CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Jan 23, 2014 at 7:31 PM
    #2181
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    But it's worked just fine for 9 months haha
  2. Jan 23, 2014 at 7:46 PM
    #2182
    zoopla
    zoopla Well-Known Member
    Calgary,Canada
    2011 tacoma trd dbl cab
    K&N cold air intake FXR retrofit/Vleds Avid front bar/side steps 3" Eibach lift
    well this might help a few of us:
    After having firing issues with the SS ballast..i received a new pair of DSP and i am still having trouble with them…I first thought it was from the cold temps but i installed everything in a nice heated garage…So i was like, what are the odd's of having the same firing issue on the same headlight with both the SS and DSP's?
    One thing was very strange on both ballast, every time it was lit up and i hade my hand right behind the bulb (D2S connector)…at the slightest touch, it would turn off the light…So maybe the trouble is from the connector, so i barely pulled inward the 2 metal flanges inside the orange socket and i would still have the problem…then i decided to remove the orange rubber seal at the bottom of the socket and BAM…now it lights up every time and does not turn off anymore even if i wiggle the connector….
    So in my case…was it really a cold temperature problem??? i dunno but i can tell you that the cheap little rubber piece was stopping the socket from making a good connection…i'll do some more test's and comment further….
    But i thought you guys should try this too in case it works!!!
  3. Jan 24, 2014 at 1:33 AM
    #2183
    Tmill
    Tmill Well-Known Member
    Tyler
    Florida Panhandle
    07 Sport Black DCLB
    Andrew what's the chances you have pics of the Gatling gun square shrouds? Can't find any on the site.
  4. Jan 24, 2014 at 9:25 AM
    #2184
    InSight Retrofits
    InSight Retrofits Closed
    Just read the guide in my signature and you will understand lol
    I might jump in on this again to start retrofitting for other tacoma guys.
    I can get the kit for $247 with 55w ballasts and bulbs, get two lights off ebay for $200, make the lights to somebody's liking and do a swap for the core lights. I am getting really bored with all this cold weather and need a project!
    Retrofits are so worth it...
    8638C30C-DA1F-440C-BE38-E5C631E87CF1_zps_8c83bfc4e46d8dd84d83b2a49ae8903d1e99923e.jpg
    4A1A11BC-50CE-4C02-914D-CED0CC265BA6_zps_21aa804069f32bfeaff46595fa1f5345a19cf20c.jpg
    BA7CEE37-4188-4C47-82B7-59BB06D09E8A_zps_fd992778e84ef8f8c77609d93bfb7d5cb610a689.jpg
  5. Jan 24, 2014 at 5:55 PM
    #2185
    mquade12194
    mquade12194 New Member
    Rochester/Hammondsport, New York
    2006 SR5 Sport Dbl Cab V6 4x4
    7 more!! :bananadance:
    (Probably less in reality!)
  6. Jan 24, 2014 at 7:23 PM
    #2186
    KojiCM
    KojiCM New Member
    Is the difference in light output worth going up to the FX-Rs?
  7. Jan 24, 2014 at 10:10 PM
    #2187
    Rubio92
    Rubio92 Well-Known Member
    Josh
    Bakersfield, CA
    '04 Prerunner IMPULSE RED
    Projector Retrofit in sig LED's galore inside and out Painted black stock alloys
    Trust me...it's WAY easier than you're making it out to be. Just take your time, stay PATIENT, and pay attention to the details. Something is bound to go wrong, so why stress. You can take a gander at my retrofit if you'd like. I'm a 1st gen owner, but a retrofit is a retrofit. Cheers!
  8. Jan 24, 2014 at 10:15 PM
    #2188
    Rubio92
    Josh
    Bakersfield, CA
    x2!!!!! I wanna see some output from those badboys!!
    :drool:
  9. Jan 24, 2014 at 10:18 PM
    #2189
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Yes
  10. Jan 24, 2014 at 10:19 PM
    #2190
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
  11. Jan 24, 2014 at 10:19 PM
    #2191
    Rubio92
    Josh
    Bakersfield, CA
    I emailed today about an order is placed today as well, not expecting anything until next week sometime. But anyone know if I should've contacted Andrew before completing my purchase to get my $50 for a how-to kicked in to get that taken off the total amount? Kind of frustrated with myself, I paid full amount. I should've come here first.
    :pout: :confused: :confused:
  12. Jan 24, 2014 at 10:23 PM
    #2192
    andlours
    andlours Well-Known Member
    Andy
    Denver, CO
    09 TRD Offroad
    I may have to take you up on this...
  13. Jan 24, 2014 at 10:44 PM
    #2193
    tacodane
    Dane
    Just give them a call. They will get you sorted out
  14. Jan 25, 2014 at 3:50 AM
    #2194
    mdobem
    mdobem New Member
    6 more!!
  15. Jan 25, 2014 at 11:07 AM
    #2195
    888
    888 Member
    Matthew
    Hilux 2.5 D4D
    Try giving them a call... they might be able to include you if your order hasn't already shipped
    Cross your fingers
  16. Jan 25, 2014 at 12:33 PM
    #2196
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Hey Andrew. Look im new to this group buy stuff n as well as the headlights projectors I'm looking to buy one 2 weeks or so. I want something good something easy to install n say I have projector headlights have 2008 toyota tacoma Whet do you recommend me don't want spend too much. If u can inbox me it will be great. Thanks sir
  17. Jan 25, 2014 at 12:35 PM
    #2197
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    Hey Andrew. Look im new to this group buy stuff n as well as the headlights projectors I'm looking to buy one 2 weeks or so. I want something good something easy to install n say I have projector headlights have 2008 toyota tacoma Whet do you recommend me don't want spend too much. If u can inbox me it will be great. Thanks sir*******
  18. Jan 25, 2014 at 1:54 PM
    #2198
    Fuse
    Fuse Geologist
    Calgary
    2015 TRD Sport 6MT
    Just got back from working up north for a month. Swapped in my replacement ballasts about 15 minutes ago. So far so good! I'll wait until we get down into the -15°C range this week and see how they hold up:D
  19. Jan 25, 2014 at 2:53 PM
    #2199
    Tmill
    Tyler
    Florida Panhandle
    07 Sport Black DCLB
    For anyone that has questions on the D2S versus the mini H1. This is what I got in an email from TRS, direct copy and paste.
    For the most part, the performance of the Mini D2S and Mini H1 projectors is even, but I will highlight some of the small differences below:
    1) Beam uniformity: The Mini D2S is a bit better in this category, with slightly more even-ness in its output.
    2) Beam Width: The Mini H1 is slightly wider here (just barely)
    3) High beam performance: The Mini D2S has a brighter, more defined high beam (bi-xenon) output
    4) Cutoff color/sharpness: Both projectors have clear lenses, which gives them a sharp and colorful cutoff line. The curved cutoff shield inside the Mini H1 projector results in slightly more color, however.
    5) Bulb type used: Obviously the H1 takes H1 and D2S takes D2S, and we feel that D2S bulbs offer a bit more precision, though no more light since they use the same light producing capsule.
    6) Size: The D2S version is about 1/2" shorter in overall depth, but is also slightly wider and a little bit taller than the H1 version.
    7) Modification to your OEM housing: the diameter of the mounting shaft on the H1 is 22mm, whereas it's 32mm on the D2S model, so unless you have an H4 headlight, you will likely have to widen up the bulb hole by a bit to use the Mini D2S projector. (The Mini D2S was designed for reflectors using H4/9003 bulbs but is still definitely usable in other applications).
    Therefore, if you value the categories more than the H1 wins, you should probably go that route - and vice-versa for the D2S model.
    Personally I just "like" the D2S model more since I favor the categories that it outshines the H1 model more in, but ultimately its up to you - since both should fit your vehicle with little to no modifications at all.
    You can check out some customer sent-in pictures of the outputs from both here:
    Morimoto Mini D2S: http://www.hidplanet.com/forums/album.php?albumid=225
    Morimoto Mini H1: http://www.hidplanet.com/forums/album.php?albumid=226
    Please let us know in regards to your wife's Rogue and we'll be glad to make a recommendation there as well.
    Thanks again Tyler!
    Andrew @ TRS
  20. Jan 25, 2014 at 8:29 PM
    #2200
    bp7861
    bp7861 Active Member
    bryan
    orange county
    05 PreRunner SR5 TRD Off Road
    toytec 3 in lift, exhaust, HID, interior LED,
    Got mine ordered
