CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Aug 1, 2015 at 4:26 PM
    #3801
    Taco4Taco
    Taco4Taco PDX_Taco
    Berto
    Portland, OR
    4x4 OR DC
    Tint windows Subs Icon EXT travel front and rear AAL Icon UCA SCS SR8 BFG AT
    Ordered the fxr 3.0
    On the OP says you need to add member name in comment section. Never saw a comment section so I shot them a email. Hopefully it doesn't get canceled.
    Question is for the halos (switchbacks) what colors do they put out. 55k or more 45k I got 55 hopefully color is not to off.
  2. Aug 4, 2015 at 7:12 AM
    #3802
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Switchbacks are in the 5500-6000K range, so just a slight blue hue.
    The comments section is right there during checkout. :)
  3. Aug 4, 2015 at 7:50 AM
    #3803
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    Andrew gonna try and put an order through tonight when I get home. can I PM ya on all the items Im adding to my cart to make sure I am getting everything I NEED and in the correct sizes and color temps?
  4. Aug 4, 2015 at 3:30 PM
    #3804
    aaronc7
    aaronc7 Well-Known Member
    Aaron
    Navarre, FL
    2013 DCSB 4x4 TRD Sport
    Or call them?
  5. Aug 4, 2015 at 3:44 PM
    #3805
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Or post it here and we can tell you haha
  6. Aug 5, 2015 at 5:35 PM
    #3806
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    ok here is what I am planning on purchasing:
    - The recommended Mini D2S 3.0
    - O lens projectors for LHD
    - H4 MotoControl
    - Black sealant (or should I get gray?)
    - G37 shrouds
    - 100mm or 110mm halos to match the DRL color
    - XB35 - 35w - 4500K
    am I missing anything?
    I plan on adding some desiccants somewhere hidden to absorb any potential moisture, Andrew your thoughts???
  7. Aug 5, 2015 at 5:42 PM
    #3807
    bellassaiw10
    Currituck NC
    Looks good to me
  8. Aug 5, 2015 at 7:01 PM
    #3808
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Sounds like a good plan. I used the black sealant but if I were to do it again I would go grey only because grey is the colour toyota uses (OCD thing) lol
  9. Aug 7, 2015 at 5:30 PM
    #3809
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    So I figured out that only the passenger side was shaking. I pulled the housing to look at it more closely and I noticed that most of the movement is at the little square plastic fittings that snap into the black plastic frame. I jammed some thin zip tie tips into all the spaces I could find and then snipped off the extra. It sits solid now. As it turns out none of the movement seems to be in the projector assembly.
  10. Aug 7, 2015 at 7:52 PM
    #3810
    bellassaiw10
    Currituck NC
    Yeah same problem I had with mine on my 1st gen it was the actual housing that was causing all my shaking. I ended epoxying it
  11. Aug 7, 2015 at 7:59 PM
    #3811
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yeah but i used zip ties...
    bellassaiw10[QUOTED] likes this.
  12. Aug 8, 2015 at 8:58 AM
    #3812
    bellassaiw10
    Currituck NC
    See my signature hahaha
    alphabravo[QUOTED] likes this.
  13. Aug 9, 2015 at 12:29 PM
    #3813
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Does anybody know if the demon eye kit that trs sells fits the FX-R projector? It says it fits the mini H1 and D2S but it doesn't say if it will work for the FX-R.
  14. Aug 9, 2015 at 2:38 PM
    #3814
    Bpassmore8
    Bpassmore8 Brian13DCSB
    Brian
    Vacaville, CA
    2013 Super White TRD Sport
    Debadged, N-Fab step bars, LED cup holder lights, LED dome and map lights, TRD stickers, HID retrofit (Morimoto Mini H1 6.0, BHLM, HomerTaco ghost raptor grill, OME 885s with 90021 up front, 60091 in the rear with trim spacer
    If nobody know they have a chat feature on the website and are always helpful
  15. Aug 9, 2015 at 3:24 PM
    #3815
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I was going to call but then realized it was Sunday. If I don't get an answer I will just call tomorrow.
  16. Aug 12, 2015 at 2:59 PM
    #3816
    skwidd
    skwidd Active Member
    NOLA
    2022 Limited
    So what are you guys doing to keep the stock lens clear? I recently used the Mother's Headlight Restorer kits because the lens were cloudy. I am thinking of buying new housings (aftermarket).
  17. Aug 12, 2015 at 3:18 PM
    #3817
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    Long flight, and I was thinking of some ideas
    Biscuits and ChadsPride like this.
  18. Aug 12, 2015 at 3:44 PM
    #3818
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Looks good man. Not a bad drawing
  19. Aug 12, 2015 at 3:44 PM
    #3819
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Part of the picture is cut off but the parts I can see do look good. My only tip if you want to call it that is to really take your time on the painting. I gave myself an entire weekend to finish everything off, although it didn't actually take that long.
    Also I baked ALL of the painted components prior to sealing off the headlights just to ensure I didn't get any off gassing once the headlights were sealed back together.
  20. Aug 12, 2015 at 5:35 PM
    #3820
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    For sure. How long and at what temp did you bake the painted parts? Also care to PM me and let me know how you wired up the halo?
