CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Mar 15, 2014 at 11:18 AM
    #2461
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Ha. I don't want to buy another set but thanks. Too much money to just use for a little.
  2. Mar 15, 2014 at 11:20 AM
    #2462
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    I know that's why I got the cheapo set lol
  3. Mar 15, 2014 at 3:15 PM
    #2463
    Trailrider
    Trailrider Member
    Austin
    6" BDS suspension lift with Fox shocks
    Anyone know the current count on orders?
  4. Mar 15, 2014 at 3:40 PM
    #2464
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I don't think you can adapt a D2S burner into an H4 mount.
    And you'd lose high beams... well.. technically, you'd lose low beams, and ANY semblance of a pattern. It would be a shotgun of light.
  5. Mar 15, 2014 at 3:41 PM
    #2465
    03is300ztk
    Zach
    07 Tacoma 4X4
    oh agreed it would look like absolute shit.
  6. Mar 15, 2014 at 6:59 PM
    #2466
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    I do not. I pretty much grinded down to the reflector
  7. Mar 16, 2014 at 4:11 PM
    #2467
    NW4RUNNER
    NW4RUNNER Well-Known Member
    4 runner trail
    TRS is a great company. I'd strongly encourage people doing business with them. One of my halos went out and they sent me a brand new pair under warranty both driver side and passenger. The new ones look more bad ass than the last pair installed them this weekend. They are now white instead of yellow when turned off.
  8. Mar 17, 2014 at 5:38 PM
    #2468
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    What number are we at ?
  9. Mar 17, 2014 at 5:58 PM
    #2469
    Trailrider
    Trailrider Member
    Austin
    I think we are around 15
  10. Mar 18, 2014 at 7:21 PM
    #2470
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    I plan to get retrofit someday in the kinda near future. I plan to get the mini H1's and I had a few questions. What wire harness should I get and what size halo? I want to put the halo on the outside if I could. And what's the best way to put it on the outside?
  11. Mar 18, 2014 at 7:32 PM
    #2471
    bellassaiw10
    Currituck NC
    H4 harness and vied the shroud specs on TRS to figure out was size halo you need
  12. Mar 18, 2014 at 7:35 PM
    #2472
    ToyotaKTMracing
    Shay
    West Virginia
    The motocontrol bi xenon h4/9003? And is the recommended halo size for the inside or for the outside?
  13. Mar 18, 2014 at 7:40 PM
    #2473
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Search it on trs website for mounting halos.
  14. Mar 18, 2014 at 7:41 PM
    #2474
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Also, if you want to retrofit a 2nd gen I wouldn't get mini's the regular shrouds look small enough as it is....
  15. Mar 18, 2014 at 7:43 PM
    #2475
    ToyotaKTMracing
    Shay
    West Virginia
    I just heard the H1s are easier. I can do FX-R if it's not much more difficult.
  16. Mar 18, 2014 at 8:25 PM
    #2476
    PcBuilder14
    Brent
    Nor Cal
    Ah, I thought you were talking about getting mini shrouds, not the H1's theirselves.
    I have the D2S kit which is similar to the H1's.
    Just be sure to get the regular sized shrouds, as the mini shrouds look too small imo....
  17. Mar 18, 2014 at 9:38 PM
    #2477
    Rubio92
    Rubio92 Well-Known Member
    Josh
    Bakersfield, CA
    '04 Prerunner IMPULSE RED
    Projector Retrofit in sig LED's galore inside and out Painted black stock alloys
    I have the Gat 2.0's in my rig and it fills pretty much the whole headlight, give or take a few inches. It would probably fill out the 2nd gen's nicely. I'm sure you could find a user on here with them.
    H1's are definitely easier, zero to minimal cutting/sanding required. I had my mom and SO look at my write up and they said they could do it. Now, letting them do a retrofit is another question entirely. :cheers:
  18. Mar 18, 2014 at 9:45 PM
    #2478
    NW4RUNNER
    4 runner trail
    I went with Iris to get the unbroken look of the halo.
  19. Mar 19, 2014 at 6:06 AM
    #2479
    TRSJimmy
    Jimmy
    Gainesville, GA
    Recommended size halo depends in the shrouds. If you go to their website and look under different shrouds, it will tell you what size will fit on the outside and inside. What shroud are you going for?
  20. Mar 19, 2014 at 9:37 AM
    #2480
    bellassaiw10
    Currituck NC
    So were at 15 roughly ? About to put an order in
