CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Jul 23, 2016 at 8:20 AM
    #5001
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Last time I heard was mid September when it will be available. There was a prototype d2s 4.0 in closeout section. Not sure if it was sold or not
  2. Jul 26, 2016 at 2:24 PM
    #5002
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    @TRSAndrew
    Does anyone know of a quality strobe module? I'm thinking that I could add a strobe circuit to all the white/amber LEDs but it would have to be rated for the full current since I don't think you can strobe a relay.
    Edit: I think I found the one I want from Whelen for like $60. It is rated for 5A/60W on 4 channels.
    Mr.PowerTrays likes this.
  3. Jul 29, 2016 at 12:12 PM
    #5003
    Wyldman
    Wyldman Well-Known Member
    Chance
    Rural,MS
    2014 White Tacoma TRD Offroad
    3" Leveling Kit, ~33" General Grabber A/T, 18"x9" Machined Rockstar II, Fender Flares, Road Armour Front Bumper, 10K Smittybuilt Winch.
    Okay sorry it took so long, I have been hampered by a knee surgery so everything takes alot longer than I think.
    20160729_132751.jpg 20160729_132821.jpg 20160729_132845.jpg 20160729_132942.jpg 20160729_132949.jpg 20160729_133009.jpg 20160729_133037_001.jpg 20160729_133055.jpg 20160729_133101.jpg 20160729_133110.jpg
    runner001, BYJOSHCOOK and Boomkanani like this.
  4. Jul 29, 2016 at 12:20 PM
    #5004
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    What is that redish color coming from the backside...paint?
  5. Jul 29, 2016 at 3:03 PM
    #5005
    Wyldman
    Chance
    Rural,MS
    That's the color change halo set on red. It's hard to see during the day.
  6. Jul 29, 2016 at 5:30 PM
    #5006
    Jbeiker
    Jbeiker Well-Known Member
    2016 Trd Sport
    Any discount for either the hid elite h11 kit or the h11 led 2 stroke kit?
  7. Jul 29, 2016 at 7:57 PM
    #5007
    TRSJimmy
    Jimmy
    Gainesville, GA
    Nopeeeee
  8. Jul 29, 2016 at 8:17 PM
    #5008
    Boomkanani
    Goldsboro, NC
    Some stuffz
    Oh gotcha. Looks really good man
  9. Jul 30, 2016 at 2:45 PM
    #5009
    Wyldman
    Chance
    Rural,MS
    Thanks!
  10. Aug 3, 2016 at 7:22 PM
    #5010
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Ok guys I'm having alot of trouble....
    I had a driver go bad and had TRS send me 3 so far and none of them work. Passenger side, drivers side still functions fine. I have confirmed the passenger side halo is still working by unplugging the drivers side halo driver and using jumpers to run to the passenger side. The passenger side halo DOES TURN ON WHEN I DO THIS.
    I have ran all three drivers directly to the battery and plug them into the halo and nothing happens. That halos are getting power as I tested it with a test light.
    Idk what to do.... did they change there drivers? My halos are AMBER ONLY. I now have them rigged up on xchange drivers so they turn off when the headlights are on. They both worked fine when I did this. The x change driver I had rigged with using the halo driver that had a black and red on one end, then a black, yellow and white on the other. The black yellow and white matched up with the xchange driver wires. TRS has only sent me drivers with red and black on both sides.....they said it will still work with the xchange....I don't see how though.
  11. Aug 8, 2016 at 7:05 PM
    #5011
    runner001
    runner001 Member
    Wow! There are some sweet setups in this thread!
  12. Aug 17, 2016 at 7:22 PM
    #5012
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I have a problem. There seems to be a film on the inside of one of my lights. I already have it apart and normal glass cleaner won't get rid of the film. I'm thinking it may have been caused by the plastic shroud getting really hot during the summer, similar to the film that can form on the inside of your windshield when the interior has a lot of super hot days. Only difference is, I can't get it off the lens. Any suggestions? Wet sanding perhaps? I surely don't want to make it worse than it already is...
  13. Aug 17, 2016 at 7:41 PM
    #5013
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    How old are they?
  14. Aug 17, 2016 at 7:46 PM
    #5014
    MatthewMay1
    Matthew
    Lone Star Republic
    Less than a year
  15. Aug 17, 2016 at 7:46 PM
    #5015
    TRSJimmy
    Jimmy
    Gainesville, GA
    Let me guess, you either used spray paint or some silicon to seal your headlights? And the film is somewhere towards the top right?
    I wouldn't even touch the inside lens without distilled water and a high quality microfiber rag. Anything else, you can scratch it.
    TacomaArto likes this.
  16. Aug 17, 2016 at 7:52 PM
    #5016
    MatthewMay1
    Matthew
    Lone Star Republic
    I sealed with retro rubber and then a layer of silicone around the outside. The haze is right in the middle of the lens. It's actually the clearest around the sides
  17. Aug 17, 2016 at 7:58 PM
    #5017
    TRSJimmy
    Jimmy
    Gainesville, GA
    Interesting. Maybe the shrouds or spray paint on the shrouds. Happens when it gets hot outside and paint starts gassing.
  18. Aug 17, 2016 at 7:59 PM
    #5018
    MatthewMay1
    Matthew
    Lone Star Republic
    I think that's exactly what it is. I've tried glass cleaner and micro fiber and it won't come off at all
    Edit: Do you think I should use the toothpaste method?
  19. Aug 17, 2016 at 8:02 PM
    #5019
    TRSJimmy
    Jimmy
    Gainesville, GA
    I was told to never touch the insides. If you really really really have to, distilled water and a quality microfiber rag. I'm not sure about the toothpaste method, only seen it work on outer lens.... I don't want you to mess up your hard work!
  20. Aug 17, 2016 at 8:02 PM
    #5020
    MatthewMay1
    Matthew
    Lone Star Republic
    Yeah, I'll be pissed if I make it worse
