CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Mar 22, 2013 at 7:33 AM
    #181
    ambiguous
    ambiguous Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
  2. Mar 22, 2013 at 8:04 AM
    #182
    CrimsonCountry
    CrimsonCountry Well-Known Member
    Huntsville, AL
    2006 4Runner (4.0) Sport Edition
    (F) LR UCA + DR/Icon 2.5" Ext Travel (R) 5100/SAW+DS 1.5" Driver only | 285/70/17 Toyo AT II| Level 8 Guardians
    I just wanted to say thanks for the great service. I placed my order Monday and got my lights yesterday...excellent.
  3. Mar 30, 2013 at 3:21 PM
    #183
    m32
    m32 Well-Known Member
    Edwin
    2013 DCSB TRD
    Guys,
    I hope you don't mind me posting this here as I'm in the middle of my install and I'm about to wire up the retrofit and have no idea what this is. Anyone?
    I've done quite a few HID kit installs and I usually just plug the hid bulb to the ballast and the ballast to the connector coming from the car. Anyone?
    Edwin
  4. Mar 30, 2013 at 3:32 PM
    #184
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That adapter harness is what allows the single lamp to work properly with the low beam and high beam. It also gets the power draw off of the factory harness and moves it to the battery.
    Make sure your grounds are solid. I've had problems with a few HID systems and the problem has always been with a ground wire. Passenger side radiator support where the bracket supports the AC line on my Tacoma did NOT provide an adequate ground.
    The connectors are marked where they go. The large square one with 3 blades on it plugs into your driver's side headlight connector.
    The fuse goes to the battery.
    The other 4 connectors are marked "Ballast" and "Projector"
    The one marked "Projector" is the trigger for your high beam solenoid.
  5. Mar 30, 2013 at 3:42 PM
    #185
    m32
    Edwin
    2013 DCSB TRD
    Thanks Rick! Last question. Do I only plug up the 3 prong to one of the headlight connectors and thus leaving the passenger side connector not plugged into anything? Thanks!
    Edwin
  6. Mar 30, 2013 at 3:43 PM
    #186
    Rich91710
    Rich
    Los Angeles
    08 Base
    Correct.
    Only one side is needed to operate the relay set.
  7. Mar 30, 2013 at 6:35 PM
    #187
    m32
    Edwin
    2013 DCSB TRD
    Thanks again Rich. I got back from dinner and wired it up and it all works. I ended up using the ground behind the washer fluid reservoir. Now time to take it back out and reseal :(
    Edwin
  8. Apr 3, 2013 at 6:59 AM
    #188
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    TRSTaco25 is back up my friends!
  9. Apr 3, 2013 at 7:06 AM
    #189
    TRSAndrew
    ATL
    You want a new light bar? Check out our 10w hitting shelves soon!
    Rigid bars use 5W LEDs, btw.
  10. Apr 3, 2013 at 8:00 AM
    #190
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Bastards...
  11. Apr 3, 2013 at 8:36 PM
    #191
    flatfeet
    flatfeet Well-Known Member
    Rob
    Hilo
    09 TRD Sport 4x4 DBL CAB
    RCD 4.5 lift, 18x9 BFD, 305/60-18 Mickey Thompson ATZ's, projector HIDs, TRD exhaust, AFE intake, onboard air, led dash mod, train horns.
  12. Apr 5, 2013 at 11:45 PM
    #192
    cse
    cse New Member
    bump! guys jump on it!
  13. Apr 6, 2013 at 5:05 PM
    #193
    chentwoten
    chentwoten New Member
    ordered!
  14. Apr 6, 2013 at 11:26 PM
    #194
    OscarMayor
    OscarMayor Member
    Jacksonville, FL
    2012 TRD OR Supawhite
    Ordered. Thanks Andrew!
  15. Apr 8, 2013 at 6:48 AM
    #195
    TRSAndrew
    ATL
    Good stuff guys. Thanks for the business!
    If only I could find a way to use the GB as part of my FJ build money. ;)
  16. Apr 8, 2013 at 7:01 AM
    #196
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    U guys have been awesome to us here......THANK YOU!
  17. Apr 8, 2013 at 12:30 PM
    #197
    keoki
    keoki Well-Known Member
    Maui, HI
    13 PreRunner TRD Off Road
    Sub'ed
  18. Apr 8, 2013 at 6:18 PM
    #198
    Rich91710
    Rich
    Los Angeles
    08 Base
    More like some of your FJ build money is supporting the GB!
  19. Apr 8, 2013 at 8:21 PM
    #199
    whirlybird9
    whirlybird9 Member
  20. Apr 8, 2013 at 8:41 PM
    #200
    BryanWhiteTRD
    BryanWhiteTRD Active Member
    How long is this deal good for? I get my truck at the end of the month or beginning early next month. Also is there a DIY for 2012-13 headlights? Leaving the VW scene with OEM R32 HID lights and want HID's!
