CLOSED: NST TRD/ Magnuson 4.0 supercharger lightweight billet crank pulley | crank dampner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 21, 2019.
  1. Jul 8, 2019 at 8:50 PM
    #321
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    FWIW.. hold you.haha
  2. Jul 8, 2019 at 8:52 PM
    #322
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I love being held! No homo.
  3. Jul 8, 2019 at 8:54 PM
    #323
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No promises.
  4. Jul 9, 2019 at 9:56 AM
    #324
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    at this price point I want in on one
  5. Jul 9, 2019 at 10:41 AM
    #325
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can add your name to the list but I can't guarantee you that it will be this price at all as there is no word on pricing yet. It is just a semi educated guess.
  6. Jul 9, 2019 at 11:02 AM
    #326
    garciav
    Houston, TX
    TRD SC,HPTuners
    sure throw my name on there, let see where this goes..
  7. Jul 9, 2019 at 11:18 AM
    #327
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Added
  8. Jul 9, 2019 at 3:05 PM
    #328
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    What is all this Whipple talk?
  9. Jul 9, 2019 at 3:07 PM
    #329
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Just me trying to make it happen. Had some interesting updates that became a dead end.
    12TRDTacoma[OP] likes this.
  10. Jul 9, 2019 at 3:12 PM
    #330
    Roostfactor
    TX panhandle
    Any details of what you are trying to do?
    Our sc housing I dont think could ever reasonably work because both the inlet and outlet ports are completely different for a screw compressor.
  11. Jul 9, 2019 at 3:18 PM
    #331
    GT7
    Grant
    Phoenix
    2013 DCLB
    Just exploring all the options. Emailed whipple and didnt get far. Found the guy out of california that designed gadgets for the dual vvti, on a facebook post from 2011. I asked if he could help and he just fowarded my email to gadget after I told him I explicitly did not want to conduct any business with urd.
    If you look up the tundra whipple, the pulley and intake location look desireable. I just need them to sell me that case and ill get it attached
    Roostfactor[QUOTED] likes this.
  12. Jul 9, 2019 at 3:26 PM
    #332
    Roostfactor
    TX panhandle
    Damn that would pish me off!
    I'll check out the Tundra Whipple.
    Really like your idea!
    TRON and GT7[QUOTED] like this.
  13. Jul 9, 2019 at 3:30 PM
    #333
    GT7
    Grant
    Phoenix
    2013 DCLB
    So you could have a bolt on 76mm throttle body which would be nice
  14. Jul 9, 2019 at 3:30 PM
    #334
    Waited many moons
    Waited many moons Well-Known Member
    Pat
    Honolulu, Hawaii
    2014 Alaska Edition
    I haven't done anything with my set up. Sounds like this would benefit me without sizing down the pulley, etc...
  15. Jul 9, 2019 at 3:43 PM
    #335
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You will require a new tensioner and new dual bearing roller to go with it in order for it to work though.
  16. Jul 9, 2019 at 5:12 PM
    #336
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    why's that?
  17. Jul 9, 2019 at 6:20 PM
    #337
    ThomasMore66
    Dallas/Fort Worth & Durango
  18. Jul 9, 2019 at 6:25 PM
    #338
    GT7
    Grant
    Phoenix
    2013 DCLB
  19. Jul 9, 2019 at 6:26 PM
    #339
    ThomasMore66
    Started following Harrop after I got their elockers in both of my 80’s. Awesome equipment.
  20. Jul 9, 2019 at 11:58 PM
    #340
    Waited many moons
    Pat
    Honolulu, Hawaii
    2014 Alaska Edition
    Any special brands, where would I purchase these parts?
