CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Jan 28, 2014 at 4:16 AM
    #2221
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Dang... I'm out haha Maybe if I worked Security Forces.
  2. Jan 28, 2014 at 6:15 AM
    #2222
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Give me two weeks....
  3. Jan 28, 2014 at 6:24 AM
    #2223
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I'm gonna order today, screw it. Picking up the truck tomorrow anyways.
    edit: ordered. How many left??? haha
  4. Jan 28, 2014 at 8:28 AM
    #2224
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I can make this happen :D seeing as how my driver side ballast fires 3 times every time I turn the lights on. It stays on but flashes real bright, 2 sec later flashes real bright, then 2 sec later flashes real bright again. Does it consistently every time for 2 weeks now. I was waiting to see if it went away but it hasn't yet. This is my 5th set of ballasts between my truck and car. First 3 were the bad SS ones and most recent 2 are the revised ones. I haven't had a chance to build my truck headlights yet so I haven't tested those new ones but for the car, looks like I need another ballast
  5. Jan 28, 2014 at 8:49 AM
    #2225
    zoopla
    zoopla Well-Known Member
    Calgary,Canada
    2011 tacoma trd dbl cab
    K&N cold air intake FXR retrofit/Vleds Avid front bar/side steps 3" Eibach lift
    Hey man! have you read my comment above…i was replacing ballast too then became doubtful that they were the problem since it happened on every ballast i replaced. What are the odd?
    If you run the D2S bulbs, it might be a connection problem between the bulb and orange connector…what i did is remove the orange rubber bumper from inside the connector. they used to only flick and not turn on at all and now since i did this they turn on 95% of the time…it isn't perfect but i think TRS should maybe look at this possibility before asking people to shoot the ballast's.
    To Andrew; The DSP sent to replace de SS aren't any better unless i did what is stated above…..
  6. Jan 28, 2014 at 2:53 PM
    #2226
    InSight Retrofits
    InSight Retrofits Closed
    What if i go dig through the garbage, find an SS ballast and shoot it once with my 45 and once with my 30-06? Does that count?
    No 50 cal yet :(
  7. Jan 28, 2014 at 3:13 PM
    #2227
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Just ordered my second kit :D
  8. Jan 28, 2014 at 7:00 PM
    #2228
    srk
    srk New Member
    2008 Tacoma
    I ordered a kit today too. I wonder how many more are needed for this GB.
  9. Jan 29, 2014 at 10:23 AM
    #2229
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    We have plenty of 45 rounds here. Need something serious!
  10. Jan 29, 2014 at 10:48 AM
    #2230
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I counted 9 people that ordered since the GB started back up again. Cmon 1 more!
  11. Jan 29, 2014 at 10:55 AM
    #2231
    brian65oh
    brian65oh Well-Known Member
    Brian
    Nor Cal (currently stationed in Jax beach FL)
    05 pre runner
    camburg long travel w/ race runner 2.5x8 co Deaver springs spintech race muffler kn cold air intake
    what wiring harness and ballast do we run with the mini h1?
  12. Jan 29, 2014 at 10:59 AM
    #2232
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    Bixenon H4/9003 always for our trucks now go and order :D
  13. Jan 29, 2014 at 11:01 AM
    #2233
    Sacrifice
    KS
    DCSB OR 4X4 LT
    do it!!!
  14. Jan 30, 2014 at 8:17 AM
    #2234
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Any deals going on for the X DRLs? Never mind, Ordered them today.
  15. Jan 30, 2014 at 7:06 PM
    #2235
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Forgot to post my completed retrofit picture. Turned out awesome, other than i didn't seal it perfectly so I have to redo that lol. Mini h1 kit.
  16. Jan 30, 2014 at 7:09 PM
    #2236
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    What bulbs are in the fog lights? Stock?
  17. Jan 30, 2014 at 7:43 PM
    #2237
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    5k's in the fogs to match the 5k bulbs in the projectors but they still aren't the same tint. I think the projectors change the way the light looks. Because when you look at it from the front the fogs and projectors look the same but the output color is different up against a wall or something.
  18. Jan 30, 2014 at 8:38 PM
    #2238
    tacodane
    Dane
    I can see that. Looks good man
  19. Jan 30, 2014 at 8:39 PM
    #2239
    double dee
    double dee Well-Known Member
    Arizona
    Just submitted my order. I think that makes 10. The bulbs I wanted were on backorder. I don't know if that makes a difference.
  20. Jan 30, 2014 at 8:44 PM
    #2240
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    Yeeyee! Yea we are good to go!
