CLOSED: NST TRD/ Magnuson 4.0 supercharger lightweight billet crank pulley | crank dampner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 21, 2019.
  1. Jul 11, 2019 at 7:01 AM
    #381
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I figure, like a couple have previously stated.....it’ll get me to the 2.7 pulley statistical figures while keeping my 2.825 and current belt.
  2. Jul 11, 2019 at 7:02 AM
    #382
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's a smart move for anyone wanting to up boost but not step down pulley sizes for slippage prevention. Even a small increase in size of the crank pulley will negate some of the most annoying slippage.
  3. Jul 11, 2019 at 7:07 AM
    #383
    ThomasMore66
    Dallas/Fort Worth & Durango
    You've been wanting to come to Texas, right?
  4. Jul 11, 2019 at 7:57 AM
    #384
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    It’d be worth the trip if I could get the cams done, retuned with HP and whatever else could be done.....
  5. Jul 11, 2019 at 11:01 AM
    #385
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Good to hear!!!!! :)
    I need to get on the ball and order a tensioner and pulley.
  6. Jul 11, 2019 at 11:20 AM
    #386
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You have good time to do so!
    I am inquiring of incorporating the RIP mod to each pulley that will be built for us for some added grip down at the crank. I am currently not sure if that will be able to be realized in the final production as apparently it takes a long time, but we'll see.
    BassAckwards, Wild Heart and GT7 like this.
  7. Jul 11, 2019 at 11:37 AM
    #387
    feesquivel
    feesquivel Well-Known Member
    West Texas
    Im in, depending on final price.
    12TRDTacoma[OP] and garciav like this.
  8. Jul 11, 2019 at 11:38 AM
    #388
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I don’t think it would really be necessary for the rip mod on the crank pulley. I imagine it would increase the belt wear also. Just my opinion, but I am perfectly fine with having the top pulley the only rip mod.
    Edit: also thinking about it more, I don’t think the crank pulley is going to slip with how much surface area has belt on it, the top pulley should be the biggest problem for belt slip being as the belt isn’t making as large of a contact patch.
  9. Jul 11, 2019 at 12:12 PM
    #389
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    How are y'all doing the RIP mod to pulleys ? I have a URD stealth pulley I need to throw on the truck and wanted to do this to help with slippage
  10. Jul 11, 2019 at 12:19 PM
    #390
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I went through smoothflowpulleyes. He adds them in for an extra like $10 or $15.
  11. Jul 11, 2019 at 12:29 PM
    #391
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Added.
    It's just an option we may be able to have. Since every pulley will be done the same we would all have to be in agreeance with it, but it already sounds like it is going to be 86'ed... So as long as you guys are aware of the option to do so it wouldn't hurt.
    Belt wear is not a thing with the mod, but when there is slippage that causes belt glazing on the ribs which accelerates wear for sure.
  12. Jul 11, 2019 at 12:32 PM
    #392
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I took a dremel to about 3 of mine now without issue. first with the 2.7, then the 2.6 now the 2.5. Just need a good bit for the dremel, shouldnt have any problem grinding through some of the aluminum
    Edit: im too cheap to get nate to machine it on my pulleys, and i wanted to be able to choose how many rips to put on there as well.
  13. Jul 11, 2019 at 12:35 PM
    #393
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You cheapass. ;) :D
    (I did the same thing to my 2.5 as well)
    BassAckwards[QUOTED] likes this.
  14. Jul 11, 2019 at 12:35 PM
    #394
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I’m not totally against it, I just don’t know that it is really needed w/ the crank pulley. But then again it would be even slightly more weight reduction... decisions decisions
  15. Jul 11, 2019 at 12:40 PM
    #395
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have seen many supercharger aftermarket billet crank pulleys with the mod integrated that's why I mention it. There is a reason why they are doing it and since we are designing a whole new pulley now is our chance to address the shortcomings of the supplied unit with the supercharger kit.
  16. Jul 11, 2019 at 12:43 PM
    #396
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Belts are cheap lets just do it
  17. Jul 11, 2019 at 12:45 PM
    #397
    BassAckwards
    i agree, im on board for rips on the crank pulley
    Great minds think alike :D
    :cheers:
  18. Jul 11, 2019 at 12:54 PM
    #398
    12TRDTacoma
    Rob
    Concordia
    Boosted
    We have to keep in mind that this mod integration is entirely pending, as we are not sure if they will even be able to do it for us and if they can we are not sure if it will drive cost up or not.
  19. Jul 11, 2019 at 1:54 PM
    #399
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hey @Roostfactor you should join in on this GB. You know you wannnaaaaaaa! :)
  20. Jul 11, 2019 at 2:00 PM
    #400
    420taco
    420taco Well-Known Member
    Justin
    PA
    Put me down for one...
