CLOSED: NST TRD/ Magnuson 4.0 supercharger lightweight billet crank pulley | crank dampner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 21, 2019.
  1. Jul 3, 2019 at 3:47 PM
    #141
    ThomasMore66
    Dallas/Fort Worth & Durango
    Will the Steada tensioner work? That’s what I have.
  2. Jul 3, 2019 at 3:49 PM
    #142
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That's over 3.5lbs removed from the OE unit! :eek:
    My guess would be something around 2.5- 3 lbs due to the fact the pulley is not impregnated with rubber like the OE crank accessory dampner is.
  3. Jul 3, 2019 at 3:50 PM
    #143
    12TRDTacoma
    Rob
    Concordia
    Boosted
    As long as you can fit the LFP dual bearing roller on it you'll be good to go.
  4. Jul 3, 2019 at 4:14 PM
    #144
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Jeez Im behind. I didnt realize the rousch tensioner was $133. The link in the main thread says 05-10 GT. Correct version?
  5. Jul 3, 2019 at 4:48 PM
    #145
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yep. Parts from 5th gen Camaros, 2005-2016 Mustangs, F-150s, Explorers, and Expeditions all fit our trucks. Lol.
    Cheap, yet effective and bulletproof mods FTW bro!
    GT7[QUOTED] likes this.
  6. Jul 3, 2019 at 6:47 PM
    #146
    ThomasMore66
    I am not grasping why we need the different wheel on the tensioner.
  7. Jul 3, 2019 at 6:50 PM
    #147
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Because if we are going to go for an overdrive crank pulley the design is already within it's limitations without interference in it's OE form. If we shave a good .170 (or whatever it was) off of the idler pulley, then we have room to play with sizes which will effectively increase our boost capabilities.
    It's basically moving physical sizing which causes interference issues and moving it all towards the largest rotational part, but we need to clear the space in order to go larger.
    lawless likes this.
  8. Jul 3, 2019 at 7:16 PM
    #148
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am curious to hear from @TRON if he had to change his idler pulley for his NST supercharger crank pulley? Not saying we won't have to. Just wondering how NST pulled it off
  9. Jul 3, 2019 at 7:32 PM
    #149
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Their old system provided an overdrive crank pulley and a series of other pulleys which were smaller than OE size in order to compensate for the new larger size of the crank pulley.
    Of course the fallacies of their system is that they used cheap Chinese bearings which would junk real fast leaving the system useless unless you spent more money on the setup on quality bearings.
    The only thing needed here is a smaller tensioner pulley, not an intricate setup of other pulleys like they were doing.
    Murphinator[QUOTED] likes this.
  10. Jul 3, 2019 at 7:43 PM
    #150
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    This^^^^^
    It's been happening to me a ton lately, across a bunch of threads here.
    I'm totally in for the bigger pulley. I need to do the tensioner anyway. Anyone have a part number for this 50mm yall keep talking of...
  11. Jul 3, 2019 at 7:45 PM
    #151
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Page 1 of the reference thread my man. It's all there. Kind of like the YouTube Red commercials. :D
  12. Jul 3, 2019 at 7:51 PM
    #152
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    I'll go and haze myself. I knew I should have looked there, but I was being lazy. :facepalm:
    Also... Good for a larger unit, cause what guy doesn't want a larger unit!?
  13. Jul 3, 2019 at 7:59 PM
    #153
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yup. I think the kit included a smaller idler pulley on the tensioner and a fan pulley in order for the NST SC crank pulley to physically fit. Everybody changed out the one idler bearing to ceramic cause that pulley is spinning pretty fast.
    12TRDTacoma[OP] likes this.
  14. Jul 3, 2019 at 8:32 PM
    #154
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Will this larger supercharger crank pulley be compatible with the NST crank pulley? Cause if I went in there to change the one, I would want to change the other while I'm at it.... a reduction of 56oz of main crank is quite a bit.
  15. Jul 3, 2019 at 9:23 PM
    #155
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The supercharger crank pulley is designed to fit on top of the crank dampner. I currently run an NST crank dampner pulley without issue. When these supercharger pulleys get made, they will be designed with a mounting surface virtually identical to the supercharger one so it will all fit up properly.
    I'm going to require that you haze yourself twice. Once you have done so and have learned your lessons then you can come back fresh into these conversations. Lol. :D
  16. Jul 4, 2019 at 10:47 AM
    #156
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Watcha wait’n for?
  17. Jul 4, 2019 at 12:12 PM
    #157
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @JustDSM you good with a larger crank pulley? Though I know you don't have a supercharger. Lol.
  18. Jul 4, 2019 at 12:23 PM
    #158
    ThomasMore66
    I feel he’ll join us soon.
  19. Jul 4, 2019 at 12:27 PM
    #159
    ThomasMore66
    Those of us with the 2.5”, I'm not sure we’ll actually move more air which is the key to more hp. We’re near the edge of efficiency on the Magnuson. @JustDSM reiterated this the other day.
    JustDSM likes this.
  20. Jul 4, 2019 at 12:31 PM
    #160
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Depending on the price, but I'm sure I'll be able to unload it if I end up staying N/A. :)
