Closed - Internal Stiffeners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kwikvette, Jul 10, 2024.
  1. Aug 17, 2024 at 6:45 PM
    #1001
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    With your install and possibly one more done, I'll kick off with confirming 2nd batch and maybe grabbing some steel this coming Friday.
    musicisevil, NoOne[QUOTED] and RxYoda like this.
  2. Aug 17, 2024 at 7:16 PM
    #1002
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I’m planning on making a template of my panels before I install, so you can have the layout of a 22 which has the bed lights shtuffs. I honestly don’t feel it’s an issue, but I know yer like me and “it’s the principle of the thing” where you’re going for reasonable accuracy overall.
    Kwikvette[QUOTED][OP] likes this.
  3. Aug 17, 2024 at 7:25 PM
    #1003
    Kwikvette
    Fresno County
    4 run, 2 don't
    That'd be really helpful!
    During your install just keep this in the back of your mind -
    If these slots were either moved a tad outward or widened, will it aid in getting the large hole on the L bracket lined up with the vehicle?
    ljerr2 and NoOne[QUOTED] like this.
  4. Aug 17, 2024 at 7:28 PM
    #1004
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Working on passenger side….
    Bed lights have a disconnect
    NoOne and Kwikvette[OP] like this.
  5. Aug 17, 2024 at 7:30 PM
    #1005
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Oh dang. It’s the inverter wire.
  6. Aug 17, 2024 at 7:31 PM
    #1006
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ahh, was the inverter an option for certain trim levels only?
  7. Aug 17, 2024 at 7:36 PM
    #1007
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    TRD up. May only be Offroad and Pro, can’t recall for Sport.
  8. Aug 17, 2024 at 7:37 PM
    #1008
    Willy Lump Lump
    21’ dcsbmt
    This and that
    MagicToolbox likes this.
  9. Aug 17, 2024 at 8:38 PM
    #1009
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Man I did not like that install. No offense. I do like the results though. It was just a lot of strange angles to hold a drill. A smaller drill helps. Not to mention I apparently have a lot going on behind my taillights, electrically speaking. IMG_1561.jpg IMG_1563.jpgAnd it got dark while I was working on it, never any fun. IMG_1562.jpgIMG_1565.jpg
  10. Aug 17, 2024 at 8:46 PM
    #1010
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not to worry no offense taken! :rofl:
    It's just like the Ronco Showtime Rotisserie...
    NoOne and Willy Lump Lump like this.
  11. Aug 17, 2024 at 9:10 PM
    #1011
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Got this did. So with careful measuring, my L brackets are pretty near perfect on both sides. This is despite using the wrong horizontal measurement and having to widen the holes with a dremel a 1/4” toward the cab:anonymous:
    Pretty sold alignment despite my poor initial measurements on the drivers side. Slotted holes in the corner bracket definitely helped. With the two bolts finger tight, I was able to rotate the L slightly to get this alignment. If it was off significantly, I could have widened the holes to match the slots, since I was already reaming shit.
    Something I haven’t seen mentioned yet, is that the middle hole for the bottom of the L bracket, falls directly on a seam. This makes getting this pilot hole started a real F’ing bear. Like @Willy Lump Lump mentioned these 6 holes will test your tolerance for horse shit. Awkward angles and crappy bits meant my drill was walking all over the place. I don’t have a punch, so I wound up using a nail to hammer a dimple to get a pilot hole to start the step bit for each one.
    Proper tools and strong core muscles would have made this much easier.
    Huge thank you to kwifab for making this happen and all you guys for your tips
  12. Aug 17, 2024 at 9:31 PM
    #1012
    Kwikvette
    Fresno County
    4 run, 2 don't
    Unless you pull off that exterior bracket, I would've never known you were slightly off on your initial drilling there.
    Looks good!
    Man, y'all are really knocking these out quickly.
    Yeah it's fair to say that 2nd batch is a go.
  13. Aug 17, 2024 at 9:33 PM
    #1013
    Kwikvette
    Fresno County
    4 run, 2 don't
    Only having half the time I normally do, I'll be working on 6 at a time versus 12.
    With that said, tagging y'all to confirm your exterior bracket and see which 6 I'll work on first.
    Thinking I'll buy steel this coming Friday so I can get started the following Monday.
    @clenkeit Plain bracket.
    @ticklemytaco No bracket chosen?
    @cybrnook Tie down with strap savers.
    @waffleiron Tie down with strap savers.
    @545 Tie down.
    @dmac120 No bracket chosen?
    @BluberryBCtaco D F bomb, P Plain bracket?
    @GunthorNC Tie down?
    @blackenblue Plain bracket.
    @CemenTRDgen Plain bracket?
    @Alakablamo Plain bracket?
    @offroadtoyboy 1 Plain bracket set, 1 F Bomb set?
    Also for those wanting tie down or tie down bottle opener variants, please state whether you're interested in a set of strap savers.
    I still have some to help fulfill requests for 2nd and possibly 3rd batch.
    They're $10 each set, and are paid to @MagicToolbox
  14. Aug 17, 2024 at 11:41 PM
    #1014
    blackenblue
    blackenblue Active Member
    Daryn
    2015 DCLB
    stock
    Plain bracket for me.
    Kwikvette[OP] and NoOne like this.
  15. Aug 18, 2024 at 3:24 AM
    #1015
    waffleiron
    waffleiron Well-Known Member
    Washington
    Tie down + Savers
  16. Aug 18, 2024 at 8:07 AM
    #1016
    cybrnook
    cybrnook Well-Known Member
    SE Michigan
    2022 TRD Off-Road Manual Transmission
    Regular tie downs, please.
  17. Aug 18, 2024 at 9:46 AM
    #1017
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    That is correct. Plain bracket for me. Thanks!
    NoOne and Kwikvette[QUOTED][OP] like this.
  18. Aug 18, 2024 at 9:49 AM
    #1018
    545
    545 Well-Known Member
    2015 Access Cab
    Tie down only
  19. Aug 18, 2024 at 9:54 AM
    #1019
    musicisevil
    Alaska
    2019 TRD Sport
    You guys should start doing sit ups now to strengthen your cores for this install…
  20. Aug 18, 2024 at 2:35 PM
    #1020
    MagicToolbox
    MagicToolbox Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    I had exactly that same problem with that seem. Drivers side was exactly on the worst edge. Passenger I managed to pull off with a 1/16 pilot hole after center punching.
    Driver side I wound up drilling a pilot hole in a 1x2 inch piece of steel, then clamping it in place where I wanted the hole and using it as a drill jig.
    I'm still feeling my abs from pushing that dang drill though there. I agree that I didn't like the install. I see why other manufacturers are going for the no hidden install. Still glad @Kwikvette made these and that I have it done. Just not interested in going into business installing them in my driveway! A lift would help a lot.
