CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Sep 7, 2015 at 11:30 AM
    #3881
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Recheck everything on that passenger side. Do you have a clean splice to the parking lights and to the turn signal? No loose strands that can be touching right?
    Delta00[QUOTED] likes this.
  2. Sep 7, 2015 at 11:33 AM
    #3882
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Good idea, I just used the wire from the previous halos and never looked back at the previous splicing job. Ill be sure to check that.
    Thanks
    But also, it seems to just happen when I flip the headlights on.
  3. Sep 7, 2015 at 11:36 AM
    #3883
    LSC15
    Logan
    2008 TRD D-Cab
    I'm not sure but that's what I would check first. First thing I though of
  4. Sep 7, 2015 at 11:37 AM
    #3884
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I be sure to check it. Thanks for the info.
  5. Sep 7, 2015 at 11:46 AM
    #3885
    LSC15
    Logan
    2008 TRD D-Cab
    Let me know what you find out buddy
  6. Sep 10, 2015 at 10:15 AM
    #3886
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    would this group buy work with a purchase of the FX-R 3.0 PNP upgrade?
    or the D2S 3.0 PNP upgrade? since its an option of the pnp upgrade
  7. Sep 10, 2015 at 10:07 PM
    #3887
    WhiteNight
    WhiteNight Well-Known Member
    PDX
    13 DCLB SPORT
    Dynamat, Rigid E series 30", Rigid SR2 combo/Rigid grill, Redline elite hood struts, Clear Bra all over
    I want to do this mod but have 0 clue how. Any info?
  8. Sep 11, 2015 at 4:44 AM
    #3888
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Search this forum, there should be plenty of write-ups, especially for 2nd gens
  9. Sep 11, 2015 at 9:23 AM
    #3889
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    First post near the bottom. Andrew has a write up for installing projectors, as well as wire harness.
  10. Sep 11, 2015 at 4:40 PM
    #3890
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    There are a couple of guys on TW that will build you a set. That's what I did for my first set. Now that I know how they go together I will prolly build the next set myself. It is not to hard if you use the D2 Morimoto Mini kits on TRS.com and if you are careful to keep everything clean during the build.
  11. Sep 13, 2015 at 8:27 PM
    #3891
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Looking to retrofit my 1st gen headlights, bought a FXR Kit, is there any write ups?
    I have a good idea of what im doing but a write up never hurt anyone
  12. Sep 16, 2015 at 4:23 AM
    #3892
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Unfortunately not, only the Stage III kits listed in the first post are valid.
  13. Sep 16, 2015 at 5:22 PM
    #3893
    99TacoDriver
    South Louisiana
    the PNP upgrade seems like a pretty good deal. why is it so much cheaper than the other regular deals? it seems like it comes with all the same stuff.
    i guess what im getting at is...what does the PNP upgrade not have that the normal kit does?
    fx-r stage 3 is $315
    PNP upgrade; fx-r stage 3 is $200
  14. Sep 16, 2015 at 5:43 PM
    #3894
    CayucosTacoma
    2004 Double Cab 4x4
    quality HID kit, harnesses.
    After 25 percent off the stage 3 kit the fxr is
    236, great deal
  15. Sep 16, 2015 at 7:35 PM
    #3895
    99TacoDriver
    South Louisiana
    but it looks like the pnp upgrade is only missing a wire harness...it still comes with your choice of bulbs. and its also a stage 3 kit in the pnp upgrade
  16. Sep 17, 2015 at 12:00 PM
    #3896
    TRSAndrew
    ATL
    It doesn't come with the ballasts or wiring. It's an upgrade FROM a PNP kit to projectors, so you would already need to have a PNP HID kit.
  17. Sep 18, 2015 at 5:24 AM
    #3897
    99TacoDriver
    South Louisiana
    Ahhh gotcha, thanks for the info
  18. Sep 18, 2015 at 8:00 AM
    #3898
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Hey guys,
    Ive been emailing since 9/12 about a potential warranty issue. Only managed to determine that there's no corrosion on any of the connections at the request of your customer service rep. Thats not much progress in 6 days. So, I figure I'd try on here.
    Although I know you'll have it in your emails, the problem is that the headlights are not turning on upon the initial flick of the headlight switch. I'm having to turn the headlight switch on/off multiple times before the headlights fire up. Problem seems to be getting worse.
    Again, no corrosion on any connectors.
    Is there anything else you guys want me to check? I'd like to have the product warrantied if in fact it's faulty, but want to check anything you need me to ahead of time to expedite the process. I leave for Dallas on Monday and if I can narrow things down and ship something back to you on Monday, when I won't need to drive the truck, I'd like to.
    Please let me know
    Thanks......
  19. Sep 18, 2015 at 2:52 PM
    #3899
    LSC15
    Logan
    2008 TRD D-Cab
    Is it just one side having trouble or both
  20. Sep 19, 2015 at 9:32 AM
    #3900
    99TacoDriver
    South Louisiana
    ive had a wiring harness that did that to me. i took a good luck at all the connectors and noticed that the plug was not fully connected with the wire.
    i noticed this by turning on the headlights and examining the ballast and harness and i could hear the plugs "humming" (they were actually arcing between the wire and the plug) so i turned the headlights off and disconnected it from the battery and reattached the plugs to the wire. note: i am talking about a cheap wiring harness and not the ballast/harness that come with the TRS packages.
    i was probably the one to damage the plugs from pulling too hard on it.
    maybe try taking a harder look at the plugs that plug into the ballast.
    hope this helps
