CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. May 11, 2014 at 5:03 PM
    #2821
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Are the 55w too much for the D2S 3.0??
  2. May 11, 2014 at 8:12 PM
    #2822
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    :bored:
  3. May 11, 2014 at 8:14 PM
    #2823
    ONEBAR
    ONEBAR Well-Known Member
    Josh
    Englewood, CO
    08 White TRD OR
    why don't you like the wire idea?
  4. May 11, 2014 at 8:19 PM
    #2824
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    The wire idea works best , i did it on mine and they dont move let alone you dont notice unless upclose; and simple splice into your parking lights.
  5. May 11, 2014 at 8:24 PM
    #2825
    ToyotaKTMracing
    Shay
    West Virginia
    Well the only reason I don't like the idea is because I don't want to mess up the shroud. I can try it I guess. And don't the xbs hook up to another wire since it has the connectors on it? And where do I put the giant fuses that are on the wires?
  6. May 11, 2014 at 8:29 PM
    #2826
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Just drill really small holes in the shrouds before you paint them, and yes the xbs plug into what you're referring to as a giant fuse, then wire the wires after the fuse into wherever you want
  7. May 13, 2014 at 4:58 PM
    #2827
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Ordered amber, hook it up, I get white
  8. May 13, 2014 at 10:13 PM
    #2828
    tHeGeeK
    tHeGeeK Member
    Kyle
    Canada
    Just putting in my order now. This will be my 2nd retro; first was a quad setup on my 4runner. 2 years later and still loving it. Opted for the Square kit this time.
  9. May 14, 2014 at 10:41 AM
    #2829
    ProForce
    Anthony
    Alaska
    Just placed my order! :woot:
  10. May 14, 2014 at 8:32 PM
    #2830
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Still no reply from trs
  11. May 14, 2014 at 9:18 PM
    #2831
    ProForce
    Anthony
    Alaska
    Took them a couple days to respond to my message I sent as well. They will not respond to your PM. You need to call or go to the website and submit your inquiry from there. Probably just busy. Id call though.
  12. May 14, 2014 at 9:18 PM
    #2832
    ProForce
    Anthony
    Alaska
    AndrewTRS [OP][​IMG]
    PMs = Not good for TRS Questions
  13. May 14, 2014 at 10:00 PM
    #2833
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Yeah I did an inquiry on their website. No big deal. Probably won't have time to put the halos in till next month
  14. May 14, 2014 at 10:03 PM
    #2834
    ONEBAR
    Josh
    Englewood, CO
    08 White TRD OR
    Go to the website and do the chat I think it's 9-5 but I'm not sure
  15. May 15, 2014 at 12:31 AM
    #2835
    tunernewb92
    tunernewb92 Well-Known Member
    Brian
    Houston, TX
    2010 DCSB MGM OR
    Bills 5100 Front and Rear OME 885 Front Sway Delete 33" MTZ TRD FJ Wheels (Plasti - Black) Pioneer 10" Sub Kicker DS series component and speakers Alpine 5 way Amp Pioneer Double Din ImMrYo Mirror Bracket Escort 8100 Radar hung from mirror Waiting at house for install: TRD skid plate Retrofit Waiting on: BruteForce sliders BruteForce front bumper 2x3 6 led spot lights
    And after less than seven months my relay is shot. Awesome sauce.
  16. May 15, 2014 at 4:28 AM
    #2836
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I'm still having bulb firing issues with mine ever since I got the kit and through like 20 emails, I still haven't worked any solution out
  17. May 15, 2014 at 6:28 AM
    #2837
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    I'm sorry to hear that!
    Is it one of the clear cube relays?
    We can definitely get it replaced for you. Just shoot us an email at support@theretrofitsource.com, call during listed hours, or hit us up on live chat and we'll get it replaced. Just a picture of it is all we need to replace it.
    Please call or use live chat for a prompt resolution. Our apologies for the troubles!
    Yes, it's perfectly fine, as you must bake the housing to close it back up. Keep in mind it only gets to maybe 180-190F in the oven for a few minutes. It gets about that hot in direct sunlight on a summer day.
    No they'll work just fine. In fact, it's an option in the kit for the Mini D2S as well. :)
    Errors do happen from time to time, unfortunately. Just shoot us an email at support@theretrofitsource.com, call during listed hours, or hit us up on live chat and we'll get it replaced.
  18. May 15, 2014 at 6:33 PM
    #2838
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Yeah no problem. I did get an email back and I replied to it. Hopefully I'll get the right part very soon
  19. May 16, 2014 at 5:27 AM
    #2839
    TRSAndrew
    ATL
    I'm certain you will, but if you feel as though it's been too long between replies please shoot me an email directly and I'll be glad to take care of you. andrew@theretrofitsource.com is my email.
  20. May 16, 2014 at 6:15 AM
    #2840
    Pepe98
    Pepe98 Love moding vehicles as hobby
    Paul
    Dayton, Ohio
    SR5 that's begging for mods
    1st Update: 500 miles Rugged Ridges Matts, Dimming rear view mirror with comp/temp, AeroForce Tech Interceptor Gauge, Aeries Professional Bull and Nerf bars, LED Lighting complete in-Cab, LED DRLs, AMP Bed Xtendr, Extang Trifecta Signature Series Tonneau, Rigid Ind LED Lighting 30" E and 20" SR series, Rigid LED Grill insert, Katskinz Leather Interior, Custom 100amp Electrical Sub Panel x2 (Engine bay and Interior), custom vinyl bed side, interior accent lighting galore (Oznium), OTTRAW, switches, under hood lighting, Red Line Elite hood struts, Power Pop-n-Lock, Under Bed Rail Lighting (switched), Custom Tinting... More to come
    sub'd for these and I will need to know how to get the order in for a full set of Halo projectors when you have them. I have 2014 SR5 DC.
    I am in for the Fogs as soon as we can order them. Spent som time on the website and could not find a complete kit for Tacoma
