CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Aug 27, 2015 at 5:19 PM
    #3861
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    LSC15 built mine.
  2. Aug 27, 2015 at 5:27 PM
    #3862
    Naleon Taco
    Naleon Taco Active Member
    Puerto Rico
    White Tacoma 2015
    where do I find him, so I can know more aboutthe price?
  3. Aug 27, 2015 at 5:34 PM
    #3863
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Sandman614 likes this.
  4. Aug 27, 2015 at 5:40 PM
    #3864
    Naleon Taco
    Puerto Rico
    White Tacoma 2015
  5. Aug 27, 2015 at 6:28 PM
    #3865
    pat864
    pat864 New Member
    Thanks. Looking forward to this project..
  6. Aug 27, 2015 at 8:33 PM
    #3866
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
  7. Aug 28, 2015 at 5:59 AM
    #3867
    iHacker
    iHacker Well-Known Member
    Rogers, Arkansas
    WeatherTech All season floormats, OEM Toyota Predator Running Board, Toyota Tacoma XSP-X LED DRLs, OEM TRD Pro Headlights retrofitted With FX-R Projectors, Morimoto XB35 Ballasts, Morimoto XB35 5500K Bulbs, Morimoto XB LED Fogs, OEM Toyota Tacoma Skid plate,...
  8. Aug 31, 2015 at 4:47 PM
    #3868
    Taco Moe
    Taco Moe Member
    FLW
    13' Tacoma DCSB TRD
    Fog Light anytime ABS Disable Back up Camera anytime Redline Hood Strut OME 3" lift w/ Dakars wet okole seat covers/weathertech mats to much to detail
    Anyone have issues with the retrofits interfering with the radio? I just installed them and when they are on, my radio signal turns to crap, and when I turn them off, it instantly becomes clear. Hoping the EMI filters will work that TRS offers. just wondering if anyone has had this issue.
  9. Aug 31, 2015 at 4:49 PM
    #3869
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
  10. Aug 31, 2015 at 4:51 PM
    #3870
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I've only noticed this where I have a questionable signal to begin with, then the lights will kill it off. If I have a good radio signal it doesn't seem to make a difference lights on or off.
  11. Aug 31, 2015 at 4:52 PM
    #3871
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I would check to see that you have a good ground. I used one of the studs under the battery where the orange ABS sensor is mounted. Make sure it is sanded clean. Otherwise not sure. I haven't noticed the problem.
  12. Aug 31, 2015 at 5:06 PM
    #3872
    Taco Moe
    Taco Moe Member
    FLW
    13' Tacoma DCSB TRD
    Thanks for the replies, Im using both grounds that was recommended in the write up and they where clean and corrosion free, I figure when the ferrite cores from trs come in I will check on the grounds just to make sure. I have great signal here and literally like a light switch (pun intended) I turn them on and the radio turns to a whole lot of static. Turn them off and the radio comes in great again. I should take a video, but I haven't heard anyone else have a severe problem.
  13. Aug 31, 2015 at 5:08 PM
    #3873
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Happens to me also, I just stopped using the radio and started using my phone and bluetooth for music so it hasn't been a high priority.
  14. Aug 31, 2015 at 5:18 PM
    #3874
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Noise can be caused by having multiple grounds in a system. It's called a ground loop. Maybe that is something you could check although I imagine it is hard to avoid in a vehicle where almost every component relies on a return to the battery via the frame. I'm kinda rusty on my physics so maybe I should look into this more.
  15. Sep 5, 2015 at 1:54 AM
    #3875
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Is it possible to buy a mini d2s kit without the HID's?
  16. Sep 6, 2015 at 9:08 AM
    #3876
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    do you mean without the bulbs or without projectors? you can buy individual components from TRS so yes I think.
  17. Sep 6, 2015 at 9:12 AM
    #3877
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Well they're HID's are made specifically for the kits. I don't know if any old generic kit will work with it. @TRSAndrew would have to clarify
  18. Sep 6, 2015 at 11:01 AM
    #3878
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Unless its a kit with D2 style bulb base you are correct. Maybe he thinks these HIDs are like the not so great plug and play ones.
  19. Sep 6, 2015 at 11:10 AM
    #3879
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's what I was going with, some people already have HIDs and think its just a plug and play
    bellassaiw10[QUOTED] likes this.
  20. Sep 7, 2015 at 11:26 AM
    #3880
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Okay guys, I need some help.
    Recently I replaced my D2S retros with switchback halos because my original halos were burning out. The only thing that I replaced were the halos in my setup. When I put the headlights back in, the voltage regulator that came with it burned up on the passenger side. I thought that maybe I just had a bad voltage regulator. TRS sent another one and the same thing happened. Maybe I just had bad luck. So I got another one and this time I switched the driver side voltage regulator with the passenger one (The one I had no issues with) to see if it was a side specific issue. Well that one burned up also.
    I have my halos wired so they come on with the parking lights.
    When this happens I blow out a 10a fuse for the taillights so basically the first click on my headlights (which turns on the parking lights) will not do anything.
    I also noticed that it seems to happen when I have my headlights on.
    Does anybody have any idea on what im doing wrong? The driver side headlight is wired the exact same way and I have no issues with it.
    Please help with any ideas as they would be much appreciated.
    @TRSAndrew
