CLOSED: NST TRD/ Magnuson 4.0 supercharger lightweight billet crank pulley | crank dampner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 21, 2019.
  1. Oct 31, 2019 at 3:09 PM
    #881
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Going to be very little if any fuel gains with these. You'll see more fuel gains with a tune and or cam gears.
  2. Oct 31, 2019 at 4:27 PM
    #882
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    A belt that last 100K is not junk! ;)
  3. Oct 31, 2019 at 4:28 PM
    #883
    TRON
    Just better throttle response
  4. Oct 31, 2019 at 5:40 PM
    #884
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You must had gotten lucky or something because at less than 10K miles I was finding cracks on the belt already. This trend continued with every other Dayco belt I ran on the blower thereafter.
    This is not an isolated incident either, many other vehicles I have worked on which just recently had their belts replaced (I'm talking accessory and T belts, not even blower equipped) which were already cracking were Dayco belts. Either they must not rotate their supply often or Toyota used to use a different supplier and sometime in the supercharger run they switched up belt supplier manufacturers.
  5. Oct 31, 2019 at 10:32 PM
    #885
    TRON
    I hear you but I’m not talking about SC belts whatsoever. The stock serpentine drive belts for tacomas are great and the percentages are high they can go over 100k. Regardless, NST is selling RPM drive belts sized for our 1GR-FE engines which is my point ;)
  6. Nov 1, 2019 at 8:39 AM
    #886
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Just bought one with the Halloween discount. Might as well do a new higher quality belt when all the pulley bling gets installed. :woot:
  7. Nov 1, 2019 at 9:19 AM
    #887
    TRON
    Yup :thumbsup:
  8. Nov 1, 2019 at 10:32 AM
    #888
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh yeah the OE belts for the accessory drive are of outstanding quality. I am in full agreeance with that one! :)
    zippsub9 likes this.
  9. Nov 2, 2019 at 11:44 PM
    #889
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
  10. Nov 3, 2019 at 6:02 AM
    #890
    mightytacoman
    Kel
    4.5L 1grfe
    Tomorrow the last day to get in on this deal I do believe. Any word on pricing, how to order the supercharger crank pulley yet?
  11. Nov 3, 2019 at 8:47 AM
    #891
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not yet. I should have some info later this coming week if all goes well.
  12. Nov 3, 2019 at 8:51 AM
    #892
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Athlaos and nudavinci64 like this.
  13. Nov 3, 2019 at 9:51 AM
    #893
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Order placed. Full kit. Tow package. Gold Ano.
  14. Nov 3, 2019 at 2:44 PM
    #894
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    Paid!
    x2 Sets - Full Kit w/ Tow Package - Black & Blue
    12TRDTacoma[OP] likes this.
  15. Nov 3, 2019 at 2:46 PM
    #895
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Paid for full set, they cancelled my crank only order.
  16. Nov 3, 2019 at 7:07 PM
    #896
    sf.larry
    sf.larry Well-Known Member
    larry
    2011 XR
    Just ordered the black crank pulley. If anyone's interested in an unused red one PM me.
  17. Nov 4, 2019 at 8:39 AM
    #897
    frantic
    frantic Member
    @12TRDTacoma - I paid for the full set. Thanks for putting this GB together!
    nudavinci64 and 12TRDTacoma[OP] like this.
  18. Nov 4, 2019 at 8:47 PM
    #898
    12TRDTacoma
    Rob
    Concordia
    Boosted
    UPDATE!!! SUPERCHARGER CRANK PULLEY GB IS NOW LIVE AND ACTIVE!
    Hi Roberto,
    Thank you for the continued interest and support, we appreciate it. Per
    our discussions regarding your request for a 1GR TRD SC Crank Insert
    Ring, we can offer you and your GB members pulleys in your choice of
    color: Red, Blue, Gold, Black, Purple.
    Such a pulley would normally cost as much as $248.00, we're prepared to
    offer each GB member a pulley at $148.00 based on your estimate of 30
    members, shipping included. Each pulley will be OEM diameter with extra
    holes added for further weight reduction.
    Each member will need to make payment here, no promo code necessary:
    https://www.shopnonstoptuning.com/store/p140/SpecialOrderCustomNSTpulleys.html
    Each member will need to include a NOTE WITH THEIR ORDER to indicate
    COLOR choice and FORUM SCREEN NAME for -PAID TAG- documentation.
    PRICE: $148.00
    DEADLINE: November 15, 2019
    LEADTIME: 40-50 days
    Machining and anodizing will begin AFTER all members have paid, in MID
    NOV, if all members make payments by the NOV 15 deadline (deadline can
    not be extended) and will require approximately 40 to 50 days. We're
    offering an extra large discount, free shipping, and choice of color in
    exchange for members' patience and support during this process.
    Each member will receive order confirmation emails and will also receive
    email updates and tracking info as they become available during the
    process.
    Thanks again, best of luck with all your projects!
    NST - NonStopTuning
    www.NonStopTuning.com
    est 2005
    TodayWasTHeDaY and zippsub9 like this.
  19. Nov 4, 2019 at 9:22 PM
    #899
    TRON
    Curious about this so call insert ring? I don’t think the NST overdrive kit came with one. I do remember having to tap out the steel pin from the TRD pulley and install it into the NST one.
    Any idea when the other pulley GB will start shipping?
  20. Nov 4, 2019 at 9:38 PM
    #900
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Pardon my lack of SC knowledge but how does this fit in to the current NST complete kit and the pending supercharger lightweight billet crank pulley | crank dampner?
