**CLOSED**Partner Steel Stoves - Group Buy**
Discussion in 'Closed Group Buys' started by ramonortiz55, Mar 28, 2017.
  1. Apr 5, 2017 at 5:14 AM
    #141
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    added your boss to the list.
    MotoEd and ProForce[QUOTED] like this.
  2. Apr 5, 2017 at 9:52 AM
    #142
    CO4Runner
    CO4Runner Active Member
    96 4Runner SR5
  3. Apr 5, 2017 at 3:27 PM
    #143
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    @ramonortiz55 he can take my spot, im withdrawing due to funds going towards new bow
  4. Apr 5, 2017 at 5:39 PM
    #144
    macdadmorgan
    macdadmorgan Clean like ammonia, Sick like pneumonia
    IG@overlandonthefly
    W-Mass
    17 TRDORMT
    Things to get me in over my head
    Waiting on the CPA to see if what side of screwed my taxes land on. Actually considering one of the four burners stoves.
  5. Apr 5, 2017 at 5:44 PM
    #145
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Can you post a copy? Do you know if this is true for the stoves with separating hinges? If so, that would mean there isn't an advantage in allowable pan size by going with the separating hinge.
  6. Apr 6, 2017 at 12:23 AM
    #146
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Sorry. I threw that disclaimer away a long time ago. I just remember it distinctly since it canceled my plans to use a double griddle I already bought across the stove.
    Best thing for you to do would be to call/contact partner steel and confirm.
  7. Apr 6, 2017 at 1:35 AM
    #147
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Have a question, didn't see this mentioned-
    It was mentioning some got in on this the last round, is this group buy going to remain open indefinitely and just keep placing orders as we get people to fill up the list or is there a certain date or a certain amount of people then close?
    If it's a limited opportunity and I can't swing it at this time is there any idea of if/when it will reopen?
  8. Apr 6, 2017 at 5:35 AM
    #148
    ramonortiz55
    Ramon
    Texas
    stock
    payment starts on Monday April 17th and will last one week - until Friday.
    If you don't make payment by then, you are out.
    The GB has no cap.
  9. Apr 6, 2017 at 5:35 AM
    #149
    ramonortiz55
    Ramon
    Texas
    stock
    do it
  10. Apr 6, 2017 at 5:36 AM
    #150
    ramonortiz55
    Ramon
    Texas
    stock
    done
  11. Apr 6, 2017 at 7:19 AM
    #151
    OmegaMan73
    OmegaMan73 Well-Known Member
    Mesa AZ
    2017 Tacoma TRD Sport 4x4
    I'm in for one. A 22".
  12. Apr 6, 2017 at 7:24 AM
    #152
    ramonortiz55
    Ramon
    Texas
    stock
    added
    OmegaMan73[QUOTED] likes this.
  13. Apr 6, 2017 at 12:47 PM
    #153
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Looks like a pretty good turn out.
    Maybe way better than the vendor initially expected. IMO they should reconsider the original proposal of additional discounting since the minimum goal will be met so easily. Otherwise, it seems a little bit like a bait and switch tactic.
    live_discover likes this.
  14. Apr 6, 2017 at 12:54 PM
    #154
    jowybyo
    Joe
    Baltimore, MD
    Huh. The vendor is giving a good deal. Not sure why they would offer more incentive since the incentive would only be to attract more people. But as you pointed out, there are plenty participating as it is. There's no bait and switch since no one has paid yet and everyone is free to not participate.
    Can I get my stove yet?
    tubbsisland, motorick and T4RFTMFW like this.
  15. Apr 6, 2017 at 3:49 PM
    #155
    Admiral_Akbar
    Admiral_Akbar Well-Known Member
    '17
    The vendor was to throw in a free item if it reaches 25 buyers. That was later changed. I'm still cool tho.
  16. Apr 7, 2017 at 11:22 AM
    #156
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    I think some people are forgetting that this GB is directly through Partner Steel, and they don't generally do direct to consumer sales and you have to buy from a dealer.
    The way that I read this GB and @ramonortiz55 can correct me if I'm wrong would be that to qualify to be a dealer you have to order a minimum total amount or product to qualify for wholesale pricing and that by doing this as a group we purchased enough to qualify which is why we are getting the pricing we are. There isn't much deeper of a discount available until the sale stops making sense for PS.
    ramonortiz55[OP] and stroM- like this.
  17. Apr 7, 2017 at 2:31 PM
    #157
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    Put me down for the 22" :thumbsup:.
    Shhhh don't tell the wife.
  18. Apr 7, 2017 at 6:30 PM
    #158
    SUMNRFAM
    SUMNRFAM Well-Known Member
    Wade
    Sac Town
    2012 Tacoma AccessCab 4X4, Pyrite Mica IG @exsplortacoma
    ICON Remote Res Front & UCA's, ICON Remote Res rear shocks w/ Oregon Auto Spring Custom leaf pack; Timbrens; SCS F5 wheels with Falken Wildpeak AT's 285-75-16's; Four Wheel Camper 'Eagle' Camper
    LOVE IT!!!! @jowybyo ,, I have had ours (2 burner 9" with the breakapart hinge) for little over a year,, flame control is fantastic,, folds up and fits in our AluBox kitchen kit along with all our pots pans etc,, comes with a 'y' fitting hose, only thing I need to figure out for ours is a windscreen..
    Go for it!!
    Wade
    @ramonortiz55 will the griddles be available on this?
  19. Apr 7, 2017 at 9:12 PM
    #159
    kruseykruse
    kruseykruse New Member
    Alex
    2014 Tacoma TRD Sport Double Cab
    Husky floor mats soon to be Clazzios
    I am really intrigued by the compact size of the folding 9" two burner stove. I have a husky job box that I use when camping. I try to keep the majority of my gear in this so I can just grab it and go when an impromptu weekend trip comes up. The smaller folding Partner Stove seems like it could live in this box with ease. In the blustery Kansas climate, however, no wind screen could really be a deal breaker. I also have concerns that the hinge could make a griddle unbalanced when stretched across the two burners. Can anybody speak to that?
  20. Apr 7, 2017 at 10:44 PM
    #160
    teamSM
    teamSM Member
    Michael
    2015 TRD Taco
    great job getting this set up. put me down for a 22''er.
    MotoEd likes this.
