CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Jan 15, 2014 at 7:38 PM
    #2081
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Nothing goes under the lamp.
    Outer ring to secure the projector into the housing, then the lamp, then washer/silicone, then the "cap" ring retains the lamp and locks the outer ring.
  2. Jan 15, 2014 at 7:52 PM
    #2082
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    Any idea when the GB will start back up?
  3. Jan 15, 2014 at 7:59 PM
    #2083
    Rubio92
    Rubio92 Well-Known Member
    Josh
    Bakersfield, CA
    '04 Prerunner IMPULSE RED
    Projector Retrofit in sig LED's galore inside and out Painted black stock alloys
    Any idea why no one at TRS is returning my emails. I've sent 3 already. All within the past two weeks. I can't really call during the day as I'm at work.
  4. Jan 15, 2014 at 8:01 PM
    #2084
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    I guess they have been swamped with new product releases recall issues and renovating their facilities...
  5. Jan 15, 2014 at 8:01 PM
    #2085
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Probably because they get hundreds of emails a day, you should've received an email stating that during this week they are busy trying to back fill orders for ballasts and that a response may take an additional 2-3 days. At least thats what I got when I emailed them yesterday
  6. Jan 15, 2014 at 8:02 PM
    #2086
    Rubio92
    Josh
    Bakersfield, CA
    No email. Not even a confirmation that I sent it. Is there another way to email them aside from going to their "contact us" page?
  7. Jan 15, 2014 at 8:03 PM
    #2087
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
  8. Jan 15, 2014 at 8:04 PM
    #2088
    bellassaiw10
    Currituck NC
    Hmm I used the contact us page I could get you their personal email but it won't be any faster
  9. Jan 15, 2014 at 8:04 PM
    #2089
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I suggest just calling when you can.
  10. Jan 15, 2014 at 8:06 PM
    #2090
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    answers@theretrofitsource.com is what I use.
  11. Jan 15, 2014 at 8:07 PM
    #2091
    Rubio92
    Josh
    Bakersfield, CA
    I'll probably try and make time tomorrow. I'm West Coast though, aren't they 3 hours ahead? Earliest I'd get off is 2. I'll call right after work. Thanks guys.
  12. Jan 15, 2014 at 8:07 PM
    #2092
    Rubio92
    Josh
    Bakersfield, CA
  13. Jan 15, 2014 at 8:56 PM
    #2093
    tacodane
    Dane
    What time do you go to work? If your up at 5 am give them a call
  14. Jan 15, 2014 at 9:17 PM
    #2094
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    So I got my DSP ballasts in today. Thankfully they both fire up 1st try every time I turn my lights on. I think I read it before in this thread, but I also have some crazy flickering going on at start up, that's okay right? It stops after about 5 seconds then it's solid.
  15. Jan 15, 2014 at 9:18 PM
    #2095
    tacodane
    Dane
    I have the same flickering you do at start up.
  16. Jan 15, 2014 at 9:44 PM
    #2096
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    Kinda shitty to pay so much and have them flicker, but what can I do haha oh well. At least they turn on!
  17. Jan 15, 2014 at 9:54 PM
    #2097
    tacodane
    Dane
    Ya I mean I'm glad that they are solving issues for everyone. And I agree to pay so much but have flickering
  18. Jan 15, 2014 at 10:07 PM
    #2098
    geogecko
    geogecko Well-Known Member
    Broken Arrow, OK
    That seems like a pretty good deal for the amount of work involved. Mine included no parts.
  19. Jan 15, 2014 at 10:16 PM
    #2099
    geogecko
    Broken Arrow, OK
    What I did was tighten the lock ring for the projector, allowing it to move the horizontal. Put the bulb back in and tighten the lock ring on the bulb as finger tight as you can get it. Connect the ballast. Leave the rubber dust/moisture cover off. Fire it up and reach in with your fingers. I was able to use the bulb lock ring to SLOWLY rotate the projector. The key is to do it slowly, so that you don't unscrew it. Usually I am able to get the horizontal back using this method.
    If your projector won't move that way, then I've also used this method. Most likely, you need to rotate the projector counterclockwise when looking from inside the truck, because you twisted it clockwise when tightening everything. So, pull the bulb back out, and use a pair of pliers to grab the end of the projector threads, being careful to not damage them. Rotate the projector CCW a little, put bulb back in (don't screw it down too tight), connect ballast, and check alignment. Keep doing that until it's right. Then tighten the bulb, being careful not to twist the projector.
  20. Jan 15, 2014 at 10:21 PM
    #2100
    geogecko
    Broken Arrow, OK
    Lol, I'll take 5 seconds of almost no noticeable flicker, versus the candles I had constantly with the SS ballasts!
    Seriously, I was embarrassed to come to a stop at a light with the dancing going on.
