CLOSED: NST TRD/ Magnuson 4.0 supercharger lightweight billet crank pulley | crank dampner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 21, 2019.
  1. Oct 26, 2019 at 9:24 AM
    #821
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I'll stay with the light oem size supercharger pulley. Also did anyone get a confirmation email from nst? Still waiting on mine.
  2. Oct 26, 2019 at 9:27 AM
    #822
    Lucario Runner
    Robert
    06 Toyota 4Runner
    The set I ordered last year had an alt pulley i couldn't use. I would suggest you type in non xrunner alt if they still make two different pulleys. That is what i did in the notes.
  3. Oct 26, 2019 at 9:47 AM
    #823
    Barbietaco
    Barbietaco Tools are good
    Shane
    2006 Tacoma
    Sas swap with Dana 60 and GM 14 bolt rear on 42" Pitbulls
    Can a person still get on the list for the pulley set?
    12TRDTacoma[OP] likes this.
  4. Oct 26, 2019 at 10:19 AM
    #824
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
  5. Oct 26, 2019 at 10:25 AM
    #825
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I got an email from them
  6. Oct 26, 2019 at 11:27 AM
    #826
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Sure can! I'll add you shortly.
    I'll update you shortly. :thumbsup:
  7. Oct 26, 2019 at 1:07 PM
    #827
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
  8. Oct 26, 2019 at 4:11 PM
    #828
    Laoturk
    Laoturk Well-Known Member
    Huntington Bch
    2013 tacoma LB
  9. Oct 26, 2019 at 6:39 PM
    #829
    12TRDTacoma
    Rob
    Concordia
    Boosted
    All,
    Remember not to sit on this too long for the NST crank dampner portion of this group buy. You have until the 4th to send payment for the 33% off discount. All who submitted their name initially for this GB, go pay before the deadline as it cannot be extended.
  10. Oct 26, 2019 at 6:59 PM
    #830
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I may call them and switch to a full set. The peer pressure is ruthless in here. I will let you know.
  11. Oct 26, 2019 at 7:03 PM
    #831
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Same, I was under the impression that the alt pulley would not fit
  12. Oct 26, 2019 at 7:19 PM
    #832
    Lucario Runner
    Robert
    06 Toyota 4Runner
    ^see attached pic
  13. Oct 26, 2019 at 9:22 PM
    #833
    nudavinci64
    Robert
    As someone else mentioned I just dropped a note that I need the non xrunner version that I have a tow package. Hopefully that helps for the alt.
    TodayWasTHeDaY likes this.
  14. Oct 27, 2019 at 12:06 AM
    #834
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So wait, on the NST website, is the full pack for all stock pulleys? or the SC pulley + alternator and water pump pulleys?
  15. Oct 27, 2019 at 5:01 AM
    #835
    chank
    chank Member
    Colorado
    07 DCLB
    Is it too late to be added to the list for a full set?
  16. Oct 27, 2019 at 5:55 AM
    #836
    zippsub9
    Halfmoon, NY
    14 DCLB
    As long as you pay and include all the appropriate notes to NST prior to 4 NOV them you are good.
  17. Oct 27, 2019 at 5:56 AM
    #837
    zippsub9
    Halfmoon, NY
    14 DCLB
    All stock pulleys on the NST website. The SC pulley is still in development with them and pricing should come out soon.
  18. Oct 27, 2019 at 10:19 AM
    #838
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I ordered the full kit also :bananadead:
  19. Oct 27, 2019 at 10:20 AM
    #839
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I have the full kit already. Waiting for supercharger pulley ordering details.
  20. Oct 27, 2019 at 10:24 AM
    #840
    TodayWasTHeDaY
    Russ
    Calgary
    Does your alt pulley look like it'll work? Tow package alternator?
