CLOSED JD Fabrication/81Trekker Suspension Group Buy CLOSED
Discussion in 'Closed Group Buys' started by Arcticelf, Apr 30, 2020.
  1. May 12, 2020 at 12:19 PM
    #201
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Or he is over thinking it?! Have some faith and trust in a shop that’s been building trophy trucks for 20yrs
  2. May 12, 2020 at 12:23 PM
    #202
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    overthink is clearly my affliction, thanks for the responses
  3. May 12, 2020 at 12:24 PM
    #203
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    either way...I think you answered this previously? outter CV isn't a plunge so it doesn't have the same issues as the inner cv... (in terms of strength and movement)
  4. May 12, 2020 at 12:26 PM
    #204
    81Trekker
    La Jolla SD
    This guy gets it!
  5. May 12, 2020 at 12:38 PM
    #205
    racebug68
    Travis
    Chandler, AZ
    The question was of technical content, the answer was you must be a technical guy and to have some faith. OK, Whatever. I know the outer cv does not allow for axle length variation... and inherently that makes it stronger than one that does. But it still is exposed to more angular operation than the inner, and from what I heard first hand, does break in cases where the tripot joint did not. This axle enhancement doesn't address that. Which, may not be not a problem, but it is a factual statement. And my statements were not meant to stir the pot or doubt someones experience or product offerings. It is just information that I was bringing to the table and asking for thoughts.
  6. May 12, 2020 at 1:09 PM
    #206
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Every engineer I've ever met/worked with overthinks a process. This is the direction I was headed.
  7. May 12, 2020 at 1:12 PM
    #207
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    That’s literally their job, so I guess it makes sense.
  8. May 12, 2020 at 1:16 PM
    #208
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Its better for the CV to break than the ADD or front differential. I'm wrapping up an install for 40 inch tires on my truck, I have RCV's and OEM CVs.... Guess which ones I'm going to run and guess which ones are going to be the spares. Unless I break a OEM joint CV every time I go out I'll only use the RCVs as spares.
    Keeping one of the joints OEM will help protect the more expensive and harder to replace components
  9. May 12, 2020 at 1:30 PM
    #209
    81Trekker
    La Jolla SD
    The 934 allows for a longer axle with more plunge which allows the outer to be more relaxed. This was discussed in detail in the original thread.
    kasnerd likes this.
  10. May 12, 2020 at 1:49 PM
    #210
    racebug68
    Travis
    Chandler, AZ
    Some people take that approach, to use a fuse of sorts. I can't fault it, but of course it depends on application and size of the fuse. Something to be said for breaking cheap easy to replace parts. Wonder if anyone has compiled data on how many have broken diffs compared to axles, especially when there are upgraded components like gearsets and lockers involved, which are advertised to be stronger than OEM.
    Ahh... thanks. Don't know how I missed that, my apologies. Longer axle does reduce outer cv working angle. That statement is all that was needed, not any of the snarky engineer comments.
    old55guy likes this.
  11. May 12, 2020 at 2:13 PM
    #211
    tetten
    Andy
    Socal
    As was already stated, you're over thinking this. It's not electrical work. Unless you have the skills and machinery to custom make CVs you really only have 3 choices..... OEM joints, RCVs, or 934 inner/OEM outer
    I don't know your intention with your truck but unless you plan on crawling difficult technical trails, your whole line of questioning is kind of moot. @81Trekker already said the main purpose of the CV 934 upgrade was to compensate for the extra travel his LT kit has. If you are solely prerunning with any other suspension kit you shouldn't be breaking CVs, OEM or not.
    All your going to find about front end failures will be anecdotal. Anecdotally, I tool around on TW and IG a lot and have never seen a report of someone breaking a front R&P or front carrier on late model Toyota 4x4s, except me.
    whatstcp and desertjunkie760 like this.
  12. May 12, 2020 at 3:12 PM
    #212
    CMScheid
    CMScheid Well-Known Member
    Cody
    NorCal
    2017 Silver Tacoma TRD Off-Road
    Front: ADS 2.5 Coilovers JD Fab LT 2.25" LCA Pivot Rear: ADS 2.5 Coilovers 3 Linked Armor: Hot Metal Fab custom Rear Bumper Hot Metal Fab custom Skids & Sliders BAMF Front Bumpers
    @Arcticelf
    I’m all in for:
    -934 CV kit (switch to LT)*
    -Steering Slide rack with heimed tie rods & double shear for spindle
    Arcticelf[OP] likes this.
  13. May 12, 2020 at 3:14 PM
    #213
    DocME
    California
    '07 FJ Cruiser
    I’m in for CV’s, what’s the ETA for being ready for those?
    Also please list them for a plus 3.5” LT kit. I should be able to get some a specs if needed.
  14. May 12, 2020 at 4:41 PM
    #214
    81Trekker
    La Jolla SD
    Flanges are cut, need your cores and axels are about 3 weeks
  15. May 13, 2020 at 5:47 AM
    #215
    Arcticelf
    Arcticelf [OP] Well-Known Member
    Gladiator
    You're on the list
  16. May 13, 2020 at 8:59 AM
    #216
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    What's included with the steering setup? Just noticed the heimed tie rods are listed separate for somebody. I thought they were included, but if not, I definitely want to add those!
    Same with the long travel actually, does it include everything as a lot, or do I need to get my own limit straps etc? No big deal, just want to be prepared
    CMScheid likes this.
  17. May 15, 2020 at 6:22 AM
    #217
    Arcticelf
    Gladiator
    I believe the outer hiem conversion is optional with the steering.
    @81Trekker can confirm on that and the BOM for the LT kit.
  18. May 15, 2020 at 9:04 AM
    #218
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    old55guy and Arcticelf[OP] like this.
  19. May 16, 2020 at 3:15 PM
    #219
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Come on guys I want some axles.
    Arcticelf[OP], CMScheid and DocME like this.
  20. May 18, 2020 at 3:04 AM
    #220
    Arcticelf
    Gladiator
    TTT someone wants axles this morning
    DocME likes this.
