**CLOSED**Round two: OME suspensions - group buy!**
Discussion in 'Closed Group Buys' started by ramonortiz55, Apr 6, 2016.
  1. Apr 12, 2016 at 7:44 AM
    #561
    hardground
    hardground Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    Boy that is a nice looking truck!
    Synergy001[QUOTED] and SCas like this.
  2. Apr 12, 2016 at 7:48 AM
    #562
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    added to the list
    Synergy001[QUOTED] likes this.
  3. Apr 12, 2016 at 7:57 AM
    #563
    hardground
    Massachusetts
    What are all of you doing for bushings?
    I know they only come with one end installed so was thinking of ordering from Wheelers for their bushings.
    How about the other two factory bushings in you shackles?
  4. Apr 12, 2016 at 8:01 AM
    #564
    Warles
    Warles Well-Known Member
    SoCal
    2015 Tacoma TRD,
    OME Suspension, Pelfreybilt bumper & skids
    Check the kit you're ordering. Some of them do come with the rear bushings.
  5. Apr 12, 2016 at 8:07 AM
    #565
    hardground
    Massachusetts
    You may have missed old posts or I may have missed more recent posts but from what I know the kit only comes with 4 of the 8 bushings needed for the springs. Also this does not address the 4 other factory bushings in your shackle. So from what I was told none of the bushings that are in you shackle will come with kit.
  6. Apr 12, 2016 at 8:10 AM
    #566
    4WALKER
    4WALKER Save the manual trans!!!
    1991 4runner 5 speed SR5 4X4
    Dirt
    4runnerssssssssssssssssss
  7. Apr 12, 2016 at 8:20 AM
    #567
    sanchaman
    sanchaman Well-Known Member
    Marco
    04 white TRD 4D tacoma
    upgraded sound system satoshi grill led interior lights new headlights motto metal wheels
    sign me up for the OMETAC04HKS – Tacoma 1998-2004 Heavy Kit -
    @ramonortiz55
  8. Apr 12, 2016 at 9:09 AM
    #568
    Warles
    SoCal
    2015 Tacoma TRD,
    That's what I've been told also, however I called ARB and asked, and then found the attached document (at their direction) which shows the "bushings" are now part of the kit for the kits shown. (Under the 2005-2015 Tacoma listings see "Footnote 1. Kit now includes leaf spring bushing kit.") As the part no. shown is for the rear bushings of the Dakars, and there are two of these part nos. being provided, and supposedly the Dakars come with the front bushings installed, I'm assuming that these are for the rear of the springs...
    This is not meant to be comprehensive, as I was just looking for a kit for my 2015 Taco...
    I'm as curious as you are, and this appears to be a recent change, as the catalog is a December 2015 catalog.
    Norton and hardground[QUOTED] like this.
  9. Apr 12, 2016 at 9:10 AM
    #569
    Tiger14
    Tiger14 Resident Defector
    Kevin
    Charleston, SC
    2014 Ford F250 Crew Cab KR 6.7PSD
    @hardground on the first page of the post @Low Range Off-Road said that whatever is listed in the OME kit # on ARB's website is what comes with the GB. It may not be every bushing to completely rebuild your shackles and spring packs, but if the kit comes with the pre-pressed bushings and the other set for the leaf pack then you're half way there.
  10. Apr 12, 2016 at 9:20 AM
    #570
    hardground
    Massachusetts
    Yeah I was not expecting the bushing for the complete shackle, just was told a few days ago that we were only getting 4 of them even though the kit said we were getting 8 of them.
    Thank you all for clearing this up, did not want any of us a few bushings short at install.
  11. Apr 12, 2016 at 9:34 AM
    #571
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    I mean if these guys have put them on their trucks they OBVIOUSLY work just fine...
  12. Apr 12, 2016 at 9:36 AM
    #572
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    So what else do I have to purchase seperate from the stock kit to install this on my truck? Do I need other bushings or something? What are you guys talking about needing other bushings and shit?
  13. Apr 12, 2016 at 9:39 AM
    #573
    hardground
    Massachusetts
    It comes with the 8 that go in your springs, the other 4 that are in your shackle you can keep as is or change if you would like to.
  14. Apr 12, 2016 at 9:41 AM
    #574
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Ok so this kit forsale comes with everything I need parts wise to put this on my truck?
    Obviously no UCA or anything... Hopefully I won't need to get another set of u bolts... I already have the flip kit installed on the current setup I have
  15. Apr 12, 2016 at 9:42 AM
    #575
    tripleseven
    tripleseven Well-Known Member
    Marin County, CA
    2016 TRD Offroad 4x4 - Super White
    Then why is the OP confirming that they are not available for the 2016? It's not about whether they fit, rather are the kits specifically dialed for the different specs on the 2016. I will call OMU myself and get confirmation.
    moe2o4 likes this.
  16. Apr 12, 2016 at 9:42 AM
    #576
    hardground
    Massachusetts
    From what I have been told it comes with everything you need.
    TheTacoma likes this.
  17. Apr 12, 2016 at 11:07 AM
    #577
    hardground
    Massachusetts
    Does you flip kit raise truck or just increase travel?
  18. Apr 12, 2016 at 11:34 AM
    #578
    DrFunker
    DrFunker Well-Known Member
    Neither, it increases the clearance under the truck.
    A quote:
    "U-bolt flip kits help increase ground clearance under your rig. Stock u-bolts face down and offer a snag point for rock and trail debris."
    edit: I guess technically, it does "raise" the truck - equipment on the truck. But not in the same way that we are thinking raising or lifting the truck.
  19. Apr 12, 2016 at 12:17 PM
    #579
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Neither as stated above... I have an AAL in the rear currently
  20. Apr 12, 2016 at 12:44 PM
    #580
    ramonortiz55
    Ramon
    Texas
    stock
    vendor has requested the next ten orders.
    You guys are up - I will send you instructions shortly
    11. @HeavyThumbs - OMETAC05LKSB – Tacoma 2005-15
    12. @Jpete - OMEFJCLKS – 2007-09 FJ Cruiser Light Kit
    13. @yankeehilux - OMETAC04HKS– Tacoma 1998-2004 HeavyKit
    14. @KaptainH - OMETAC05LKSB
    15. @Etmarckwardt - OMETAC05LKSB
    16. @AznTRD - OMETAC05LKSB – Tacoma 2005-15 Stock Kit
    17. @trey99ek - OMEFJCLKS– 2007-09 FJ Cruiser Light Kit
    18. @BlueHeli - OMETAC05HKS
    19. @Jnelson0019 - OMETAC05HKS – Tacoma 2005-15 Heavy Kit
    20. @Warles - OMETAC05LKSB – Tacoma 2005-15 Stock Kit
    Etmarckwardt and Synergy001 like this.
