little notch, so a slipped half hitch would grab hold and you don't have to feed the rope through.
    In the piece you cut, it looks like there are artifacts that may be dependent on direction of cut, or something. That feature in the top, the two half circles are different from each other - very curious.
  3. Jul 11, 2024 at 9:01 PM
    #63
    Kwikvette
    Fresno County
    4 run, 2 don't
    Always thought laser cutters were cool, even the smaller ones meant for cutting thin wood. You can get some remarkable detail out of those.
    As for the plasma piece above, that metal was 3/16" with many of those small details such as the half circles are coming in at .059" radius
    The kerf width of a 60 amp nozzle is .043"
    Running even at my fully dialed in speeds (with rules implemented for such small angles/etc) because of how plasma works, it is practically impossible to achieve anything better than what I posted above on my setup.
    This is before we get into high-definition plasma of course, which would cost over $60k for a machine itself, and normally run on a higher-end table with different movement style (and motors) costing over $30-50k.
    But even on my same plasma cutter, I could absolutely benefit from a nicer table. I already know what table I will upgrade to but that'll be some years from now.
    Gofundme? :rofl::spending:
  4. Jul 11, 2024 at 10:12 PM
    #64
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Im extremely interested.
    I can’t find a solution that isn’t low profile.
    And im too attached to my swing case, so maintaining the bracket for that is a priority for me.
    Some people like a slim look nearly OEM or as if nothing was there.
    Kwikvette[OP] likes this.
  5. Jul 11, 2024 at 11:18 PM
    #65
    BluberryBCtaco
    BC Canada
    What would you need for 2nd gen measurements?
    I have to replace my tail lights anyway. How can I assist?
    Kwikvette[QUOTED][OP] likes this.
  6. Jul 12, 2024 at 12:09 AM
    #66
    that180guy
    that180guy Well-Known Member
    Alex
    DCLBOF
    I'm attached to my fridge/cooler slide lol. Too lazy to remount it to make room for sliders. I too should have measured and made room for them but...oops. I too am in for these, either in 1/8'' or the cads. Tell me where to send beer moneey!
  7. Jul 12, 2024 at 4:40 AM
    #67
    nevertoomanytacos
    nevertoomanytacos Taco Fan
    3rd Gen
    Could inside edge be rounded?
  8. Jul 12, 2024 at 7:08 AM
    #68
    Kwikvette
    Fresno County
    4 run, 2 don't
    That was a thinking out loud moment as I believe the stiffeners work for both generations.
    But if something comes up I'll be sure to ask.
  9. Jul 12, 2024 at 7:11 AM
    #69
    Kwikvette
    Fresno County
    4 run, 2 don't
    As in, sanded/grinded down?
    That'd be some manual labor just to do that even on one set - a finger sander or die grinder would remove too much material too quickly, and a hand file would work best but take a bit to accomplish
    Lots of items out there retain that metal lip without issue, I was just referring to a radius cut out that's all
    Is that what you meant or?
    Here's an example of another item I cut out, also 3/16" thick
    The lip isn't very sharp, but it exists unless manually grinded down
  10. Jul 12, 2024 at 10:14 AM
    #70
    Kwikvette
    Fresno County
    4 run, 2 don't
    One issue I've read about regarding the 4WP stiffeners are how the nuts aren't centered over the holes
    I wanted to alleviate this with a super simple little jig so I cut this out of stainless steel
    I toyed with placement of the nuts right over the holes, leaving enough room for a bolt to go through
    However, this can be an issue when lining it up with the large L bracket based on how it sits within the tail light housing
    Simple solution would be a slightly larger hole too on the L bracket, but I feel better just having all the nuts centered evenly over the holes so I'll be welding bolts to the stainless steel plate for my jig
    Just need to go out and buy some bolts for that
    The square nuts you see there are weld nuts I normally use on projects, so I'll have to price those out otherwise I can stick with standard hardware found online
    musicisevil likes this.
  11. Jul 12, 2024 at 10:16 AM
    #71
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    You could also use weld nuts. There's a pilot part to them. I am planning on using these to mount my skid when I do a crossmember chop
    https://www.mcmaster.com/93560A180/
  12. Jul 12, 2024 at 10:19 AM
    #72
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh I've used similar, but keep in mind whatever costs I accrue affect the end result here and buyers will need to spend more
    I won't be using the cheapest hardware, but the solution doesn't warrant some crazy hard stainless steel application either (or something like your link shows)
    4WP used cheap nuts on their setup and put two small tacks per; I'll at least make the tacks larger
    At more than $1 per nut you show there, that's an automatic $10 added to the cost of the stiffeners (before tax and shipping for said hardware)
  13. Jul 12, 2024 at 10:22 AM
    #73
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Yep I get it, just wanted to make sure you knew about these as an option for this or another project you got goin on
  14. Jul 12, 2024 at 10:50 AM
    #74
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    I just got around to finally installing the 4WP version. I mounted the portion visible in the bed pointing up. Pointing towards the cab conflicted with how I load the bed for camping (every fraction of an inch of space matters and has been optimized for). It would be nice to have the same option on yours, but I'm obviously not in the market now, so take my opinion for what it's worth.
  15. Jul 12, 2024 at 10:52 AM
    #75
    Kwikvette
    Fresno County
    4 run, 2 don't
    Picture?
    Just because you own a set, doesn't mean I can't make just the tie down portion as a one off if you needed.
    Just depends what all else you're wanting to change as I can orient the mounting holes to match your current ones without needing to re-drill.
    Or even send a blank set and you just drill into the plate itself to match the holes on your existing mount.
  16. Jul 12, 2024 at 11:58 AM
    #76
    MagicToolbox
    It could be rounded a little, but keep in mind that the steel is going to be between 1/8 and 3/16 thick, that's not much of a round over. It would also add considerably to the post processing, the plasma can't cut a rounded edge.
    I'm already designing a 3D printed insert that would slide in which would protect rope from the edges.
    This is all still early, and the Tie down point has not even been finalized, so things are still changing.
  17. Jul 12, 2024 at 2:21 PM
    #77
    Kwikvette
    Fresno County
    4 run, 2 don't
    The right tools make all the difference
    Giantstoge likes this.
  18. Jul 12, 2024 at 2:40 PM
    #78
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Loving this! I had no idea this style existed but it's SO SO much better than the standard ones we see (and which I already have on my truck but are often annoying).
    I'd love to commit, but I'm also picky. Specifically, I don't need or want a bottle opener, nor any funny graphics or anything like that (no offense to anyone who enjoys that stuff, just not my cup of tea). Most important to me would be a sleek, but robust, tie down point. I'll be keeping an eye on the thread to see what the final design looks like and may be all in on that. Otherwise I may just draw up my own piece for the tie down and use SendCutSend then weld 'em up myself.
    Either way, great work here everyone, this is why the Tacoma community is so awesome!
    AssQuake likes this.
  19. Jul 12, 2024 at 3:22 PM
    #79
    Kwikvette
    Fresno County
    4 run, 2 don't
    When the final product is announced, I will then post up and make a batch with the two or three most asked for styles
    Not everyone wants a tie down, or a bottle opener, or both, and since it's a small piece I can cut those nested separately from everything else
    A lot of people want to pre-order, so that'll be difficult to get to (as in, first run will be limited) but contributing members will be included in the first batch
  20. Jul 12, 2024 at 4:16 PM
    #80
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ready for tomorrow
    Mainly just ensure there's room for the holes and angles are correct
    Then hoping to cut a few parts in 3/16" later in the day
