CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Oct 26, 2015 at 9:23 AM
    #4001
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    You ran them on outside of shroud though?
  2. Oct 26, 2015 at 10:13 AM
    #4002
    crunchy11
    crunchy11 Well-Known Member
    North CA
    stock(too stock) 13 trd
    seat stains
    Yea. The panarama leds wires face out board. It was the easiest route without breaking them off and soldering back on. Barely visible. this was my first go,
    I wanted to have them done by a pro but I cant afford it.
  3. Oct 26, 2015 at 11:18 AM
    #4003
    LSC15
    Logan
    2008 TRD D-Cab
    I understand buddy
  4. Oct 27, 2015 at 3:41 PM
    #4004
    crunchy11
    North CA
    seat stains
    well looks like Ill be taking mine apart again.
    well my fix worked for about two days. looks like Ill be cracking these back open, Im assuming I can only order two xb halos?
  5. Oct 28, 2015 at 8:02 PM
    #4005
    johnnys219
    johnnys219 big dreams, little money
    johnny
    new jersey
    2015 dclb trd sport
    3 inch bilstein lift. 4runner brake upgrade. offroad bumper. full on board air and electronics
    @TRSAndrew i ordered the d2s stage 3. but i could not find where to put my username in the comment. i made 2 orders. email johnnys_219@hotmail.com the only place i saw was in shipping instructions. but i was unsure.
  6. Oct 28, 2015 at 8:23 PM
    #4006
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Can someone point me in the right direction here? 05-11 retrofit with d2s 3.0. I Ground down the back of the reflector leaving enough for the "alignment ring" to sit where it belongs and the hex nut to clear. The idea is the projector will sit at the correct angle regardless or crooked grinding. When I put the nut on it doesn't tighten down evenly. The top of the projector is tight but the bottom is loose and the projector moves.
    1464601085.jpg IMG_20151028_141905.jpg IMG_20151028_141929.jpg IMG_20151028_143645.jpg
  7. Oct 28, 2015 at 8:25 PM
    #4007
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    It looks like the top lip is catching in the first and second photos
  8. Oct 28, 2015 at 8:28 PM
    #4008
    Sandman614
    Tim
    '06 SR5 Off Road
    Can you pm me?
  9. Oct 28, 2015 at 8:29 PM
    #4009
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    It's been a while since I did my retrofit, but I recall you need to modify that alignment ring otherwise your alignment will actually be off. I know it's separate from what you were asking but figured I would mention it.
  10. Oct 28, 2015 at 8:36 PM
    #4010
    Sandman614
    Tim
    '06 SR5 Off Road
    Well maybe I should go without this ring..
  11. Oct 28, 2015 at 8:39 PM
    #4011
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I think I just removed the tab that is in the ID of the circle. Seems to me the ring would actually lock you in around 15* out from having a level cutoff. I did mine a while back and only once so others are probably better suited to give advice on that.
    Sandman614 likes this.
  12. Oct 28, 2015 at 8:42 PM
    #4012
    bellassaiw10
    Currituck NC
    This is right just grind the inside nub piece off
  13. Oct 28, 2015 at 9:07 PM
    #4013
    Sandman614
    Tim
    '06 SR5 Off Road
    I wonder if that's my issue, I'll try it.
  14. Oct 28, 2015 at 9:10 PM
    #4014
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Probably not your issue with tightening the nut, but would be your next issue when trying to get a nice level cutoff.
  15. Oct 29, 2015 at 2:19 AM
    #4015
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    You may have to shave some more in the back. Honestly, you don't even have to use the alignment ring
  16. Oct 29, 2015 at 2:25 AM
    #4016
    TRSJimmy
    Jimmy
    Gainesville, GA
    Like so , from Andrews write up
    Before:
    After:
    9) Mount the projector using only the silicone washer at the front and the hex lock ring at the rear. Tighten as much as you can by hand--no wrench or socket.
    Rear:
    After you aligned it, add some jbweld to the hex nut and the reflector bowl. Boom!
  17. Nov 2, 2015 at 2:29 PM
    #4017
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Looks like it needs to be shaved down even more, but definitely the right idea!
  18. Nov 2, 2015 at 2:33 PM
    #4018
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ugh, i really need to get my retrofits installed!!! I havent really had a free weekend since they showed up months ago!! Newborn baby has killed all my truck mod time lol
  19. Nov 2, 2015 at 2:36 PM
    #4019
    Sandman614
    Tim
    '06 SR5 Off Road
    I just got done shaving down the silicone ring. This will allow the projector to sit at the same orientation as a regular h4 bulb.
    The problem is that the inside of the reflector bowl is different thicknesses at the top and bottom. This doesn't allow the nut to sit flush with the correct h4 mounting surface. This makes the projector tilt upwards, and when installed I can only assume everyone has to aim the headlight lower to counter this.
  20. Nov 2, 2015 at 2:48 PM
    #4020
    TRSAndrew
    ATL
    I've never had any issues based on that minor difference, to be honest. You can always over-compensate with a few extra threads on the adjuster screw.
