CLOSED JD Fabrication/81Trekker Suspension Group Buy CLOSED
Discussion in 'Closed Group Buys' started by Arcticelf, Apr 30, 2020.
  1. May 11, 2020 at 8:00 AM
    #181
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    All right guys the group buy promo code is live. I will PM everyone on the list for the LCA kits now. The code is only valid for one week so make sure to place your order ASAP!
    There is also a section for notes so please specify steel, aluminum or no skid option and 2wd or 4wd.
    Thanks guys!
    CMScheid, kasnerd and desertjunkie760 like this.
  2. May 11, 2020 at 8:19 AM
    #182
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    :bananadance:....imma keep hittin the refresh button then!!
  3. May 11, 2020 at 8:29 AM
    #183
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    The site will not let me do localpickup and the discount code at the same time.
  4. May 11, 2020 at 8:32 AM
    #184
    81Trekker
    La Jolla SD
    It should work if not just include notes for no skid and we will refund you $80 ASAP
    Arcticelf[OP] likes this.
  5. May 11, 2020 at 8:59 AM
    #185
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Just paid, I added in the notes my situation with the 5/8” or custom bushings.
    I only read the PM before paying and didn’t add in the note that I’m 4x4 and Aluminum.
  6. May 11, 2020 at 9:43 AM
    #186
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Yes, the LCA brackets with Steel skid
    Arcticelf[QUOTED][OP] likes this.
  7. May 11, 2020 at 2:13 PM
    #187
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    So will we get money back if we aren't getting a skid, how does that work?
  8. May 11, 2020 at 2:19 PM
    #188
    81Trekker
    La Jolla SD
    Yes, just use the promo code from the group buy, include no skid in the notes, pay the total amount and I will refund you the skid right away
  9. May 11, 2020 at 2:23 PM
    #189
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Good deal. For the shopify stuff get JD to add options to the item like the different skid materials and an option for local pickup that will bypass the code situation. We did that and it makes life so much easier than refunding or sending an invoice. It's a PITA sometimes dealing with online retail webpage stuff.
  10. May 11, 2020 at 2:33 PM
    #190
    81Trekker
    La Jolla SD
    I need to sit down and spend some time dialing it in... I’ve been so busy making parts lately! Lol
    CMScheid likes this.
  11. May 11, 2020 at 2:39 PM
    #191
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    It can be very time consuming and frustrating.
  12. May 12, 2020 at 7:17 AM
    #192
    Arcticelf
    Arcticelf [OP] Well-Known Member
    Gladiator
    Three more spots to fill until the CV axle order happens. Who wants a 4WD upgrade?
    kasnerd and ovrlndkull like this.
  13. May 12, 2020 at 7:45 AM
    #193
    81Trekker
    La Jolla SD
    Just a little reminder...
    old55guy, kasnerd, Hawk373 and 3 others like this.
  14. May 12, 2020 at 7:55 AM
    #194
    DocME
    California
    '07 FJ Cruiser
    Can the shafts be made to fit a +3.5 length?
  15. May 12, 2020 at 8:01 AM
    #195
    81Trekker
    La Jolla SD
    Yes, any length
    kasnerd and Arcticelf[OP] like this.
  16. May 12, 2020 at 8:27 AM
    #196
    81Trekker
    La Jolla SD
    3 pass with a weave over the top... theses things are so solid
  17. May 12, 2020 at 11:07 AM
    #197
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    Can we get a NSFCC (not safe for credit cards) warning label?? that's awesome. wow. beefcake.
    hoverlover and desertjunkie760 like this.
  18. May 12, 2020 at 11:23 AM
    #198
    81Trekker
    La Jolla SD
    I just lol’ed that shits funny!
    kasnerd[QUOTED] likes this.
  19. May 12, 2020 at 11:59 AM
    #199
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    So on the axle thing, it clearly improves the strength and operation angles of the tripod joint, and the axle itself. Can the outer OEM CV survive larger angles than stock-ish extended travel suspensions give now? Seems that one has to flex even more because of steering while flexed, like flex in x (suspension) and y (steering) instead of x only. And if it is flexed more in x, same in y, but isn't any stronger is it a potentially increased point of failure?
    To be clear, I haven't broken an axle yet, hope to never break one. But heard that even in OEM configuration and angles, it is often the outer joint that fails. Any truth to this? Any thought on giving the 300m parts a whirl in the outer CV similar to what is going on with the inner?
    On another note, I am eagerly awaiting more pics of the steering setup, hoping you can give some additional teaser shots of that also, particularly with the new boots required on the rack itself as well as how the tie rod arrangement works with the angles compared to OEM.
    Arcticelf[OP] and old55guy like this.
  20. May 12, 2020 at 12:16 PM
    #200
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I'm going to go out on a limb here and say you're an engineer?
    Arcticelf[OP] and whatstcp like this.
