CLOSED - REGEAR NOW WITH SIBI BUILT
Discussion in 'Automotive Group Buys' started by socalexpeditions, Apr 17, 2020.
  1. Jun 29, 2020 at 10:57 PM
    #1381
    socalexpeditions
    socalexpeditions [OP] IG: @socalexpeditions
    I agree, time is money. And Riverside straight up is not a fun place to drive to.
    Glad we aren’t having gear related issues. Usually if you have no issues after the heat cycling, you’re good to go. Unless you snap something offroading then it’s all on you haha!
  2. Jun 30, 2020 at 10:18 AM
    #1382
    thelifeaquatic
    thelifeaquatic Well-Known Member
    2018 TRD OR DCSB
    I had an issue.
    Front driver side axle seal. Took it back and they replaced it and everything has been seemingly solid since. Will go check for any leaks or issues again and update if any found. Otherwise gears have been great, some whine at speed and more apparent on decel, not sure how much is too much or to be expected but it’s not crazy loud, similar volume to tire noise but at a higher pitch. Also not sure if they installed the master kit or not as I didn’t watch them do the install. My appointment was May 22nd.
  3. Jun 30, 2020 at 10:20 AM
    #1383
    socalexpeditions
    Waiting on response from Miguel
    SilverSurfer and thelifeaquatic like this.
  4. Jun 30, 2020 at 10:21 AM
    #1384
    socalexpeditions
    I have decel whine too, especially in the 70mph range. Hard to hear over all the wind noise and tires, but its there.
    I’m getting answers about the master kit right now
  5. Jun 30, 2020 at 10:34 AM
    #1385
    Biggums
    Biggums Well-Known Member
    Jade
    SoCal
    Really hard to see the actual number of people who had no issues after install when the majority of the feedback on this post is all about leaks, loud noises, etc.
    socalexpeditions[OP] likes this.
  6. Jun 30, 2020 at 11:26 AM
    #1386
    socalexpeditions
    Because all the people with no issues are happily driving haha. They finished the groupbuy and dipped out of the thread, and I don’t blame them.
    taco_whisperer and TRDCLMB like this.
  7. Jun 30, 2020 at 11:46 AM
    #1387
    roy326
    roy326 Well-Known Member
    Roy
    Southern California
    2020 Tundra/V8 4Rnner/GX460. I do miss my tacoma
    I’m like on the cusp of calling Mario to put my money down, but i need to know that it’s a simple gasket and that the issue can be taken care of by purchasing OEM gaskets.
    Also the post about broken stud was misleading because it was actually a tool that broke not the truck’s wheel stud. Super misleading
    At the end, i want to hear... only three trucks had an issue and all could have been resolved with OEM gasket because (NO BRAINER FIX). The good new is ... no one has any gearing issue meaning they are all getting installed correctly.
    I hope they have a check list, so they can check mark every time they complete a job because everyone will feel better about what is being checked. Heck we can print it and bring it the day of if they aren’t offended.
    Socalexpeditions: Thank you for your time in doing this; i know a group buy can be a pain
    socalexpeditions[OP] and lamjam like this.
  8. Jun 30, 2020 at 1:21 PM
    #1388
    socalexpeditions
    Answer for the Master Kit question:
    “Hey Brotha! Hope all is well.
    We do use install kits, not from Nitro. We buy direct from Timken (OEM) for Toyota application.
    Nitro has gear noise, it’s normal. We have notice it’s a hit or miss. Now the Revolution brand has no gear noise, however the Toyota community is stuck with Nitro and they follow the trend thinking they are the best. I’ve tried to educate or customers so they know. Don’t get me wrong they are a good brand.”
  9. Jun 30, 2020 at 1:21 PM
    #1389
    AgedFlatulence
    AgedFlatulence Well-Known Member
    SoCommiefornia
    16 TRD OR DCSB 4x4 Quicksand
    OVTune 4.88 Kings remote w/adjustment Add a Leaf 2"lift RCI Skids RCI Differential Cover RCI lower A arm covers Demello sliders Snugtop windoors Yakima Skyline TRD Pro Grill knockoff 265r75/16 Falken ATW3 Anytime camera Recovery gear
    I have this as well. Heck I had this stock. I have noticed after more miles on the regear it is getting less noticeable.
  10. Jun 30, 2020 at 1:28 PM
    #1390
    josiemobile428
    josiemobile428 Well-Known Member
    Jake
    18 TRD OR 4x4 DCLB
    Just so I'm reading this right, PWG gets the gears only (not master kit) from Nitro Gear. All the necessary seals they get from Timken.
  11. Jun 30, 2020 at 1:30 PM
    #1391
    jhmw815
    jhmw815 Well-Known Member
    Los Angeles, CA
    2018 Tacoma Trd Pro
    Unfortunately, I do not have much knowledge about cars in general unlike most of you. Unless there is noticeable leak, I won't be able to tell if the job is done 100%.. Honestly, I don't even know why I have to worry about this when I'd invested good about of money to have the professionals do it. I'm at little over 500 miles with gear oil replaced, so far so good. I'm planning to get some work done by RPM garage after July 4th weekend so I might just have them inspect the vehicle for me..
  12. Jun 30, 2020 at 1:30 PM
    #1392
    socalexpeditions
    Yes you are correct.
    That includes all the bearing and other stuff too.
    I’m glad they use Timken seals since they’re higher quality.
  13. Jun 30, 2020 at 1:31 PM
    #1393
    socalexpeditions
    If it works, it works. I’m at 6k miles now. And very hard miles, lots of long mountain passes and I use 4Lo almost everyday.
  14. Jun 30, 2020 at 1:33 PM
    #1394
    josiemobile428
    Jake
    18 TRD OR 4x4 DCLB
    Alright, thanks OP. Appreciate all the communication you're dealing with
  15. Jun 30, 2020 at 1:37 PM
    #1395
    socalexpeditions
    Any other questions?
  16. Jun 30, 2020 at 1:38 PM
    #1396
    socalexpeditions
    Anytime man sorry I’ve been gone without signal
  17. Jun 30, 2020 at 1:47 PM
    #1397
    Biggums
    Jade
    SoCal
    Sorry if this has been answered already, but are they reusing the bearings or using new ones?
  18. Jun 30, 2020 at 1:47 PM
    #1398
    roy326
    Roy
    Southern California
    so if they are using OEM seals, are the leaks that people are complaining about because they re-used old seals by accident? Or is it incorrect installation?
  19. Jun 30, 2020 at 1:50 PM
    #1399
    Biggums
    Jade
    SoCal
    Yeah, didn't really clarify that.
  20. Jun 30, 2020 at 2:17 PM
    #1400
    TRDCLMB
    TRDCLMB Well-Known Member
    2019 Cement TRD Off-Road
    I asked about my old stuff and Carlos told me I could have it or they could toss it for me. Looked like there were old seals and bearings in the pile, but honestly I couldn’t tell you. When I spoke with Miguel I asked and he said everything was being replaced and gave me the list to include bearings. If I’m not doing the work I like to know the details as if I were so I know for the future. I didn’t have a garage At the time otherwise I would have done it myself on a whim and learned the process. I’ve put about as much miles on my truck as SoCal since getting it done with back and forth trips to the sierras with a good amount of decent strain on the diffs and have had zero issues aside from the whinning decelerating from 60-45 mph which from Nitro and the 5.29 mega thread seems to be normal and I kind of have grown to like it. RPMS are lower than the chart shows and I drive around 70-75mph constantly. My local shop who changed the fluids and rotated tires didn’t say anything about over torqued lugs or diff plugs either. If you have some concerns Miguel will address them as he did with me without issues.
    Biggums and socalexpeditions[OP] like this.
