CLOSED: NST TRD/ Magnuson 4.0 supercharger lightweight billet crank pulley | crank dampner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 21, 2019.
  1. Jan 27, 2020 at 7:46 PM
    #1221
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Okay, well, I finally am happy to report that I WILL have an update for you guys in the coming few days at most regarding this GB. I am not able to say more at this exact moment until I get a green light from NST, which should be tomorrow.
    I WILL say, however, that like a few of you, I got the wrong alternator pulley as well. :(
    That was sort of a good and bad thing though because I found out that my seprentine belt for the accessories has a nice big split in the outside rib. So I have to go back in there to replace the belt sometime soon anyways.
  2. Jan 27, 2020 at 8:40 PM
    #1222
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Its unfortunate and unlikely they will ever do PS pulleys for us again. They only did like 5 xrunners to begin with.
    Hahaha!! Nice!! That pic is well over 10 years old! Where are the peanut M&Ms:rofl:
    Torspd and SUMOTNK[QUOTED] like this.
  3. Jan 27, 2020 at 8:50 PM
    #1223
    TRON
    Anybody know the right process of machines on how one could make this red pulley have cut outs like the grey one?
    I presume there would be a cad drawing in the end for the CNC machine to mimic?
  4. Jan 27, 2020 at 10:14 PM
    #1224
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    True but you never know with 30 some on SC pulleys sold here and another 20 or so kits might be able to swing it. They have to still have the CAD file laying around. Maybe my beater honda needs some lighter pulleys for those traffic jam burn outs... :bananadead:
  5. Jan 27, 2020 at 10:24 PM
    #1225
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So what's the deal with the crank dampner a and their steel sleeve insert? I notice a groove in mine, and the past few times I have pulled out the main bolt I have found oil on it.. no immediate signs of leakage anywhere just in there particularly. It's sort of weird. I'm trying to figure out if I should be concerned or not.
  6. Jan 28, 2020 at 5:38 AM
    #1226
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    What's the weight difference between them? Is the stock one with cutouts steel? I wouldn't risk the cutouts on an aluminum pulley myself.
    BassAckwards likes this.
  7. Jan 28, 2020 at 6:10 AM
    #1227
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Have you guys received your crank pulleys yet?
    I have not - wonder if I need to shoot them an email.
  8. Jan 28, 2020 at 6:12 AM
    #1228
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Nobody yet. Robert is handling a single point of communication and will get clearance to release an update in the next 24-48.
  9. Jan 28, 2020 at 6:16 AM
    #1229
    Scott B.
    Scott
    Georgia
    Very good.
    Thanks for the update - I asked because I didn't want to bombard them with unnecessary emails.
    zippsub9[QUOTED] likes this.
  10. Jan 28, 2020 at 6:18 AM
    #1230
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Preferably a CAD drawing, although we can make due without one. We would just reverse engineer the pulley, draw up the Tooling Geo for it, and program the CNC to machine those features. That would definitely be 5-Axis job, but I would be concerned with rigidity not only during the machining process, but afterwards as well.
    ideally, that would all be done at the same time in the lathe. but you need the right lathe to be able to do turning work, as well as milling, which we have. again, since its billet aluminum, not sure how well those reliefs would work.
    TRON[QUOTED] likes this.
  11. Jan 28, 2020 at 7:24 AM
    #1231
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    For example.. no model for these cast Bronze valves im working on now. So I just use the drawing and measurements of the casts themselves, and create Geometry and toolpaths based off of said geometry. Little more difficult, but definitely doable.
  12. Jan 28, 2020 at 7:29 AM
    #1232
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You greased the seal right?!?!
  13. Jan 28, 2020 at 7:31 AM
    #1233
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Didn't realize I had to in order to install a new pulley on it. I've literally never done that before on any other crank pulley install and I've always been fine. Of course when installing the new seal I always did put a little grease on it so it would go in easily.
  14. Jan 28, 2020 at 7:33 AM
    #1234
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well if you have it off again, or anyone about to install the new crank pulley, grease the seal and or the sleeve. :thumbsup:
    Murphinator likes this.
  15. Jan 28, 2020 at 7:44 AM
    #1235
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Damn. I literally just had it off too. I'm assuming you use some high speed bearing grease or will silicone paste suffice?
  16. Jan 28, 2020 at 7:47 AM
    #1236
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I just used wheel bearing grease. Doesn't take much, and helps tremendously.
  17. Jan 28, 2020 at 7:57 AM
    #1237
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I appreciate for the pro tip Mr. Mark. :) :thumbsup:
  18. Jan 28, 2020 at 7:57 AM
    #1238
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tor :p :cool:
    TRON likes this.
  19. Jan 28, 2020 at 8:11 AM
    #1239
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Nvr. :D
    No, but on a serious note, noted. :)
    Torspd[QUOTED] likes this.
  20. Jan 28, 2020 at 9:57 AM
    #1240
    TRON
    What made you take the crank off?
