CLOSED: NST TRD/ Magnuson 4.0 supercharger lightweight billet crank pulley | crank dampner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 21, 2019.
  1. Jul 4, 2019 at 12:44 PM
    #161
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    My 2.3 would disagree with this statement. The MP90s max RPM efficiency limits is somewhere around 18,000 if I remember correctly. It's been a long time since I looked into that.
    I'll update you on the list. :D
    BassAckwards likes this.
  2. Jul 4, 2019 at 2:02 PM
    #162
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    My 2.3 definitely has more jam than my 2.5. I'm also at elevation though so efficiency might be the same as a bigger pulley at sea level.
    BassAckwards, 12TRDTacoma[OP] and GT7 like this.
  3. Jul 4, 2019 at 2:54 PM
    #163
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am at sealevel and I can say firsthand my 2.3 definitely shows a largely notable jam over the 2.5.
  4. Jul 4, 2019 at 3:04 PM
    #164
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Airflow at peak rpm between the 2.3’s and 2.5’s are surprisingly similar. In the midrange that’s another story.
  5. Jul 4, 2019 at 3:22 PM
    #165
    TodayWasTHeDaY
    Russ
    Calgary
    My butt dyno agrees with that assessment. It absolutely spools up quicker
    12TRDTacoma[OP] and BassAckwards like this.
  6. Jul 4, 2019 at 4:02 PM
    #166
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting. That makes a lot of sense and I can see that being very true. It is a lot faster at mid rev.
    Hell yeah brother!
    Sorry, I was just dying to say that. :D
  7. Jul 5, 2019 at 8:52 AM
    #167
    12TRDTacoma
    Rob
    Concordia
    Boosted
  8. Jul 5, 2019 at 9:08 AM
    #168
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm in process of reading this entire thread. Add me to the list. I have a few other spendy mods I'm working on so any delay in payment would help.
  9. Jul 5, 2019 at 9:12 AM
    #169
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Right now we are still in the R process of the R&D for it... It's a slow going thing because the pulley we want to replicate is obviously on the trucks and since it is a main pulley which is not easily replaceable it is not just as easy as like oh okay let's pull it off and measure it. No we still need to get a CAD of it and then we can start tweaking with the design for further lightening purposes. And CAD is past my skillset.
    I thought I had some CAD files for it, but it turns out I had some Hilux files which funny enough are of the 6 rib pulley style design and it is uncertain weather or not it was a dampner drawing or a supercharger pulley itself.
  10. Jul 5, 2019 at 9:14 AM
    #170
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Past my modding needs for now but enjoying the show. :popcorn:
    @12TRDTacoma Wouldn't this also act similar to a lightweight flywheel which can have negatives as well as positive? Or is there enough other counter weight on crank itself?
    EDIT: Second question since it was deemed not a stupid question.
    70 oz vs 14oz is a big jump in weight but is there any normal resistance added to the motor just by adding the S/C? For example if the S/C adds some resistance to the crank that wasn't already there (maybe rough estimate of rotational mass of the blower blades? ) maybe the jump in weight isn't as bad on the crank as suspected???
  11. Jul 5, 2019 at 9:21 AM
    #171
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Good question
  12. Jul 5, 2019 at 9:24 AM
    #172
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm in process of tracking down a contact my dad gave me. He has watched this guy take a billet block and make a custom high rise intake manifold for a race engine.
    No guarantee but this guy sounds like he potentially has the means to get this done.
    FWIW I'm in favor of the extra effort in a 6 rib design.
  13. Jul 5, 2019 at 9:36 AM
    #173
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Same. It can be done
  14. Jul 5, 2019 at 9:37 AM
    #174
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The dampner and the supercharger crank pulley are one once unified on the setup. It is mostly redundant to run one lightweight billet and the other pot metal as the effects of the lightweight design are mostly counteracted due to the additional weight being added to it. By lightening 100% of the pulley setup it allows for a setup faster revving as a whole and as long as both are balanced and designed correctly there is no need to worry about any further issues.
    This would not have the negatives of a lightweight flywheel as the flywheel is a large major rotational component in the assembly. As long as the crank dampner is correctly balanced, the rest is all gravy.
    You are correct, this would be similar to a lightweight flywheel in theory, not in size of course.
    I hope I answered the questions for you.
    6 rib is WAY more trouble than it is worth. I and we have investigated it. Trust me, you won't be happy and will spend a ton of money venturing after a fruitful mod which will deem ultimately fruitless.
  15. Jul 5, 2019 at 9:40 AM
    #175
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ok. 5 rib is fine too. I'm getting pretty good at cutting belts anyway.
    BassAckwards and 12TRDTacoma[OP] like this.
  16. Jul 5, 2019 at 9:41 AM
    #176
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @Murphinator had a good idea about pooling funds to buy a s/c drive pulley for this. Where are we on that? We could always put it up for sale on ebay when we're done to reclaim funds.
    12TRDTacoma[OP] likes this.
  17. Jul 5, 2019 at 9:44 AM
    #177
    12TRDTacoma
    Rob
    Concordia
    Boosted
    With a larger pulley there would be less need for all these grip mods as the main crank pulley now gains better belt wrap on and since that is where the major wrap is occuring, increasing the size will always increase the wrap in the process along with a side effect benefit of additional boost added.
    A new crank pulley would be some $130 with a wait time of a week from Magnuson direct.
    If we had a bare pulley which is off truck it would be easier for @XPOTRPR to make the measurements and CAD needed to move forward with this, however, I sort of see this as a pointless expense since we all have the pulley already.
    We have to exercise patience here because we are now approaching mods which have never been previously done before.
  18. Jul 5, 2019 at 9:47 AM
    #178
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Patient I can be. Just looking at it so nobody had down time on their truck. If 10 guys pitched 15$ it might seem light in expenses for all.
  19. Jul 5, 2019 at 9:51 AM
    #179
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have talked to XPO and he has no issue with (and is willing to) taking his truck apart for a bit to take some measurements, photos, and CAD stuff. He did say it would be a little bit though because he has been out of town so we are at his mercy new pulley or not. It's really just a waiting game.
  20. Jul 5, 2019 at 5:54 PM
    #180
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm so glad one of the 3 gb I'm down for has a little patience. My credit score thanks y'all
