**CLOSED**Round two: OME suspensions - group buy!**
Discussion in 'Closed Group Buys' started by ramonortiz55, Apr 6, 2016.
  1. Apr 12, 2016 at 12:47 PM
    #581
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    :spy:
  2. Apr 12, 2016 at 1:35 PM
    #582
    ionyota
    ionyota Well-Known Member
    2012 TRDOF DCSB
    OME lift, All-Pro UCAs, BFG KM2 pizza cutters
    @Synergy001 - whats the difference between the 885 coils and the 886 coils that causes the need for aftermarket UCAs with the 886s? Are the 886s slightly longer?
  3. Apr 12, 2016 at 1:39 PM
    #583
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    886s are a little taller than the 885s man!
  4. Apr 12, 2016 at 1:57 PM
    #584
    Texas-Shrapnel
    Texas-Shrapnel Well-Known Member
    Kevin
    2015 DCSB TRD off road
    My buddy has the full OME heavy kit with the 886's on his 2012 DCSB, and he did not have to change the UCA's.
    CaliDevilDoc likes this.
  5. Apr 12, 2016 at 2:06 PM
    #585
    4WALKER
    4WALKER Save the manual trans!!!
    1991 4runner 5 speed SR5 4X4
    Dirt
    :boink:
  6. Apr 12, 2016 at 2:28 PM
    #586
    Tiger14
    Tiger14 Resident Defector
    Kevin
    Charleston, SC
    2014 Ford F250 Crew Cab KR 6.7PSD
    So no matter what I'm going with the heavy kit I asked for. My concern is with the 886's and my front bumper/winch combo will I still get the full 3"? I like my truck as level as possible and just worry I'm going to get 3" out back and 2" up front with the added weight. I know the 886 is slightly taller than 885 with stiffer spring rate. Any help? Do I need additional parts to get the full 3"?
  7. Apr 12, 2016 at 2:36 PM
    #587
    Tacodile84
    Tacodile84 Well-Known Member
    Tucson, Arizona
    14 TRD Offroad 4x4
    I think it's going to be a trial and error for you at this point. The 886's should make it pretty level, but you could always add a half inch spacer later if it's not quite level.
  8. Apr 12, 2016 at 2:48 PM
    #588
    Tiger14
    Kevin
    Charleston, SC
    Can you add a top plate spacer without disassembling the strut? I didn't think that the factory length studs on the top plate had enough length to fit a spacer? Sorry to hijack the thread, I've searched everywhere and the answers about this lift setup vary a lot. I'm not opposed to the extra work, I just don't have coil compressors that can handle the 886's.
  9. Apr 12, 2016 at 2:51 PM
    #589
    Dkrazykracker32
    Dkrazykracker32 New Member
    2008 FJ
    Synergy001 and paintedhands like this.
  10. Apr 12, 2016 at 2:54 PM
    #590
    Shackleford027
    Shackleford027 New Member
    2013 Silver Tacoma TRD
    OMETAC05LKSB – Tacoma 2005-15 Stock Kit - $1226.45
  11. Apr 12, 2016 at 3:00 PM
    #591
    Tacodile84
    Tucson, Arizona
    14 TRD Offroad 4x4
    Yes, you can add the top plate spacer without taking apart the strut. If you do a 1/2" spacer you will need longer studs. Most kits come with them.
    http://toyteclifts.3dcartstores.com/TOP1-T--Front-Top-Plate-Spacer-Kit-_p_333.html
  12. Apr 12, 2016 at 3:44 PM
    #592
    Low Range Off-Road
    Low Range Off-Road Well-Known Member
    We also have a Top Plate Kit as well.
    http://www.lowrangeoffroad.com/toyo...ser-top-plate-spacer-kit-approx-3-4-lift.html
  13. Apr 12, 2016 at 4:01 PM
    #593
    Dozer
    Dozer Well-Known Member
    Colorado
    13 TRD Off Road
    I resisted as long as I could. @ramonortiz55 - please put me down for:
    OMETAC05HKS – Tacoma 2005-15 Heavy Kit
  14. Apr 12, 2016 at 4:45 PM
    #594
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
  15. Apr 12, 2016 at 6:08 PM
    #595
    hardground
    hardground Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    Sorry I was talking about a shackle flip like in this video but they also have the U-Bolt flip done.
    https://youtu.be/rsuwEUCSEOA
    What U-Bolt flip kit did you use? Maybe I will do that too.
  16. Apr 12, 2016 at 6:25 PM
    #596
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    I was told the same when I ordered
    hardground likes this.
  17. Apr 12, 2016 at 6:25 PM
    #597
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    All pro unbolt flip kit... It was given to me by another member for free other wise I'd still have the regular set up
    hardground[QUOTED] likes this.
  18. Apr 12, 2016 at 11:07 PM
    #598
    DanTman88
    DanTman88 Well-Known Member
    Dan
    Southern Maine
    2010 DCSB SR5 4x4
    Is there a recommended wheel offset for this kit?
  19. Apr 12, 2016 at 11:44 PM
    #599
    DanTman88
    Dan
    Southern Maine
    2010 DCSB SR5 4x4
    or a wheel/ tire size? Thanks
  20. Apr 13, 2016 at 1:10 AM
    #600
    sull625
    sull625 Well-Known Member
    Dave
    Montana
    12 TRDOR DC Spruce Mica
    Can I still get in for a OMETAC05LKSB?
