**CLOSED**Round two: OME suspensions - group buy!**
Discussion in 'Closed Group Buys' started by ramonortiz55, Apr 6, 2016.
  1. Jul 1, 2016 at 6:37 PM
    #1901
    CaliDevilDoc
    CaliDevilDoc Well-Known Member
    San Diego, CA
    2016 Barcelona Red TRD Off-Road 4x4. 1995 FZJ80
    OME nitrochargers, 886, and Dakars
    I got about 3 inches of lift and it camburg uniball UCA
  2. Jul 1, 2016 at 6:51 PM
    #1902
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    not sure if the 1st gen U bolts are the same or not. the first gen didn't come with them in the kit but the second gens did. how much are you looking to get?
  3. Jul 1, 2016 at 10:36 PM
    #1903
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Try a different shop. Unless something changed pretty radically for 3rd Gens, I don't understand why any competent alignment shop wouldn't be able to dial you in.
  4. Jul 2, 2016 at 3:53 AM
    #1904
    hardground
    hardground Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    Shipping cost, I don't want any money for them
  5. Jul 2, 2016 at 4:10 AM
    #1905
    hardground
    Massachusetts
    With new UCA's and LCA's my alignment was a bitch too. It took them 4+ hours and I am still not completely happy. The steering is still off, steering wheel holds left or right, like a real old truck where you turn the wheel but nothing happens at first. It drives perfectly straight down the highway, no pulling, just not as responsive when driving slow. Any ideas?
    My cams are facing down on the driver side and up on the passenger. Thought that was strange
  6. Jul 2, 2016 at 7:04 AM
    #1906
    carofchoice
    Jeff
    Newton, IL
    let me find out if they are the same or not and if they are the same ill take them. will get back to you soon. thanks
  7. Jul 2, 2016 at 7:55 AM
    #1907
    Norton
    That seems weird to me. I'm not as familiar with LCA replacement, but I though UCA replacement was supposed to make alignment easier? That said, you ended up with a bit more than 3" of lift, didn't you? (I know anything more than 3" makes things more difficult, but I thought mitigating that was the idea behind replacing UCAs.
  8. Jul 2, 2016 at 11:25 AM
    #1908
    carofchoice
    Jeff
    Newton, IL
    sent ya a pm.
  9. Jul 2, 2016 at 1:20 PM
    #1909
    deanooo311
    deanooo311 Well-Known Member
    ryan
    Midland, MI
    15 taco base 4x4 dclb
    OME 885, dakar leaf pack. 265/75r16 duratracs "c". Back up camera. Scan gauge. Husky floor liners. Cal trend canvas seat covers. Topper and tacoma bed mat. Tailgate skin and cap. Differential breather mod. Intermittent wiper switch. Redline hood struts.
    So reading the write ups on the brake line has me a bit nervous. Looks like a pain in the ass especially if air gets into master cylinder. Need reassurance that lines will install easily and bleeding isn't as hard as I'm making it out to be. Help me guys.
  10. Jul 2, 2016 at 1:31 PM
    #1910
    carofchoice
    Jeff
    Newton, IL
    bleeding the brakes isnt hard at all. once you get the line off and new ones on just use a plastic soda bottle with a hose drilled through the lid. attach the hose to the bleeder valve and have someone pump the brakes while you release the valve. repeat till there is no more air. start at the furthest corner first and work your way closest to the master cylinder. very easy and shouldnt take you long at all.
    i will be ordering lines here soon aswell. good luck.
  11. Jul 2, 2016 at 2:20 PM
    #1911
    deanooo311
    ryan
    Midland, MI
    I was just reading stories of people having problems with their new lines attaching to the bracket.
  12. Jul 2, 2016 at 2:25 PM
    #1912
    Norton
    I agree with @carofchoice. The job itself it NOT difficult or complicated, assuming you can get the old lines to come loose. (My rear ones were a PITA.)
    One clarification I'd offer to his comments is that, on newer trucks like ours, pumping the brakes isn't required. If you turn the key on and press the brake pedal, the electric ABS motor does all the work pumping out the old fluid. (@Crom posted a great explanation here. With the exception of "speed bleeder valves," that aren't original equipment and to which I haven't upgraded yet, bleeding the brakes on my truck went exactly as described.)
    Crom likes this.
  13. Jul 2, 2016 at 4:07 PM
    #1913
    deanooo311
    ryan
    Midland, MI
    I know I'm making it out to be much harder than what it's going to be, just a little nervous from other posts saying how difficult it was for them. Lift is sitting on bench in shop, tires at discount tire until Tuesday and brake hose at FedEx 20 miles away until Tuesday. :annoyed:
  14. Jul 2, 2016 at 4:54 PM
    #1914
    Norton
    I can relate. I've also been nervous tackling some of my mods. As long as they're not fused, brake lines are pretty straightforward. Take your time and monitor the fluid level when bleeding. You do NOT want to run the reservoir dry. Given the size of our reservoirs, however, that takes some doing.
    Crom likes this.
  15. Jul 2, 2016 at 6:02 PM
    #1915
    carofchoice
    Jeff
    Newton, IL
    That is something I did forget to mention. Nice catch
  16. Jul 3, 2016 at 11:55 PM
    #1916
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
    tis the tall one
  17. Jul 4, 2016 at 7:13 AM
    #1917
    Jtaoj0
    Jtaoj0 Well-Known Member
    Sounds like the census is yes, do longer brake lines and the the Goodridge 2-21155 is the right set. I hadn't planned on doing lines but there seems to be plenty of those installing the OME lift who are doing them.
    Norton likes this.
  18. Jul 4, 2016 at 8:02 AM
    #1918
    carofchoice
    Jeff
    Newton, IL
    • 2" Extended Brake Line Kit - For Trucks with Lifts
    • Vehicle2003 Toyota Tacoma
    • Submodel4WD
    • AutoAnything SKU2706377
    • Part Number2-21154
    • Goodridge 15% Off All Products!
    for first gen
    I'll be doing mine so I don't have to worry about it later plus it will be better than the stock lines anyways.
    currently 15% off at autoanything
  19. Jul 4, 2016 at 8:20 AM
    #1919
    Norton
    I ran (2" extended) Goodridge lines on my 1st Gen for years with no problems, and upgraded to them when installing my 2nd Gen lift last week. In addition to peace of mind when upgraded suspension reaches full-droop, SS lines improve pedal feel/consistency and provide much greater durability than the OEM rubber ones.
    The part numbers listed above (2-21154 for 1st Gen and 2-21155 for 2nd Gen) are correct. IIRC, AutoAnything had the best price when I bought my 1st Gen lines. More recently, jet.com had the best price ($92, after 15% coupon) when I bought my 2nd Gen lines.
  20. Jul 5, 2016 at 8:40 AM
    #1920
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    Anyone get 887's on their 3rd gen yet with stock UCAs? Curious to know of specific experiences before I try my hand at the install...
