[Closed] Offroading water damage in a brand new Taco!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by islandhiker, Jul 26, 2021.
  1. Jul 27, 2021 at 6:21 AM
    #61
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Fair enough. Just didn’t want you to get carried away ripping your truck apart only to realize later it was the gas tank.
  2. Jul 27, 2021 at 6:22 AM
    #62
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    My wife is an RN and she always tells people that if you go on line for anything medical only trust Mayo Clinic site, nothing else.
    As far as your truck ,I understand...we all did that. I followed a group of modified Tacoma's and Jeep's once...made but I was nervous, stock tires on a stock OR edition...
  3. Jul 27, 2021 at 6:22 AM
    #63
    islandhiker
    islandhiker [OP] Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Thankyou for the suggestion though!
  4. Jul 27, 2021 at 6:23 AM
    #64
    islandhiker
    Calgary, AB
    Its so easy to get carried away with it! "Yeah I've got a TRD off road tacoma! I can do anything...."
    Pwl and DAS Taco[QUOTED] like this.
  5. Jul 27, 2021 at 12:20 PM
    #65
    DAS Taco
    DAS
    2017 TRD Offroad
    Exactly, I did ok but I could have easily gotten in trouble :)!
  6. Jul 27, 2021 at 12:40 PM
    #66
    islandhiker
    Calgary, AB
    So I've had a small world moment! whilst out on the trail I stopped to help a flipped ATV rider and his daughter, they were both fine and I helped them roll their ATV and be on their way. Turns out the drivers brother is a mechanic, who I happened to call today to get my truck looked at! Tomorrow at 9am they will have a look and if nothing expensive needs doing they will do so for free! (he didn't sound too alarmed by what I had described). Anyways, I think that about wraps things up. Thankyou all for amusement/advice/reassurance.
  7. Jul 27, 2021 at 12:57 PM
    #67
    4x4spiegel
    4x4spiegel Well-Known Member
    Karma , yes !!!
  8. Jul 27, 2021 at 1:03 PM
    #68
    604
    604 Well-Known Member
    2002 Lincoln Navigator V8
    good stuff =)
  9. Jul 27, 2021 at 1:21 PM
    #69
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Totaled
    islandhiker[OP] and MilkDud like this.
  10. Jul 27, 2021 at 4:34 PM
    #70
    islandhiker
    Calgary, AB
    Found some drainage plugs underneath and a whole bunch of crappy water came out, gonna drive around for a bit and give it a clean water rinse tomorrow.
    xxTacocaTxx likes this.
  11. Jul 27, 2021 at 5:44 PM
    #71
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    a tacoma dying doing what it loved
  12. Jul 27, 2021 at 5:44 PM
    #72
    myn75
    Nor Cal
    how long were you in the water for? a 'dunk' or a wade or a full on swim?
  13. Jul 27, 2021 at 6:14 PM
    #73
    islandhiker
    Calgary, AB
    I'd say 45sec-1min water just over the running boards. A wade I suppose? I see you own a 2021 also, please learn from my error and take it easy! I'll post a picture of the drainage plugs later if you'd like in case you run into the same issue.
    DAS Taco, myn75[QUOTED] and Junkhead like this.
  14. Jul 27, 2021 at 8:20 PM
    #74
    myn75
    Nor Cal
    well if i am to be honest i also took mine thru some puddles on a forest road when i had just only 700 mi on it HAHA (was about 6 months ago). it was merely a dunk however and i thought the water came up to the bottom of the doors but my friends said it was only up to about the middle of the wheels. It did indeed make me very paranoid and took awhile to get past it lol
  15. Jul 27, 2021 at 9:33 PM
    #75
    islandhiker
    Calgary, AB
    Lesson learned right!
  16. Jul 28, 2021 at 7:15 AM
    #76
    DAS Taco
    DAS
    2017 TRD Offroad
    Please show us what drain points you found to be plugged.
  17. Jul 28, 2021 at 7:25 AM
    #77
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    With all due respect man, you are thinking way too hard on this.
    Running board height? 1 minute of submersion / moving through the water? That's nothing.
    It's fine.
    My personal benchmark for a problem would be "does my truck run?" A: Yes? Then no problem. Sloshing = ignore.
    gudujarlson and islandhiker[OP] like this.
  18. Jul 28, 2021 at 7:30 AM
    #78
    islandhiker
    Calgary, AB
    You're right man, but I've learned alot from you guys :)
  19. Jul 28, 2021 at 7:50 AM
    #79
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Do you have running boards or tube steps? If tube steps is it possible water is in them?
  20. Jul 28, 2021 at 8:27 AM
    #80
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Wtf
