**CLOSED**Northstar Battery group buy 3.0**
Discussion in 'Closed Group Buys' started by ramonortiz55, Oct 31, 2016.
  1. Nov 21, 2016 at 2:40 PM
    #61
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    @ramonortiz55 im out on this bro, my battery total shut right now and need a immediate fix.:cheers:
  2. Nov 21, 2016 at 3:40 PM
    #62
    Heleto
    Heleto Well-Known Member
    Sam
    NC
    Anyone here planning to install this battery in 1st gen?
    @ramonortiz55 I am interested a dual battery setup. I know it depends on the number of people interested, but do you have a rough idea of when we will get the shipment..a ballpark?
  3. Nov 21, 2016 at 4:17 PM
    #63
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    about a week after everyone pays
  4. Nov 21, 2016 at 9:00 PM
    #64
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    On a 1st gen, a 24F is the largest size that will fit in the stock location. Where were you thinking of mounting the second battery?
  5. Nov 21, 2016 at 9:06 PM
    #65
    Heleto
    Sam
    NC
    A quick search on Northstar website shows that both these batteries fit: NSB-AGM-24F and NSM-AGM-35. Would that a mistake, you think?
    I am planning to mount the second on the passenger side firewall. I am currently doing some research on where to install for first gen and did not decide yet.
  6. Nov 21, 2016 at 9:14 PM
    #66
    Digiratus
    Roaming the PNW
    The RedHead
    A 35 has less capacity the a 24F but I'm sure either size will work. I chose to use 24Fs because of the capacity and because the positive/negative post location. I'd suggest 2 of the same size either way. If you have the room over the passenger fender (no ABS controller there) that is a convenient location for the house battery.
  7. Nov 21, 2016 at 9:16 PM
    #67
    Heleto
    Sam
    NC
    I searched on your posts and did not find any. Curious if you have a dual battery setup?
  8. Nov 21, 2016 at 9:21 PM
    #68
    Digiratus
    Roaming the PNW
    The RedHead
    I do. House battery is in the bed. Used 00 gauge with a BlueSea ML-ACR controller. No room in my engine bay.
  9. Nov 22, 2016 at 10:47 AM
    #69
    Heleto
    Sam
    NC
    OK. Thanks.
  10. Nov 22, 2016 at 3:55 PM
    #70
    ramonortiz55
    Ramon
    Texas
    stock
    Let me know if you want in
  11. Nov 22, 2016 at 3:56 PM
    #71
    ramonortiz55
    Ramon
    Texas
    stock
    Added
  12. Nov 22, 2016 at 3:57 PM
    #72
    ramonortiz55
    Ramon
    Texas
    stock
    We have 11!
    SAC-CA-Runner likes this.
  13. Nov 22, 2016 at 9:08 PM
    #73
    Heleto
    Sam
    NC
    Count me in for two NSB-AGM-24F. Thanks for doing this.
    Digiratus likes this.
  14. Nov 24, 2016 at 10:43 AM
    #74
    Styx2015
    Styx2015 Well-Known Member
    Paul
    2008 White Tacoma DCSB TRD Off Road
    I'll take two as well. Not sure if they will be 35's or 24's. Still waiting for an answer on fitment, but definitely in.
  15. Nov 24, 2016 at 11:49 AM
    #75
    ramonortiz55
    Ramon
    Texas
    stock
    yes sir
  16. Nov 25, 2016 at 5:56 PM
    #76
    Heleto
    Sam
    NC
    I placed an order for two NSB-AGM-24F. Planning to use one as a starter battery and another for applications in cab. I did some research and I found that deep cycle battery can be used as a starter battery without a problem. Am I wasting money here just ordering another 24F instead of just getting a regular starter and better off with it?
    @Digiratus you mentioned about using two 24Fs too. Is one of them used as a starter battery. Could you please share your experience?
    ramonortiz55[OP] likes this.
  17. Nov 25, 2016 at 6:17 PM
    #77
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, the Northstar AGM can easily handle starting duties and also be used in deep discharge situations like a second battery on a expo rig.
    On my rig, I have a 24F in the stock location for starting duties and a 2nd 24F mounted in the bed to run the fridge, the Ham, the CB, the stereo amps, the inverter and powers all my bed lights and RTT accessories.
  18. Nov 25, 2016 at 6:27 PM
    #78
    ramonortiz55
    Ramon
    Texas
    stock
    how did you keep it in place?
  19. Nov 25, 2016 at 6:29 PM
    #79
    Digiratus
    Roaming the PNW
    The RedHead
    Which one? Main or house?
  20. Nov 25, 2016 at 6:30 PM
    #80
    ramonortiz55
    Ramon
    Texas
    stock
    the one n the bed
