Closed - Internal Stiffeners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kwikvette, Jul 10, 2024.
  1. Aug 10, 2024 at 8:36 PM
    #901
    RxYoda
    RxYoda Well-Known Member
    Mark
    Florence, SC
    2023 Sport Premium 4x4 DCSB
    Prime, paint, cure…
  2. Aug 11, 2024 at 12:53 PM
    #902
    MagicToolbox
    MagicToolbox Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    Just sent payment requests to those of you getting strap savers in the first batch.
    In an attempt to get ahead of the second batch, those of you listed below (copied from the first page), let us know if you want strap savers. Pictures should be starting to come in soon for installs so you can get a better idea of what you are getting.
    @clenkeit Plain bracket
    @ticklemytaco
    @cybrnookTie down only
    @waffleironTie down only
    @545Tie down only
    @dmac120
    *PIF* BluberryBCtaco D F bomb, P Plain bracket
    @GunthorNCTie down only
    @blackenbluePlain bracket
    @CemenTRDgenPlain bracket
    @AlakablamoPlain bracket
    @offroadtoyboy1 Plain bracket set, 1 F Bomb set
    NoOne and Kwikvette[OP] like this.
  3. Aug 12, 2024 at 1:24 PM
    #903
    RxYoda
    Mark
    Florence, SC
    Bolts received!
    NoOne, Kwikvette[OP] and Slow_sr20 like this.
  4. Aug 12, 2024 at 1:27 PM
    #904
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    Those are 1.25
    I use 1.50 on all the parts; seems they sent you the wrong parts?
  5. Aug 12, 2024 at 1:30 PM
    #905
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Also in California they cause reproductive harm and cancer. But only in Cali.
  6. Aug 12, 2024 at 1:32 PM
    #906
    RxYoda
    Mark
    Florence, SC
    They did, I have already had them send the correct ones. (correct on invoice, packing error).
    NoOne likes this.
  7. Aug 12, 2024 at 1:36 PM
    #907
    Kwikvette
    Fresno County
    4 run, 2 don't
    What doesn't kill you only makes you stronger :luvya:
  8. Aug 12, 2024 at 4:06 PM
    #908
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Correction: That which doesn’t kill you, only postpones the inevitable.
  9. Aug 12, 2024 at 4:51 PM
    #909
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hoping to see some installed, hopefully soon!
    Those that were waiting for their package to be sent were mailed off earlier today - you'll get your stiffies along with the 3D insert you ordered thanks to @MagicToolbox
    musicisevil, 6H05tP3p3 and NoOne like this.
  10. Aug 12, 2024 at 5:01 PM
    #910
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I had a setback… I sprayed my second coat with Rustoleum “Professional” primer and it was the wettest coat I’ve had in a long time. Even in full HOT Sun, it was still tacky 3 hours later. Switching tactics…
    Willy Lump Lump likes this.
  11. Aug 12, 2024 at 5:26 PM
    #911
    Willy Lump Lump
    21’ dcsbmt
    This and that
    I had the drivers side in, took it out to spray the holes…
    MagicToolbox likes this.
  12. Aug 12, 2024 at 5:28 PM
    #912
    Kwikvette
    Fresno County
    4 run, 2 don't
    :worthless:
  13. Aug 12, 2024 at 5:50 PM
    #913
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Sorry. I will get some on the next round.
  14. Aug 12, 2024 at 5:53 PM
    #914
    MagicToolbox
    OK @Kwikvette, I got some pictures.
    Here's what I did. Traced the "L" bracket on a piece of cardboard with a pencil, cut out the perimeter, and drilled the top holes with my step drill bit. I installed the tie down, and the top internal with the weld nuts. I used a transfer punch to mark the center of the slotted holes, pilot drilled, step drilled to a clearance hole, and deburred. We put the card board on the bolts, put the "L" bracket on, and finger tightened the bolts. Then I used an X-acto blade and cut the large hole as well as the two smaller slotted holes, tracing the Toyota sheet metal.
    This pic shows a slight misalignment of the large hole, as well as the one slotted hole for the wire management.
    This pic shows the second hole above the large hole, you can see the pencil marks from the tracing operation, as well as the X-acto tracing of the Toyota metal.
    This pic shows the slight misalignment of the Hidden stiffy holes without the cardboard in the way.
    This pic shows the wire attachment in my recommended revised orientation. IN MY TRUCK it was attached to the wiring harness with electrical tape with the long part facing the front of the truck. I cut it off and will tape it back on facing backwards, as I do not believe that even with PERFECT alignment of the slotted holes, that the push through stud will hold onto 3/16" steel.
    This is a picture of the plastic wire management device with a 10 mm socket on a ¼" hex driver for scale.
    Kwikvette[OP] and NoOne like this.
  15. Aug 12, 2024 at 6:24 PM
    #915
    Kwikvette
    Fresno County
    4 run, 2 don't
    Now you got me curious as to why the large hole is misaligned - it was based off the template used on @Sand_In_My_Taco truck where the large hole and wire opening matched up perfectly.
    You can see that this truck didn't even have any wires running through the large hole or anything else in the way; wonder what those options are for?
    Unless you think it's the alignment of the internal bracket that is putting the L bracket where it is?
    What do you suggest we do in this case? I'd like to leave the L bracket alone as it seems it's more about how it gets aligned versus the holes being in the wrong location.
    What if I skip weld nuts on the top of the L bracket and make them to be slots instead (while still providing the necessary nuts)?
    This would allow more flexibility during the installation process.
    NoOne and MagicToolbox[QUOTED] like this.
  16. Aug 12, 2024 at 6:28 PM
    #916
    MagicToolbox
    I think leaving it as is makes the most sense. There is a possibility that I did not properly clock the "L" bracket when I installed it. I may also be able to open up one or both of the holes to allow enough rotation.
    The wire on the drivers side is for the bed cargo lights. Passengers side has a cargo light and the 110 VAC bed outlet.
    NoOne likes this.
  17. Aug 12, 2024 at 6:33 PM
    #917
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gotcha.
    But does my suggestion make sense?
    Not weld the top two nuts, make them into slots, and provide the nuts for install?
    This means you have the ability to move them slightly.
    Also I'd like to incorporate that top slot above the large hole unless we skip it cause it won't fit in there with the thick steel plate?
    NoOne likes this.
  18. Aug 12, 2024 at 6:41 PM
    #918
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    I just started a new job, haven't had time to install.
    I'll try and do it tomorrow night
  19. Aug 12, 2024 at 6:41 PM
    #919
    MagicToolbox
    Whups, sorry missed that question...
    Hmm.
    It should allow the "L" to be clocked more easily. It may make assembly a little easier, in that you can push the bolts through, and hang the bracket. It does mean that you need a wrench on the inside to tighten them.
    It would ALSO allow those bolts to support a shelf in the fender for a hidden air compressor mount or 5 liter Scepter jerry can of water...
    NoOne likes this.
  20. Aug 12, 2024 at 6:50 PM
    #920
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll wait for those that have their sets (or will receive their sets soon) to install their stiffeners and see if this is a common trend before attempting to rectify it.
    Again I want all bases covered before I make more.
